- GPU: 4070Ti
- Video driver version: 535.86.05
- Kernel version: 6.3.12
- Proton version: 8.0-104, GE 8-9, Experimental
Foliage flickers unless you run the game with VKD3D_DISABLE_EXTENSIONS=VK_EXT_mesh_shader, see video here: 2023 07 25 21 13 47 - YouTube
Since this game is UE5 and uses Nanite, this is probably relevant: UE 5.1 MAWI demo mis-renders mesh shader path · Issue #1632 · HansKristian-Work/vkd3d-proton · GitHub
The problem is still here with 545.29.06. When I try VKD3D_DISABLE_EXTENSIONS=VK_EXT_mesh_shader the game crashes a few seconds after start. I installed beta Vulkan 535.43.22 and it’s working with the variable. Without the variable it’s still flickers a lot.
