[BUG] the descriptionScheduleYamlGenerator.py from 6.0.8.1 output nothing with MiniPipeline.app.json
Required Info:
  • Software Version
    DRIVE OS 6.0.8.1
  • Target OS
    Linux
  • SDK Manager Version
    1.9.2.10884
  • Host Machine Version
    native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
the descriptionScheduleYamlGenerator.py in 6.0.8.1 cannot generate any yaml with the demo app.json
To Reproduce
/usr/local/driveworks/tools/descriptionScheduleYamlGenerator/descriptionScheduleYamlGenerator.py --app /usr/local/driveworks/apps/minipipeline/applications/MiniPipeline.app.json --output ./aaa.app.yaml
Expected behavior
/usr/local/driveworks/tools/descriptionScheduleYamlGenerator/descriptionScheduleYamlGenerator-old.py --app /usr/local/driveworks/apps/minipipeline/applications/MiniPipeline.app.json --output ./aaa.app.yaml
Input Description file path: /usr/local/driveworks/apps/minipipeline/applications/MiniPipeline.app.json
Output schedule directory path: /gw_demo/
Analysis...
Generating...
Yaml schedule generated : standardSchedule : 0 : /gw_demo/MiniPipeline__standardSchedule.yaml
Json description to Yaml schedule file done.
Actual behavior
zs@in-sdk-docker:/gw_demo$ /usr/local/driveworks/tools/descriptionScheduleYamlGenerator/descriptionScheduleYamlGenerator.py --app /usr/local/driveworks/apps/minipipeline/applications/MiniPipeline.app.json --output ./aaa.app.yaml
Analysis...
Generating...
Additional context
the python from last release 6.0.6 works well.
Dear @lizhensheng,
I could reproduce the issue. Thanks for letting us know.
Please share the latest .py after resolving this issue.
Dear @lizhensheng,
Could you try /usr/local/driveworks/tools/descriptionScheduleYamlGenerator/descriptionScheduleYamlGenerator.py --app /usr/local/driveworks/apps/minipipeline/applications/MiniPipeline.app.json --output ./MiniPipeline__standardSchedule.yaml and confirm if it is working?
It’s not working.
Can you reproduce this behavior?
I don’t see any issue with the command
root@6.0.8.1-0006-build-linux-sdk:/home/nvidia# cd test
root@6.0.8.1-0006-build-linux-sdk:/home/nvidia/test# ls
root@6.0.8.1-0006-build-linux-sdk:/home/nvidia/test# /usr/local/driveworks/tools/descriptionScheduleYamlGenerator/descriptionScheduleYamlGenerator.py --app /usr/local/driveworks/apps/minipipeline/applications/MiniPipeline.app.json --output ./MiniPipeline__standardSchedule.yaml
Output schedule directory path: /home/nvidia/test/
Analysis...
Generating...
Yaml schedule generated : standardSchedule : 0 : /home/nvidia/test/MiniPipeline__standardSchedule.yaml
I reproduce with your behavior.
