On previous Jetpacks with TX1 I had no problems compiling the argus samples using cmake and the readme instructions. When I do the same thing on a TX2 with JP3.1’s multimedia API I get lots of build errors related to CreateValueOption. Is this a known issue? Is there a newer version of the argus samples apps?
Scanning dependencies of target arguscamerauicommon
[ 42%] Building CXX object apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/App.cpp.o
[ 43%] Building CXX object apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/AppModuleGeneric.cpp.o
In file included from /home/ubuntu/tegra_multimedia_api/argus/samples/utils/Validator.h:45:0,
from /home/ubuntu/tegra_multimedia_api/argus/samples/utils/Value.h:35,
from /home/ubuntu/tegra_multimedia_api/argus/apps/camera/modules/Dispatcher.h:38,
from /home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:34:
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp: In member function ‘virtual bool ArgusSamples::AppModuleGeneric::initialize(ArgusSamples::Options&)’:
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:145:52: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_deviceIndex)));
/home/ubuntu/tegra_multimedia_api/argus/samples/utils/Error.h:74:26: note: in definition of macro ‘PROPAGATE_ERROR’
bool peResult = (_err); \
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:151:58: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_exposureTimeRange)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:154:50: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_gainRange)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:157:56: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_sensorModeIndex)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:161:62: error: ‘createValueOption’ was not declared in this scope
"enabled.", Dispatcher::getInstance().m_frameRate)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:165:54: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_focusPosition)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:172:51: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_outputSize)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:178:51: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_outputPath)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:183:50: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_vstabMode)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:186:52: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_denoiseMode)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:189:56: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_denoiseStrength)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:192:56: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_edgeEnhanceMode)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:196:60: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_edgeEnhanceStrength)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:201:58: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_aeAntibandingMode)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:204:47: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_aeLock)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:207:48: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_awbLock)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:210:48: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_awbMode)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:214:61: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_exposureCompensation)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:218:60: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_ispDigitalGainRange)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:226:56: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_deFogEnable)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:230:56: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_deFogAmount)));
/home/ubuntu/tegra_multimedia_api/argus/apps/camera/ui/common/AppModuleGeneric.cpp:234:57: error: ‘createValueOption’ was not declared in this scope
Dispatcher::getInstance().m_deFogQuality)));
apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/build.make:86: recipe for target 'apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/AppModuleGeneric.cpp.o' failed
make[2]: *** [apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/AppModuleGeneric.cpp.o] Error 1
CMakeFiles/Makefile2:266: recipe for target 'apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/all' failed
make[1]: *** [apps/camera/ui/common/CMakeFiles/arguscamerauicommon.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
ubuntu@tegra-ubuntu:~/tegra_multimedia_
