Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Dear @yannick.otten,
I could see error related to compiling .cu files. I would expect this in DRIVE OS 5.2.0 due to unavailability of nvcc on target where as DRIVE SW 10 has nvcc on target.
PyTorch is not officially supported and optimized for DRIVE platform. We recommend using ONNX → TensorRT conversion and use TensorRT model for inference to get optimal performance. Please check Developer Guide :: NVIDIA Deep Learning TensorRT Documentation for more details.
I don’t understand why PyTorch is supported on the Jetson and not on the DRIVE platform. Converting models to ONNX and then to TensorRT is a really time consuming workflow and shouldn’t be a “solution”.
Note that, The releases for Jetson and DRIVE are different. TensorRT is well optimized for DRIVE platform and we are optimizing it further and adding support for new op/layers in each release. We have provided parsers to integrate ONNX models into TensorRT. We recommended to convert your model to ONNX for optimal performance . You can prepare your model and convert to ONNX on host machine and then use TRT APIs for ONNX → TRT conversion on target. Please check sampleONNXMnist sample for converting ONNX → TRT.
As I said, we do not officially support building instructions for pyTorch as the versions keep changing You may seek help from the community
