Working on should buildings in a stage.
Each building has Geometry with matrix like this:
Can I create an XForm (called site) to move all buildings to 0,0,0 so sun study extension will work correctly?
Yes you can. If you group everything under a fresh xform you can move everything together as one group. Or you can add a standard XYZ coordinate system over the top of this prim. The 4x4 matrix occurs with some DCC software and some connectors. Ideally this should not happen. We encourage all prims to have standard XYZ coordinate systems.
I tried and didn’t realise how to calculate the right transformation.
The object are really far, so working with the Gizmo wasn’t an option.
Trying to slide the X or Y didn’t work as expected.
Thanks for the answer :)
Yaakov.
