I’m writing driver for a system with 8 cameras that have same I2C addresses for AGX Xavier. Currently we’re using a tca9548 hardware I2C switch to avoid address conflicts, but I’d like to inquire about other possibilities.
I noticed that on the Jetson Xavier NX platform, a GPIO-controlled cam_i2cmux (“i2c-mux-gpio”) is used in tegra194-camera-jakku-rbpcv2-imx219.dtsi. If I understand things correctly, this cam_i2cmux is built into the Xavier NX and not a hardware switch on a carrier board, is that correct? Is this cam_i2cmux feature also available on Jetson AGX Xavier as well? If so, is there any differences in the GPIO pin settings?
Sorry, but which pins? I checked the pinmux configuration spreadsheets for both Jetson NX and AGX Xavier, there is a GPIO6 reserved for ‘Baseboard CAM MUX Sel’ for NX, but I couldn’t find a similar one for AGX Xavier.
Unfortunately I don’t have a Jetson Xavier NX at hand right now. Could you please tell me what is the part number of this “hardware MUX” chip used on NX? I couldn’t find anything about it in the Jetson Nano and Jetson Xavier NX Camera Design Guide. All it says in section 6.1 is: “Jetson Xavier NX Developer Kits use a MUX to direct CAM_I2C to either of the two camera connectors that does not have an I2C address and selects between the two connectors using a GPIO”
