Can you tell me about the Camera Specifications on TX1 developer kit?
ex) Image sensor, resolution, etc…
The image sensor is an OmniVision OV5693 5MP sensor.
As for FOV I’m not sure if it’s 80 degrees or 88 degrees (the two most common on Sunny Optical’s product lineup). The camera is a Sunny Optical p5v27c, although finding a datasheet for that part marking is proving to be impossible, if anyone else has knows the FOV I’d also be interested.
where you able to figure out the FOV, i measured mine, it was 70 degree for the TX2, still trying to identify the datasheet? any leads would be appreciated.
