Can I run opensm on Ubuntu under Windows Subsystem for Linux (WSL)?
If I install the appropriate software/drivers, can I run opensm on Ubuntu under Windows Subsystem for Linux (WSL)?
Thank you.
No, unfortuantely, I only have an unmanaged switch and since the Windows driver doesn’t come with OpenSM anymore, therefore; I HAVE to have a Linux system running just to run OpenSM.
Thank you.
This configuration is not tested and there is no plans to test it. If you have managed IB switch, you might enable SM in it or use dedicated Linux host to run subnet manager or Unified Fabric Manager (UFM).
