Can not change camera pose
Hello,I’m tring to use rep.distribution.uniform to change the camera pose, but the pose it generate never change, how to change the camera pose when using the replicator? my code is as follow:
with rep.new_layer():
    plane = rep.create.plane(scale=100, visible=True)
    port = rep.create.from_usd(path, semantics=[("class", "port")])
    camera = rep.create.camera(
        # position=(1,0.5,36),
        position=rep.distribution.uniform((0.9, 0.4, 10), (1.1, 0.6, 40)),
        rotation=(-90, -90, 0),
        focus_distance=rep.distribution.normal(400.0, 100),
        f_stop=0,
        look_at=port
def get_CameraDR():
    with camera:
        rep.modify.pose(
             position=rep.distribution.uniform((-5, -5, 0), (5, 5, 0)),
             #rotation=rep.distribution.uniform((0, -90, 0), (0, -90, 180)),
             look_at=port
    return camera.node
def start(name):
    rep.randomizer.register(get_CameraDR)
    with rep.trigger.on_frame(num_frames=30):
        rep.randomizer.get_CameraDR()
if __name__ == '__main__':
    start('PyCharm')
whether in the create function or in the randomizer , the pose never change. My isaac sim version is 2022.2.0,and the code is run in script editor
Hi there,
the following script worked from my side. Once you press Replicator → Step the Xform of the camera changes location.
        f_stop=0,
def get_CameraDR():
    with camera:
        rep.modify.pose(
    return camera.node
def start(name):
    start('PyCharm')
Let me know if you still have issues.
Hi, I have tested your code,It can work in 2022.2.0 ,maybe it’s the ‘look_at’ in my code affect the program.
