my device is jetson orix nx 16GB
Software part of jetson-stats 4.2.8 - (c) 2024, Raffaello Bonghi
Model: NVIDIA Orin NX Developer Kit - Jetpack 5.1.1 [L4T 35.3.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
P-Number: p3767-0000
Module: NVIDIA Jetson Orin NX (16GB ram)
Platform:
Distribution: Ubuntu 20.04 focal
Release: 5.10.104-tegra
jtop:
Version: 4.2.8
Service: Active
Libraries:
CUDA: 11.4.315
cuDNN: 8.6.0.166
TensorRT: 8.5.2.2
VPI: 2.2.7
Vulkan: 1.3.204
OpenCV: 4.9.0 - with CUDA: YES
I searched the entire system but couldn’t find libnvcuvid.so. I only found
/usr/lib/aarch64-linux-gnu/tegra/libnvcuvidv4l2.so
what should i do
The lib may be specific to dGPU. Not in-use on Jetson platforms. You may share your use-case so that we can suggest next.
build decord from source
dmlc/decord: An efficient video loader for deep learning with smart shuffling that’s super easy to digest
i build it like
cmake … -DUSE_CUDA=/usr/local/cuda-11.4 -DCMAKE_BUILD_TYPE=Release
and then
CMake Error at cmake/modules/CUDA.cmake:33 (message):
Cannot find libnvcuvid, you may need to manually register and download at
Video Codec SDK | NVIDIA Developer . Then copy libnvcuvid
to cuda_toolkit_root/lib64/
Call Stack (most recent call first):
CMakeLists.txt:92 (include)
i search ‘/usr/local/cuda-11.4/lib64’ not found libnvcuvid.so
from Video Codec SDK | NVIDIA Developer what should i do
tks.
The application should be for dGPU. Not supported on Jetson. For developing multimedia use-cases on Jetson, please use gstreamer or jetson_multimedia_api
system
Closed
January 1, 2025, 12:53am
8
