Can not login to SDKM with error "User is not authorized on NVIDIA developer server"
I try to login to Jetson SDK manager but error “User is not authorized on NVIDIA developer server” occurs, below I’m attaching logs from .nvsdkm/sdkm.log
17:19:23.193 - info: SDK Manager started running at: 2025-01-24 17:19:23.192
17:19:23.193 - info: SDK Manager log file name: sdkm-2025-01-24-17-19-23.log
17:19:23.194 - info: SDK Manager client version: 2.2.0
17:19:23.194 - info: SDK Manager is running in GUI mode
17:19:23.194 - info: Arch: x64
17:19:23.310 - info: Electron main process is ready to create BrowserWindow
17:19:23.723 - info: not running on WSL 5.15.0-130-generic
17:19:23.752 - info: Current DB Version:  20
17:19:23.861 - info: /etc/os-release NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
17:19:23.861 - info: /etc/issue Ubuntu 20.04.6 LTS \n \l
17:19:23.861 - info: /etc/lsb-release DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.6 LTS"
17:19:23.868 - info: codeNameCounts in /etc/apt/sources.list { focal: 10 }
17:19:23.903 - info: User agent for http requests: SDKM/2.2.0.12028 (ubuntu20.04)
17:19:23.964 - info: Initializing GA4 Telemetry client ID: 62ca6b25-d7f4-54bf-b6f5-e997afc1b658
17:19:23.978 - info: downloadMetrics.reset
17:19:23.981 - info: Forking worker process
17:19:23.984 - info: Initializing the download service
17:19:23.987 - info: Download service pid is: 3942
17:19:23.988 - info: Download manager can use up to 12 download threads per file
17:19:24.004 - info: create .sdkm.bashrc under /home/nuc/.nvsdkm/.sdkm.bashrc
17:19:24.008 - info: installMetrics.reset
17:19:24.008 - info: uninstallMetrics.reset
17:19:24.012 - error: Cannot get user selected groups
17:19:24.151 - info: Logger level is set to: info
17:19:24.293 - info: Front-end main function (startMain) was called
17:19:24.336 - info: Creating auto update task
17:19:24.339 - info: Host OS: ubuntu20.04
17:19:24.341 - info: packageJson: /opt/nvidia/sdkmanager/resources/app/package.json
17:19:24.396 - info: [Download Service]:Download service is initializing
17:19:24.396 - info: [Download Service]:Download service was initialized
17:19:24.396 - info: [Download Service]:Got heartbeat request
17:19:24.397 - info: [Download Service] Download service is alive
17:19:24.413 - info: LastSeenSDKMClientVersion is set to 2.2.0.12028
17:19:24.425 - info: Screen res: 2560 x 1440, scaleFactor 1
17:19:24.414 - info: Application configuration is: {"mainRepoURL":"https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json","hwRepoURL":"https://developer.download.nvidia.com/sdkmanager/sdkm-config-hw/sdkml1_repo_hw.json","PIDServer":"P","DevZoneServer":"P","StarfleetServer":"P"}
17:19:24.424 - info: manifest: {"name":"sdkmanager","releaseVersion":"2.2.0","releaseRevision":"0","releaseBuild":"12028","release":false,"chrome":"91.0.4472.164"}
17:19:24.424 - info: Telemetry parameters are: title: SDK Manager 2.2.0.12028 version: 2.2.0 dev: 0 internal: undefined
17:19:24.424 - info: tryToAutoLogin failed: Aborting auto login since there is no logged in user
17:19:24.424 - info: Telemetry: allow = . isGDPRAllowed=false
17:19:24.424 - info: Total memory: 15.27 GB
17:19:24.426 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
17:19:24.460 - info: Create timing task for auto update successfully.
17:19:25.200 - info: Created symlink /home/nuc/.nvsdkm/sdkm-2025-01-24-17-19-23.log => /home/nuc/.nvsdkm/sdkm.log
17:19:25.444 - info: logging in to starfleet server
17:19:25.445 - info: Logging in with starfleet login method...
17:19:25.452 - info: Event: Login Progress: undefined
17:19:25.459 - info: Listening to Starfleet Redirect URL on port: 8080
17:19:25.460 - info: Opening login URL in browser:  https://login.nvidia.com/authorize?response_type=code&client_id=_gWkp8NvPxc7svfRKyXJ4IseQyYupLhWJiMxyPy0gm4&scope=openid+consent+email&device_id=8e258895f2df86c71327bbde4ffe0db25f0060baefd2a7aa9f4ae7c288d2aebf&code_challenge=ITlQcH5Evdw-WXgtjqjFFMBJfVwwNxjQza4FrsC7y_w&code_challenge_method=S256&prompt=login&ui_locales=en_US&nonce=67676767&redirect_uri=http%3A%2F%2Flocalhost%3A8080
17:19:25.460 - info: Event: Login Progress: Waiting for user to complete login in the external browser...
17:19:38.600 - info: The local server receives a request from external browser.
17:19:38.600 - info: Got Starfleet server signin response. Request URL:  /sdkmanager/?ui_locales=en_US&code=1YFQMeJbwKmVf0UkbEigE0xZ2cbMBWS3Wsp-Q1FwHJtfeHz35Z7vb6zz_Xgk4al-EkWmjNVS41IbBnu3ODb96Q
17:19:38.600 - info: Event: Login Progress: dz_login_auth_completed
17:19:39.108 - info: Event: Login Progress: Logging into NVIDIA Developer server...
17:19:39.110 - info: Event: Login Progress: Login credentials retrieved successfully.
17:19:39.112 - info: start to get startfleet user info
17:19:39.114 - info: start to get devzone user info
17:19:39.114 - info: User programs URL is: https://developer.nvidia.com/api/user/programs
17:19:39.115 - info: User profile URL is: https://api-prod.nvidia.com/services/eupservice/v1/user/getProfile
17:19:39.116 - info: start to get user profile from EUP
17:19:39.379 - info: get user profile from EUP takes 0.263 sec
17:19:39.467 - info: get startfleet user info takes 0.354 sec
17:19:39.467 - info: Event: Login Progress: Loading user information...
17:19:39.676 - error: devzone getDevzoneUserInfo error, took 0.562s. Error: HTTPError: Response code 403 (Forbidden).
17:19:39.677 - info: Event: Login Complete: failed
17:19:39.677 - error: loginManager.login failed: unauthorized_user_dz
Is your ubuntu running on a physical machine or virtual machine (e.g. WSL, VirtualBox, VMware)?
Please check below for a similar topic:
Based on the comment on the above topic, could you update your SDK manager and try again?
