The dts configuration for /dev/ttyS0 is show below, but I don’t see any pin number can be calculated from this configuration, although I know the pin number is 236 for tx and 238 for rx. Can you describe how to find out the pin number we are using through this dts?
uarta: serial@3100000 {
compatible = “nvidia,tegra186-hsuart”;
iommus = <&smmu TEGRA_SID_GPCDMA_0>;
reg = <0x0 0x03100000 0x0 0x40>;
reg-shift = <2>;
interrupts = <0 TEGRA186_IRQ_UARTA 0x04>;
nvidia,memory-clients = <14>;
dmas = <&gpcdma 8>, <&gpcdma 8>;
dma-names = “rx”, “tx”;
clocks = <&tegra_car TEGRA186_CLK_UARTA>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>;
clock-names = “serial”, “parent”;
resets = <&tegra_car TEGRA186_RESET_UARTA>;
reset-names = “serial”;
status = “disabled”;
nvidia,tolerance-low-range = <0>;
nvidia,tolerance-high-range = <4>;
nvidia,adjust-baud-rates = <115200 115200 100>;
Hi
Yes, we are using the custom board according devkit for TX2_NX.
But still I don’t know how.
R32.5.1
gpiochip2: GPIOs 248-255, parent: platform/max77620-gpio, max77620-gpio, can sleep:
gpio-253 ( |spmic_gpio_input ) in lo
gpio-254 ( |spmic_gpio_input ) in lo
gpiochip1: GPIOs 256-319, parent: platform/c2f0000.gpio, tegra-gpio-aon:
gpio-302 ( |eqos_phy_reset ) out hi
gpio-312 ( |power-key ) in hi
gpiochip0: GPIOs 320-511, parent: platform/2200000.gpio, tegra-gpio:
gpio-408 ( |w-disable1 ) out lo
gpio-410 ( |w-disable2 ) out lo
gpio-412 ( |external-connection:) in lo
gpio-441 ( |hdmi2.0_hpd ) in lo
gpio-456 ( |camera-control-outpu) out lo
gpio-461 ( |camera-control-outpu) out lo
