Can you ever imagine a MIPI camera can stream 15 meters away from the host?
You may need ser/des or gmsl chip for this kind of case.
Yes @ShaneCCC here is the solution for it.
e-con Systems’ GMSL cameras use GMSL & GMSL2 technology, a SerDes technique, to carry high-speed video, bidirectional control data, and power over a single coaxial cable. The GMSL & GMSL2 cameras are SerDes cameras which can be used for longer distance. These cameras can be placed 15 meters away from host processor through coaxial cable and still to support less latency and high frame rate.
Know more: GMSL Cameras | SerDes Cameras | GMSL2 Cameras
