Cannot build jp6.1 RT kernel
Ran the script and it cannot find paths or create symbolic links.
fred@eng-ai1:~/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source$ ./generic_rt_build.sh enable
Enable RT kernel
cp: cannot stat '/home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/defconfig': No such file or directory
cp: cannot stat '/home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/tegra_prod_defconfig': No such file or directory
./generic_rt_build.sh: line 61: /home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/scripts/config: No such file or directory
./generic_rt_build.sh: line 71: /home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/scripts/config: No such file or directory
cp: cannot stat '/home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/.updated.defconfig': No such file or directory
ln: failed to create symbolic link '/home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/tegra_defconfig': No such file or directory
cp: cannot stat '/home/fred/yocto/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/.updated.tegra_prod_defconfig': No such file or directory
PREEMPT RT config is set successfully!
sdkmanager does not rebuild the kernel, it just keeps uploading the original one that was build initially.
Please refer to the steps in
No data from Joystick Logitech-f710 - #10 by DaneLLL
Hi @DaneLLL
I will try that, thank you.
