Cannot delete the folders from Nucleus
I was trying to delete the folders and files from Nucleus website.
Somehow I met the message bellow and the folder can not be deleted.
Is there any other way to delete the folders?
I am using omniverse enterprise version, so Nucleus is installed in an individual PC.
Thank you very much.
Frank Liu
Hello @frank_liu! I’ll get someone from the dev team to help you with this!
The account you are logged in with - is it an Admin account?
Not proposing that you have to be an administrator to delete items - but it looks like there’s been a snag with the permissions on the thumbnails. If you have an admin account you should be able to override those permissions and just delete.
Hi @WendyGram and @mkarlsson,
Thank you for the reply.
The account name “omniverse” I use to delete the folders and files is an Admin account, which is the default Master superuser of Nucleus server.
By the way, I login with the account who created the folder, still cannot delete the folder.
The error message shows “FOLDER_NOT_EMPTY”, but I didn’t see anything in this folder.
got it - discussing with team
can you show me the permissions on that Linked folder please?
also, try to edit the path you are viewing by manually entering /Linked/.thumbs after Assets - what permissions do you see on items there?
Hi @mkarlsson ,
The screen shot shows as bellow.
After editing the path to enter /Linked/.thumbs after the path of Assets shows the error message at the bottom right.
By the way, I login as both “omniverse”(account as super user) and “user2”(account who created the folder). The error message show “Path does not exist.” after editing the path of Assets. .
Hi @frank_liu
If you are following the default docker-compose setting, please check the “content.1.1” folder under “/var/lib/omni/nucleus-data/data/”.
If the folder is empty then there should be no file uploaded.
In addition, which OS you are hosting the nucleus server?
@frank_liu what exact version of Nucleus are you running please?
Hi @frankt ,
The folder content.1.1 is not empty and with several omni.content.xxx files in the path.
I installed Ubuntu 18.04.6 LTS as the OS of nucleus server.
Hi @mkarlsson ,
I used the version 2022.1.0 of nucleus server, the file name is “nucleus-stack-2022.1.0+tag-2022.1.0.gitlab.3983146.613004ac.tar.gz”.
By the way, I didn’t install the cache for which file name is “nucleus-cache-2022.1.0+tag-2022.1.0.gitlab.3983147.c11aebcf.tar.gz”.
Hi @frank_liu
Have you ever upload files from navigator? or web client? looks like there are already files uploaded to nucleus server
Hi @frank_liu
Please use “NVIDIA Omniverse Nucleus Tools”, to check the folder from terminal.
  1. Download Nucleus-Tools by command
$ docker pull nvcr.io/omniverse/prerel/nucleus-tools:1.0.0
  1. Execute command
$ sudo docker run <nucleus-tools-image-id> ls -r -pa -p <admin password> -u <admin username> <serverhost/IP> <Pathname> (for example /Projects/OVE-Demo/Models/)
  1. If you indeed find files which invisible from navigator UI under the folder, and you would like to delete it, please execute command
sudo docker run <nucleus-tools-image-id> rm --do-it -p <admin password> -u <admin username> <serverhost/IP> <Pathname> (for example /Projects/OVE-Demo/Models/test.png)
  1. Delete the folder from navigator again.
If you are encountering trouble with above steps, we can set a session via Microsoft Teams.
Hi @frankt ,
I was stuck at the docker pull command, I got the message bellow when I trying to pull the nucleus-tools:1.0.0 images.
$ sudo docker pull nvcr.io/omniverse/prerel/nucleus-tools:1.0.0
Error response from daemon: unauthorized: authentication required
I also tried to login NGC with my omniverse account, generated the key with Username $oauthtoken, and login nvcr.io with the given password, finally I’ve got the message bellow.
$ sudo docker login nvcr.io
Username: $oauthtoken
Password:
Login Succeeded
Error response from daemon: pull access denied for nvcr.io/omniverse/prerel/nucleus-tools, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied
Could you help me with the permission issue, please?
Hi @frank_liu
Shall we setup a session, kindly check the message box
1 have met the same problem,have you figure it out ?
+1 same problem here
Hi! Any update on the issue with the pulling nucleus docker tool image? I have the same issue as well.
@jun.tang7 , @rodolphe.assere @bastian.dose
Can you please tell me if you each have purchased Nucleus Enterprise or are within a company that purchased it?
I have a Nucleus Enterprise account with SOPRA STERIA company
Our company is registered for the DriveSim project, and we use Nucleus via that membership.
