Cannot download DriveOS 5.2.0 from SDK Manager
I can not access to DriveOS 5.2.0 from SDK Manager. I tried using --archived-versions flag. I tried older versions as well. Nothing worked.
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Dear @bgodeogl ,
Older releases were removed from sdkmanager. Can you use DRIVE OS 5.2.6 release?
We are using DRIVE OS 5.2.0 in our active operations. We need identical setup. If you could provide a link for 5.2.0, I can use SDK Manager offline mode.
Dear @bgodeogl ,
Do you have 5.2.0 installed on any host. If so, you can use the same host to flash target.
We are using 5.2.0 actively in operation. We prefer having those files locally for any case in the future. We can not spare a host PC for this purpose. Could you help?
You need a Ubuntu 18.04 host installed with DRIVE OS for flashing purpose. Hence I am checking if you have any host which was used to flash board. Please confirm this.
Currently, we removed DRIVE OS 5.2.0 for sdkmanager and needs to check internally on supporting this.
Same issue here, I tried an offline installation with a local copy of 5.2.0, but the sdkmanager just skips the install process completely on the device and reports finished successfully. Would be great to have 5.2.0 back we have some dependencies that are not working on 5.2.6.
