I failed to install the CUDA 5.5 for GTX 690. Very frustrating. The installer kept saying that it cannot find the compatible graphic hardware.
I also tried to install 4.0, all the others succeeded, but I cannot install the dev driver; Same error as 5.5, cannot find compatible graphic hardware.
You might need to uninstall any NVIDIA drivers already exisiting on your system and install the one directly from NVIDIA. You don’t need the dev driver, really, just a relatively current driver that is compatible with the CUDA toolkit you’re installing.
Could you please full clean the driver? Here below are steps.
1.Go to Device Manager → Display adapter → Select NVIDIA graphical card → Properties → Driver → Uninstall → Check the box “Delete the driver software for this device” → Click Ok
2. After driver is completed removed, click “Scan for hardware changes”. The native in box graphical driver will be installed. Click and expand Display adapter, make sure “Standard VGA Graphics Adapter” is present.
3. Install CUDA packages
4. Go to %systemDrive%\ProgramData\NVIDIA Corporation\CUDA Samples\v5.5\bin\win64\Release
5. Run sample named deviceQueryDrv.exe in cmd. If no error, it means CUDA driver is installed successfully.
6. Run sample named deviceQuery.exe in cmd. If no error, it means CUDA runtime is installed successfully.
The package “cuda_5.5.20_winvista_win7_win8_general_64.exe” can only be installed on desktop/workstation/server platform.
The package “cuda_5.5.20_winvista_win7_win8_notebook_64.exe” can only be installed on notebook platform.
