I’ve tried sudo /opt/nvidia/jetson-io/jetson-io.py and sudo python3
Nothing happens. I don’t get any error messages either.
What is your BSP/JP version?
Hi. I’m on r39.2. is this what you’re asking for?
Hi vishal42,
Are you using the developer kit? Could you connect it to a monitor and try running the command from a local terminal in the desktop environment?
Please let us know if the gray interface appears briefly and then disappears immediately. This issue has been reported in other forum posts.
Jose Morera
Embedded Software Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
That is actually how I’m using it. I’m using the Jetson Orin Nano Super Developer Kit. I have it connected to a monitor. I try running the command in a local terminal. However, there is no output and no interface appearing – not even briefly
Please dump the below commands results:
cat /etc/nv_tegra_release
cat /etc/nv_boot_control.conf
Hi, this is what I’m getting
eden@eden:~$ cat /etc/nv_tegra_release
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
eden@eden:~$ cat /etc/nv_boot_control.conf
TNSPEC 3767-300-0005-W.1-1-1-jetson-orin-nano-devkit-
COMPATIBLE_SPEC 3767–0005–1–jetson-orin-nano-devkit-
TEGRA_BOOT_STORAGE mmcblk0
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
eden@eden:~$
Hi vishal42,
You may find the following webpage helpful: Jetson-IO Not Working on Jetson Orin Nano, which discusses several possible causes of this behavior, along with troubleshooting steps and potential solutions.
Another thing worth trying is to reinstall the package:
sudo apt purge nvidia-jetson-io
sudo apt install nvidia-jetson-io
You can also refer to the Configuring the Jetson Expansion Headers section of the NVIDIA Jetson Linux Developer Guide for details on how the Jetson-IO tool is expected to work.
Hopefully this helps.
Jose Morera
We cannot reproduce the issue using our Orin Nano developer kit in r39.2.
Please try to reflash the device.
The same issue. I flashed device via USB, installed Jetpack 7.2. successfully. But, when run jetson-io in system terminal, application frame appears and instantly disappears. So I cant use my cameras and other io equipment out of the box. Temporary solved by changing FDT-overlay config manually to add inx219 camera there. Absolutely manual decision (I dont like that). I suspect its because of the board naming (jetson reference developer kit SUPER), so, thats why io tool doesnt run (because of super naming trick?) Anyway, would be nice if NVIDIA fix this issue for all native boards in the next JP release. If I change camera of add more input devices - I dont know jow to make them work normally… network camera in RJ slot also needed…
We suggest flashing the device using SDK Manager since the current Jetson ISO image has a known issue with jetson-io.py
SDK flashing failed from my PC. thats why I used to flash from USB image… So, maybe any patch anticipated? Or need to take another image for flashing from USB ?
When I try doing this, it says this system (the jetson orin nano devkit) does not meet the minimum requireents.
Memory space equal or larger than 8gb is recommenbded.
It was supposed to be just a warning. Please ignore it.
