Can't run jetson-io.py on my jetson nano dev kit
I’m trying to run the jetson-io.py file as part of the https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/hw_setup_jetson_can.html#wwpID0EOHA guide, but for some reason when I run the file it doesn’t show anything on the screen.
Some background information - I’m running 32.6.1
I’ve tried to create the init.py and init.py files in the jetson-io directory, no luck there.
Also tried to check the /boot/dtb folder and it;s not empty.
Any thoughts?
And on another note, is there a need for both MCP cards or can I use only one?
I’m trying to install all the ROS dependencies so this is the reason for trying to configure the canBus.
hello user153332,
did you install the Jetpack release via NVIDIA SDK Manager?
are you using this command to enable Jetson-IO? $ sudo python /opt/nvidia/jetson-io/jetson-io.py
