I am trying to enable YCbCr output on the Quadro P2000 card on Linux (buildroot) by setting the following option in xorg.conf:
Option “ColorSpace” “YCbCr444”
Option “ColorRange” “Limited”
I am using a DP->HDMI converter (4k capable) and HDMI->SDI converter that allows me to read the signal type. I tested both in 1080p as well as 2160p modes. Also, both converters report YCbCr support in the EDID (see XOrg log) and I can enable YCbCr in Windows (on the same system / cables / converter).
X.Org.log shows the following line:
Failed to set requested color space for ‘BMD Blackmagic’
Also, I can’t enable the color space in the nvidia-settings (button is disabled).
Find xorg.conf and Xorg.0.log below.
What could be the reason that YCbCr cannot be enabled?
Ultimately I would like to enable 30-bit mode as well, but I didn’t succeed with 24-bit neither. Any further information for that or should it work when Depth is set to 30. There is a note in the README that 30-bit is not supported in HDMI. Does that include conversion from DisplayPort? YCbCr422/10bit should work?
Thank you!
Marc
xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.25 (buildmeister@swio-display-x86-rhel47-03) Wed Jan 24 20:46:04 PST 2018
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
# VertRefresh 30.0
# 1920x1080 @ 30.00 Hz (GTF) hsync: 32.97 kHz; pclk: 80.18 MHz
#Modeline "1920x1080_30.00" 80.18 1920 1984 2176 2432 1080 1081 1084 1099 -HSync +Vsync
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "ModeValidation" "NoVesaModes, NoXServerModes"
Option "IgnoreEDIDChecksum" "DFP-6"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
Option "UseEdid" "True"
Option "ModeDebug" "True"
Option "ModeValidation" "AllowNonEdidModes"
Option "ColorSpace" "YCbCr444"
Option "ColorRange" "Limited"
EndSection
Section "Module"
Load "glx"
EndSection
Section "ServerFlags"
Option "BlankTime" "0"
Option "StandbyTime" "0"
Option "SuspendTime" "0"
Option "OffTime" "0"
EndSection
XOrg.0.log
[code][ 31.954]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 31.955] X Protocol Version 11, Revision 0
[ 31.955] Build Operating System: Linux 4.15.0-39-generic x86_64
[ 31.955] Current Operating System: Linux buildroot 4.14.67 #1 SMP Tue Sep 18 11:05:16 CEST 2018 x86_64
[ 31.955] Kernel command line: console=tty1 vt.handoff=7 fbcon=scrollback:128k root=/dev/nfs rw netdevwait nfsroot=192.168.96.41:/nfsroot/icore rootwait ip=dhcp nfsrootdebug nvidia-drm.modeset=1
[ 31.955] Build Date: 20 November 2018 04:35:33PM
[ 31.956]
[ 31.956] Current version of pixman: 0.34.0
[ 31.956] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 31.956] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 31.960] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Nov 30 06:19:26 2018
[ 31.996] (==) Using config file: “/etc/X11/xorg.conf”
[ 31.996] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 32.002] (==) ServerLayout “Layout0”
[ 32.002] () |–>Screen “Screen0” (0)
[ 32.002] () | |–>Monitor “Monitor0”
[ 32.004] () | |–>Device “Device0”
[ 32.004] () |–>Input Device “Keyboard0”
[ 32.004] () |–>Input Device “Mouse0”
[ 32.004] () Option “BlankTime” “0”
[ 32.004] () Option “StandbyTime” “0”
[ 32.004] () Option “SuspendTime” “0”
[ 32.004] () Option “OffTime” “0”
[ 32.004] (==) Automatically adding devices
[ 32.004] (==) Automatically enabling devices
[ 32.004] (==) Automatically adding GPU devices
[ 32.005] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 32.018] (WW) The directory “/usr/share/fonts/X11//TTF/” does not exist.
[ 32.018] Entry deleted from font path.
[ 32.022] (WW) The directory “/usr/share/fonts/X11//OTF/” does not exist.
[ 32.022] Entry deleted from font path.
[ 32.025] (WW) The directory “/usr/share/fonts/X11//Type1/” does not exist.
[ 32.025] Entry deleted from font path.
[ 32.031] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/X11//100dpi/". [ 32.031] Entry deleted from font path. [ 32.031] (Run 'mkfontdir' on "/usr/share/fonts/X11//100dpi/"). [ 32.036] (WW)
fonts.dir’ not found (or not valid) in “/usr/share/fonts/X11//75dpi/”.
[ 32.036] Entry deleted from font path.
[ 32.036] (Run ‘mkfontdir’ on “/usr/share/fonts/X11//75dpi/”).
[ 32.036] (==) FontPath set to:
/usr/share/fonts/X11//misc/
[ 32.036] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 32.036] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 32.036] (WW) Disabling Keyboard0
[ 32.036] (WW) Disabling Mouse0
[ 32.036] (II) Loader magic: 0x7f4b40
[ 32.036] (II) Module ABI versions:
[ 32.036] X.Org ANSI C Emulation: 0.4
[ 32.036] X.Org Video Driver: 23.0
[ 32.036] X.Org XInput driver : 24.1
[ 32.036] X.Org Server Extension : 10.0
[ 32.036] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 36.335] (–) PCI:*(0:4:0:0) 10de:1c30:10de:11b3 rev 161, Mem @ 0xf8000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/131072
[ 36.335] (II) Open ACPI successful (/var/run/acpid.socket)
[ 36.335] (II) LoadModule: “glx”
[ 36.342] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 36.720] (II) Module glx: vendor=“NVIDIA Corporation”
[ 36.720] compiled for 4.0.2, module version = 1.0.0
[ 36.720] Module class: X.Org Server Extension
[ 36.721] (II) NVIDIA GLX Module 390.87 Tue Aug 21 16:10:56 PDT 2018
[ 36.722] (II) LoadModule: “nvidia”
[ 36.778] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 36.812] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 36.812] compiled for 4.0.2, module version = 1.0.0
[ 36.813] Module class: X.Org Video Driver
[ 36.816] (II) NVIDIA dlloader X Driver 390.87 Tue Aug 21 15:44:49 PDT 2018
[ 36.816] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 36.818] (–) using VT number 2
[ 36.832] (II) Loading sub module “fb”
[ 36.832] (II) LoadModule: “fb”
[ 36.835] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 36.841] (II) Module fb: vendor=“X.Org Foundation”
[ 36.841] compiled for 1.19.6, module version = 1.0.0
[ 36.841] ABI class: X.Org ANSI C Emulation, version 0.4
[ 36.841] (II) Loading sub module “wfb”
[ 36.841] (II) LoadModule: “wfb”
[ 36.843] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 36.849] (II) Module wfb: vendor=“X.Org Foundation”
[ 36.849] compiled for 1.19.6, module version = 1.0.0
[ 36.849] ABI class: X.Org ANSI C Emulation, version 0.4
[ 36.849] (II) Loading sub module “ramdac”
[ 36.849] (II) LoadModule: “ramdac”
[ 36.849] (II) Module “ramdac” already built-in
[ 36.857] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 36.857] (==) NVIDIA(0): RGB weight 888
[ 36.857] (==) NVIDIA(0): Default visual is TrueColor
[ 36.857] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 36.858] () NVIDIA(0): Option “ColorSpace” “YCbCr444”
[ 36.858] () NVIDIA(0): Option “ColorRange” “Limited”
[ 36.858] () NVIDIA(0): Option “ModeValidation” “AllowNonEdidModes”
[ 36.858] () NVIDIA(0): Option “ModeDebug” “True”
[ 36.858] () NVIDIA(0): Option “UseEDID” “True”
[ 36.858] () NVIDIA(0): Option “IgnoreEDIDChecksum” “DFP-6”
[ 36.858] () NVIDIA(0): Enabling 2D acceleration
[ 36.867] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:4:0:0
[ 36.867] (–) NVIDIA(0): DFP-0
[ 36.867] (–) NVIDIA(0): DFP-1
[ 36.867] (–) NVIDIA(0): DFP-2
[ 36.867] (–) NVIDIA(0): DFP-3
[ 36.867] (–) NVIDIA(0): DFP-4
[ 36.867] (–) NVIDIA(0): DFP-5
[ 36.867] (–) NVIDIA(0): DFP-6 (boot)
[ 36.867] (–) NVIDIA(0): DFP-7
[ 36.871] (II) NVIDIA(0): NVIDIA GPU Quadro P2000 (GP106GL-A) at PCI:4:0:0 (GPU-0)
[ 36.871] (–) NVIDIA(0): Memory: 5242880 kBytes
[ 36.871] (–) NVIDIA(0): VideoBIOS: 86.06.3f.00.0d
[ 36.871] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 36.871] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 36.871] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 36.871] (–) NVIDIA(GPU-0): DFP-0 Name Aliases:
[ 36.871] (–) NVIDIA(GPU-0): DPY-0
[ 36.871] (–) NVIDIA(GPU-0): DP-0
[ 36.871] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 36.871] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 36.871] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 36.871] (–) NVIDIA(GPU-0): DFP-1 Name Aliases:
[ 36.871] (–) NVIDIA(GPU-0): DPY-1
[ 36.871] (–) NVIDIA(GPU-0): DP-1
[ 36.871] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 36.871] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 36.871] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 36.871] (–) NVIDIA(GPU-0): DFP-2 Name Aliases:
[ 36.871] (–) NVIDIA(GPU-0): DPY-2
[ 36.871] (–) NVIDIA(GPU-0): DP-2
[ 36.871] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 36.871] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 36.871] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 36.871] (–) NVIDIA(GPU-0): DFP-3 Name Aliases:
[ 36.871] (–) NVIDIA(GPU-0): DPY-3
[ 36.871] (–) NVIDIA(GPU-0): DP-3
[ 36.871] (–) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 36.872] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 36.872] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 36.872] (–) NVIDIA(GPU-0): DFP-4 Name Aliases:
[ 36.872] (–) NVIDIA(GPU-0): DPY-4
[ 36.872] (–) NVIDIA(GPU-0): DP-4
[ 36.872] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 36.872] (–) NVIDIA(GPU-0): DFP-5: disconnected
[ 36.872] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 36.872] (–) NVIDIA(GPU-0): DFP-5 Name Aliases:
[ 36.872] (–) NVIDIA(GPU-0): DPY-5
[ 36.872] (–) NVIDIA(GPU-0): DP-5
[ 36.872] (–) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 36.873] (–) NVIDIA(GPU-0): BMD Blackmagic (DFP-6): connected
[ 36.873] (–) NVIDIA(GPU-0): BMD Blackmagic (DFP-6): Internal DisplayPort
[ 36.873] (–) NVIDIA(GPU-0): BMD Blackmagic (DFP-6) Name Aliases:
[ 36.873] (–) NVIDIA(GPU-0): DFP
[ 36.873] (–) NVIDIA(GPU-0): DFP-6
[ 36.873] (–) NVIDIA(GPU-0): DPY-6
[ 36.873] (–) NVIDIA(GPU-0): DP-6
[ 36.873] (–) NVIDIA(GPU-0): DPY-EDID-6a6c7100-7611-b14e-fe1e-3782b97e8698
[ 36.873] (–) NVIDIA(GPU-0): BMD Blackmagic (DFP-6): 1440.0 MHz maximum pixel clock
[ 36.873] (–) NVIDIA(GPU-0): — EDID for BMD Blackmagic (DP-6) —
[ 36.873] (–) NVIDIA(GPU-0): EDID Version : 1.3
[ 36.873] (–) NVIDIA(GPU-0): Manufacturer : BMD
[ 36.873] (–) NVIDIA(GPU-0): Monitor Name : BMD Blackmagic
[ 36.873] (–) NVIDIA(GPU-0): Product ID : 0xbe0c
[ 36.873] (–) NVIDIA(GPU-0): 32-bit Serial Number : 0x00000000
[ 36.873] (–) NVIDIA(GPU-0): Serial Number String :
[ 36.873] (–) NVIDIA(GPU-0): Manufacture Date : 2012, week 52
[ 36.873] (–) NVIDIA(GPU-0): DPMS Capabilities :
[ 36.873] (–) NVIDIA(GPU-0): Input Type : Digital
[ 36.873] (–) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[ 36.873] (–) NVIDIA(GPU-0): Supports GTF : No
[ 36.873] (–) NVIDIA(GPU-0): Maximum Image Size : 0 mm x 0 mm
[ 36.873] (–) NVIDIA(GPU-0): Valid HSync Range : 15.0 kHz - 68.0 kHz
[ 36.873] (–) NVIDIA(GPU-0): Valid VRefresh Range : 23.0 Hz - 60.0 Hz
[ 36.873] (–) NVIDIA(GPU-0): EDID maximum pixel clock : 150.0 MHz
[ 36.873] (–) NVIDIA(GPU-0): CEA-861 extension block # : 0
[ 36.873] (–) NVIDIA(GPU-0): CEA-861 revision : 3
[ 36.873] (–) NVIDIA(GPU-0): IEEE Vendor Registration ID: 00-0c-03
[ 36.873] (–) NVIDIA(GPU-0): Supports YCbCr 4:4:4 : Yes
[ 36.873] (–) NVIDIA(GPU-0): Supports YCbCr 4:2:2 : Yes
[ 36.873] (–) NVIDIA(GPU-0): Supports Basic Audio : Yes
[ 36.873] (–) NVIDIA(GPU-0): Audio Descriptor : 0
[ 36.873] (–) NVIDIA(GPU-0): Audio Format : PCM
[ 36.873] (–) NVIDIA(GPU-0): Maximum Channels : 8
[ 36.873] (–) NVIDIA(GPU-0): Sample Rates : 48KHz
[ 36.873] (–) NVIDIA(GPU-0): Sample Sizes : 16-bits, 20-bits, 24-bits
[ 36.873] (–) NVIDIA(GPU-0): Speaker Allocation Data :
[ 36.873] (–) NVIDIA(GPU-0): Front Left + Front Right
[ 36.873] (–) NVIDIA(GPU-0): Low Frequency Effect
[ 36.873] (–) NVIDIA(GPU-0): Front Center
[ 36.873] (–) NVIDIA(GPU-0): Rear Left + Rear Right
[ 36.873] (–) NVIDIA(GPU-0): Front Left Center + Front Right Center
[ 36.873] (–) NVIDIA(GPU-0): Detailed Timings:
[ 36.873] (–) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 36.873] (–) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 36.873] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.873] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.873] (–) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.873] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 36.873] (–) NVIDIA(GPU-0): H/V Polarity : +/+
[ 36.873] (–) NVIDIA(GPU-0): Image Size : 708 mm x 398 mm
[ 36.873] (–) NVIDIA(GPU-0): RGB 444 bpcs : 8
[ 36.873] (–) NVIDIA(GPU-0): YUV 444 bpcs : 8
[ 36.873] (–) NVIDIA(GPU-0): YUV 422 bpcs : 8, 10, 12
[ 36.873] (–) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.873] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 36.873] (–) NVIDIA(GPU-0): Interlaced : yes
[ 36.873] (–) NVIDIA(GPU-0): Established Timings:
[ 36.873] (–) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 36.873] (–) NVIDIA(GPU-0): CEA-861B Timings:
[ 36.873] (–) NVIDIA(GPU-0): Pixel Clock : 148.35 MHz
[ 36.873] (–) NVIDIA(GPU-0): CEA Format : 16
[ 36.873] (–) NVIDIA(GPU-0): Aspect Ratio : 16:9
[ 36.873] (–) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[ 36.873] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 36.873] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 36.873] (–) NVIDIA(GPU-0): CEA Format : 31
[ 36.873] (–) NVIDIA(GPU-0): 1920 x 1080 @ 30 Hz
[ 36.873] (–) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.874] (–) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 36.874] (–) NVIDIA(GPU-0): H/V Polarity : +/+
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 34
[ 36.874] (–) NVIDIA(GPU-0): Aspect Ratio : 16:9
[ 36.874] (–) NVIDIA(GPU-0): RGB 444 bpcs : 8
[ 36.874] (–) NVIDIA(GPU-0): YUV 444 bpcs : 8
[ 36.874] (–) NVIDIA(GPU-0): YUV 422 bpcs : 8, 10, 12
[ 36.874] (–) NVIDIA(GPU-0): 1920 x 1080 @ 25 Hz
[ 36.874] (–) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 33
[ 36.874] (–) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[ 36.874] (–) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 32
[ 36.874] (–) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 36.874] (–) NVIDIA(GPU-0): Interlaced : yes
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 5
[ 36.874] (–) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 20
[ 36.874] (–) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 36.874] (–) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 4
[ 36.874] (–) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 19
[ 36.874] (–) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 36.874] (–) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[ 36.874] (–) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[ 36.874] (–) NVIDIA(GPU-0): H/V Polarity : -/-
[ 36.874] (–) NVIDIA(GPU-0): Aspect Ratio : 4:3
[ 36.874] (–) NVIDIA(GPU-0): 720 x 576 @ 50 Hz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 720, 732
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 796, 864
[ 36.874] (–) NVIDIA(GPU-0): VRes, VSyncStart : 576, 581
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 586, 625
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 17
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 18
[ 36.874] (–) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 36.874] (–) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 36.874] (–) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 36.874] (–) NVIDIA(GPU-0): CEA Format : 0
[ 36.874] (–) NVIDIA(GPU-0): Extension Block Detailed Timings:
[ 36.874] (–) NVIDIA(GPU-0): Image Size : 708 mm x 398 mm
[ 36.874] (–) NVIDIA(GPU-0): 1440 x 480 @ 60 Hz
[ 36.874] (–) NVIDIA(GPU-0): HRes, HSyncStart : 1440, 1478
[ 36.874] (–) NVIDIA(GPU-0): HSyncEnd, HTotal : 1602, 1716
[ 36.874] (–) NVIDIA(GPU-0): VRes, VSyncStart : 480, 488
[ 36.874] (–) NVIDIA(GPU-0): VSyncEnd, VTotal : 494, 524
[ 36.874] (–) NVIDIA(GPU-0): Image Size : 531 mm x 398 mm
[ 36.874] (–) NVIDIA(GPU-0): — End of EDID for BMD Blackmagic (DP-6) —
[ 36.874] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 36.874] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 09 a4 0c be 00 00 00 00
[ 36.874] (–) NVIDIA(GPU-0): 34 16 01 03 80 00 00 78 0a ee 91 a3 54 4c 99 26
[ 36.874] (–) NVIDIA(GPU-0): 0f 50 54 20 00 00 01 01 01 01 01 01 01 01 01 01
[ 36.874] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
[ 36.874] (–) NVIDIA(GPU-0): 45 00 c4 8e 21 00 00 1e 01 1d 80 18 71 1c 16 20
[ 36.874] (–) NVIDIA(GPU-0): 58 2c 25 00 c4 8e 21 00 00 9e 00 00 00 fc 00 42
[ 36.874] (–) NVIDIA(GPU-0): 6c 61 63 6b 6d 61 67 69 63 0a 20 20 00 00 00 fd
[ 36.874] (–) NVIDIA(GPU-0): 00 17 3c 0f 44 0f 00 0a 20 20 20 20 20 20 01 c3
[ 36.874] (–) NVIDIA(GPU-0): 02 03 28 71 52 90 1f 22 21 20 05 14 04 13 06 15
[ 36.874] (–) NVIDIA(GPU-0): 07 16 02 03 11 12 01 23 0f 04 07 83 2f 00 00 68
[ 36.874] (–) NVIDIA(GPU-0): 03 0c 00 10 00 00 1e 00 01 1d 00 72 51 d0 1e 20
[ 36.874] (–) NVIDIA(GPU-0): 6e 28 55 00 c4 8e 21 00 00 1e 8c 0a a0 14 51 f0
[ 36.874] (–) NVIDIA(GPU-0): 16 00 26 7c 43 00 13 8e 21 00 00 98 01 1d 80 d0
[ 36.874] (–) NVIDIA(GPU-0): 72 1c 16 20 10 2c 25 80 c4 8e 21 00 00 9e 01 1d
[ 36.874] (–) NVIDIA(GPU-0): 00 bc 52 d0 1e 20 b8 28 55 40 c4 8e 21 00 00 1e
[ 36.874] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2a
[ 36.876] (–) NVIDIA(GPU-0): DFP-7: disconnected
[ 36.876] (–) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 36.876] (–) NVIDIA(GPU-0): DFP-7 Name Aliases:
[ 36.876] (–) NVIDIA(GPU-0): DPY-7
[ 36.876] (–) NVIDIA(GPU-0): DP-7
[ 36.876] (–) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 36.876] (II) NVIDIA(GPU-0):
[ 36.876] (II) NVIDIA(GPU-0): — Building ModePool for BMD Blackmagic (DFP-6) —
[ 36.877] () NVIDIA(GPU-0): Mode Validation Overrides for BMD Blackmagic (DFP-6):
[ 36.877] () NVIDIA(GPU-0): AllowNonEdidModes
[ 36.877] (WW) NVIDIA(GPU-0): Failed to set requested color space for ‘BMD Blackmagic
[ 36.877] (WW) NVIDIA(GPU-0): (DFP-6)’.
[ 36.877] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_60”:
[ 36.877] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 36.877] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 36.877] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 36.877] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.877] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.877] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.877] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 36.877] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.877] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 36.877] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.877] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.877] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.877] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.877] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.877] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.877] (II) NVIDIA(GPU-0): Mode “1920x1080_60” is valid.
[ 36.877] (WW) NVIDIA(GPU-0): Validating Mode “1920x1080_60i”:
[ 36.877] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 36.877] (WW) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 36.877] (WW) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.877] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.877] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.877] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.877] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 36.877] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.877] (WW) NVIDIA(GPU-0): Extra : Interlace
[ 36.877] (WW) NVIDIA(GPU-0): Mode is rejected: Interlaced modes are not supported over
[ 36.877] (WW) NVIDIA(GPU-0): DisplayPort.
[ 36.877] (WW) NVIDIA(GPU-0): Mode “1920x1080_60i” is invalid.
[ 36.909] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_60”:
[ 36.909] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 36.909] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 36.909] (II) NVIDIA(GPU-0): Pixel Clock : 148.35 MHz
[ 36.909] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.909] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.909] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.909] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 36.909] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.909] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 36.909] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.909] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.909] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.909] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.909] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.909] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.909] (II) NVIDIA(GPU-0): Mode “1920x1080_60” is valid.
[ 36.909] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_50”:
[ 36.909] (II) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[ 36.909] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 36.909] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 36.909] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 36.910] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 36.910] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.910] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 36.910] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.910] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.910] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.910] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.910] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.910] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.910] (II) NVIDIA(GPU-0): Mode “1920x1080_50” is valid.
[ 36.910] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_30”:
[ 36.910] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 36.910] (II) NVIDIA(GPU-0): 1920 x 1080 @ 30 Hz
[ 36.910] (II) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 36.910] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.910] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.910] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.910] (II) NVIDIA(GPU-0): Mode “1920x1080_30” is valid.
[ 36.910] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_25”:
[ 36.910] (II) NVIDIA(GPU-0): 1920 x 1080 @ 25 Hz
[ 36.910] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.910] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 36.910] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 36.910] (II) NVIDIA(GPU-0): Mode “1920x1080_25” is valid.
[ 36.910] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_24”:
[ 36.910] (II) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[ 36.910] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[ 36.910] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[ 36.910] (II) NVIDIA(GPU-0): Mode “1920x1080_24” is valid.
[ 36.910] (WW) NVIDIA(GPU-0): Validating Mode “1920x1080_60i”:
[ 36.910] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 36.910] (WW) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 36.910] (WW) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 36.910] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 36.910] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 36.910] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.910] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 36.910] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.910] (WW) NVIDIA(GPU-0): Extra : Interlace
[ 36.910] (WW) NVIDIA(GPU-0): Mode is rejected: Interlaced modes are not supported over
[ 36.910] (WW) NVIDIA(GPU-0): DisplayPort.
[ 36.910] (WW) NVIDIA(GPU-0): Mode “1920x1080_60i” is invalid.
[ 36.910] (WW) NVIDIA(GPU-0): Validating Mode “1920x1080_50i”:
[ 36.910] (WW) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[ 36.910] (WW) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.911] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 36.911] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 36.911] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.911] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 36.911] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.911] (WW) NVIDIA(GPU-0): Extra : Interlace
[ 36.911] (WW) NVIDIA(GPU-0): Mode is rejected: Interlaced modes are not supported over
[ 36.911] (WW) NVIDIA(GPU-0): DisplayPort.
[ 36.911] (WW) NVIDIA(GPU-0): Mode “1920x1080_50i” is invalid.
[ 36.911] (II) NVIDIA(GPU-0): Validating Mode “1280x720_60”:
[ 36.911] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 36.911] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 36.911] (II) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 36.911] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 36.911] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 36.911] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 36.911] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 36.911] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.911] (II) NVIDIA(GPU-0): Viewport 1280x720+0+0
[ 36.911] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.911] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.911] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.911] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.911] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.911] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.911] (II) NVIDIA(GPU-0): Mode “1280x720_60” is valid.
[ 36.911] (II) NVIDIA(GPU-0): Validating Mode “1280x720_50”:
[ 36.911] (II) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[ 36.911] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.911] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[ 36.911] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[ 36.911] (II) NVIDIA(GPU-0): Mode “1280x720_50” is valid.
[ 36.911] (II) NVIDIA(GPU-0): Validating Mode “720x480_60”:
[ 36.911] (II) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 36.911] (II) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 36.911] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[ 36.911] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[ 36.911] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 36.911] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[ 36.911] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 36.911] (II) NVIDIA(GPU-0): Viewport 720x480+0+0
[ 36.911] (II) NVIDIA(GPU-0): Mode “720x480_60” is valid.
[ 36.912] (II) NVIDIA(GPU-0): Validating Mode “720x480_60”:
[ 36.912] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 36.912] (II) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 36.912] (II) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 36.912] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[ 36.912] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[ 36.912] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 36.912] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[ 36.912] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 36.912] (II) NVIDIA(GPU-0): Viewport 720x480+0+0
[ 36.912] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.912] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.912] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.912] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.912] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.912] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.912] (II) NVIDIA(GPU-0): Mode “720x480_60” is valid.
[ 36.912] (II) NVIDIA(GPU-0): Validating Mode “720x576_50”:
[ 36.912] (II) NVIDIA(GPU-0): 720 x 576 @ 50 Hz
[ 36.912] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 732
[ 36.912] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 796, 864
[ 36.912] (II) NVIDIA(GPU-0): VRes, VSyncStart : 576, 581
[ 36.912] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 586, 625
[ 36.912] (II) NVIDIA(GPU-0): Viewport 720x576+0+0
[ 36.912] (II) NVIDIA(GPU-0): Mode “720x576_50” is valid.
[ 36.913] (II) NVIDIA(GPU-0): Validating Mode “640x480_60”:
[ 36.913] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 36.913] (II) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 36.913] (II) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 36.913] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 36.913] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 36.913] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 36.913] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 36.913] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 36.913] (II) NVIDIA(GPU-0): Viewport 640x480+0+0
[ 36.913] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.913] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.913] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.913] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.913] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.913] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.913] (II) NVIDIA(GPU-0): Mode “640x480_60” is valid.
[ 36.913] (II) NVIDIA(GPU-0): Validating Mode “1280x720_60”:
[ 36.913] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 36.913] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.913] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 36.913] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 36.913] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 36.913] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 36.913] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.913] (II) NVIDIA(GPU-0): Viewport 1280x720+0+0
[ 36.913] (II) NVIDIA(GPU-0): Mode “1280x720_60” is valid.
[ 36.913] (WW) NVIDIA(GPU-0): Validating Mode “1440x480_60i”:
[ 36.913] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 36.913] (WW) NVIDIA(GPU-0): 1440 x 480 @ 60 Hz
[ 36.913] (WW) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 36.913] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1440, 1478
[ 36.913] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1602, 1716
[ 36.913] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 488
[ 36.913] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 494, 524
[ 36.913] (WW) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 36.913] (WW) NVIDIA(GPU-0): Extra : Interlace
[ 36.913] (WW) NVIDIA(GPU-0): Mode is rejected: Interlaced modes are not supported over
[ 36.913] (WW) NVIDIA(GPU-0): DisplayPort.
[ 36.913] (WW) NVIDIA(GPU-0): Mode “1440x480_60i” is invalid.
[ 36.913] (WW) NVIDIA(GPU-0): Validating Mode “1920x1080_50i”:
[ 36.913] (WW) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[ 36.913] (WW) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 36.913] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 36.913] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 36.913] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 36.913] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 36.913] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 36.913] (WW) NVIDIA(GPU-0): Mode “1920x1080_50i” is invalid.
[ 36.913] (II) NVIDIA(GPU-0): Validating Mode “1280x720_50”:
[ 36.913] (II) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[ 36.913] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[ 36.913] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[ 36.913] (II) NVIDIA(GPU-0): Mode “1280x720_50” is valid.
[ 36.914] (II) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 36.914] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 36.914] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 36.914] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 36.914] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 36.914] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 36.914] (II) NVIDIA(GPU-0): Viewport 640x480+0+0
[ 36.914] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 36.914] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 36.914] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 36.914] (II) NVIDIA(GPU-0): Base Depth 32
[ 36.914] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 36.914] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 36.914] (II) NVIDIA(GPU-0): Mode “640x480_60” is valid.
[ 36.914] (WW) NVIDIA(GPU-0): Validating Mode “640x350_85”:
[ 36.914] (WW) NVIDIA(GPU-0): Mode Source: VESA
[ 36.914] (WW) NVIDIA(GPU-0): 640 x 350 @ 85 Hz
[ 36.914] (WW) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 36.914] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[ 36.914] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[ 36.914] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 350, 382
[ 36.914] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 385, 445
[ 36.914] (WW) NVIDIA(GPU-0): Sync Polarity : +H -V
[ 36.914] (WW) NVIDIA(GPU-0): Mode is rejected: VertRefresh (85.080 Hz) out of range
[ 36.914] (WW) NVIDIA(GPU-0): (23.000-60.000 Hz).
[ 36.914] (WW) NVIDIA(GPU-0): Mode “640x350_85” is invalid.
[ 36.914] (WW) NVIDIA(GPU-0): Validating Mode “640x400_85”:
[ 36.914] (WW) NVIDIA(GPU-0): 640 x 400 @ 85 Hz
[ 36.914] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[ 36.914] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 445
[ 36.914] (WW) NVIDIA(GPU-0): Sync Polarity : -H +V
[ 36.914] (WW) NVIDIA(GPU-0): Mode “640x400_85” is invalid.
[ 36.914] (WW) NVIDIA(GPU-0): Validating Mode “720x400_85”:
[ 36.914] (WW) NVIDIA(GPU-0): 720 x 400 @ 85 Hz
[ 36.914] (WW) NVIDIA(GPU-0): Pixel Clock : 35.50 MHz
[ 36.914] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 720, 756
[ 36.914] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 828, 936
[ 36.914] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 446
[ 36.914] (WW) NVIDIA(GPU-0): Mode is rejected: VertRefresh (85.039 Hz) out of range
[ 36.914] (WW) NVIDIA(GPU-0): Mode “720x400_85” is invalid.
[ 36.914] (II) NVIDIA(GPU-0): Validating Mode “640x480_60”:
[ 36.914] (II) NVIDIA(GPU-0): Mode Source: VESA
[ 36.914] (II) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 36.914] (WW) NVIDIA(GPU-0): Validating Mode “640x480_73”:
[ 36.914] (WW) NVIDIA(GPU-0): 640 x 480 @ 73 Hz
[ 36.914] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 664
[ 36.914] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 704, 832
[ 36.914] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 36.914] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 520
[ 36.914] (WW) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 36.914] (WW) NVIDIA(GPU-0): Mode is rejected: VertRefresh (72.809 Hz) out of range
[ 36.914] (WW) NVIDIA(GPU-0): Mode “640x480_73” is invalid.
[ 36.914] (WW) NVIDIA(GPU-0): Validating Mode “640x480_75”:
[ 36.914] (WW) NVIDIA(GPU-0): 640 x 480 @ 75 Hz
[ 36.914] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 36.914] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 720, 840
[ 36.914] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 481
[ 36.914] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 500
[ 36.914] (WW) NVIDIA(GPU-0): Mode is rejected: VertRefresh (75.000 Hz) out of range
[ 36.914] (WW) NVIDIA(GPU-0): Mode “640x480_75” is invalid.
[ 36.914] (WW) NVIDIA(GPU-0): Validating Mode “640x480_85”:
[ 36.914] (WW) NVIDIA(GPU-0): 640 x 480 @ 85 Hz
[ 36.914] (WW) NVIDIA(GPU-0): Pixel Clock : 36.00 MHz
[ 36.914] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 696
[ 36.914] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 832
[ 36.914] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 509
[ 36.914] (WW) NVIDIA(GPU-0): Mode is rejected: VertRefresh (85.008 Hz) out of range
[ 36.914] (WW) NVIDIA(GPU-0): Mode “640x480_85” is invalid.
[ 36.914] (II) NVIDIA(GPU-0): Validating Mode “800x600_56”:
[ 36.914] (II) NVIDIA(GPU-0): 800 x 600 @ 56 Hz
[ 36.914] (II) NVIDIA(GPU-0): Pixel Clock : 36.00 MHz
[ 36.914] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 824
[ 36.914] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1024
[ 36.914] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[ 36.914] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 603, 625
[ 36.91
