Cannot unload Nvidia driver
Hello. When I tried to unload the nvidia driver, I removed nvidia_uvm ans nvidia_modeset sucessfully.
However. I could not remove nvidia module because it is used by drm module.
How should I do to unload driver correctly ?
Thank you for your help in advance.
We are moving to Linux forum for better help, thank you.
It’s the other way round, the nvidia module is using the drm module, so that’s not the blocker.
I’d rather guess you have some client running, locking the module. This might be either a display server (xorg/wayland) or simply the nvidia-persistenced daemon. Please check what keeps a hold onto the /dev nodes.
Thank you for your suggestion.
How could I do to check and unlock the client that keeps a hold onto the /dev nodes ?
i.e.: sudo lsof |grep "/dev/nvidia"
Excuse me. @generix @Mart This is the output results after I ran the command sudo lsof |grep “/dev/nvidia”. How should I do next ?
This is the first part of the results
nvidia-pe   37265                               root    2u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-pe   37265                               root    4u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-pe   37265                               root    6u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-pe   37265                               root    7u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-pe   37265                               root    8u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-pe   37265                               root    9u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-pe   37265                               root   10u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-pe   37265                               root   11u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-pe   37265                               root   12u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-pe   37265                               root   13u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-pe   37265                               root   14u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-pe   37265                               root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-pe   37265                               root   16u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-pe   37265                               root   17u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-pe   37265                               root   18u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-pe   37265                               root   19u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-pe   37265                               root   20u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848                               root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848                               root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848                               root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848                               root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848                               root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848                               root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848                               root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848                               root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848                               root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848                               root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848                               root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848                               root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848                               root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848                               root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848                               root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848                               root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848                               root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40929 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40929 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40929 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40929 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40929 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40929 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40929 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40929 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40929 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40929 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40929 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40929 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40929 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40929 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40929 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40929 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40929 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40930 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40930 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40930 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40930 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40930 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40930 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40930 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40930 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40930 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40930 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40930 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40930 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40930 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40930 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40930 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40930 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40930 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40931 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40931 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40931 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40931 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40931 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40931 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40931 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40931 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40931 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40931 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40931 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40931 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40931 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40931 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40931 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40931 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40931 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40932 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40932 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40932 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40932 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40932 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40932 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40932 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40932 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40932 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40932 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40932 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40932 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40932 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40932 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40932 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40932 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40932 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40933 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40933 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40933 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40933 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40933 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40933 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40933 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40933 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40933 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40933 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40933 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40933 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40933 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40933 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40933 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40933 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40933 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40934 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40934 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40934 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40934 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40934 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40934 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40934 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40934 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40934 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40934 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40934 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40934 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40934 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40934 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40934 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40934 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40934 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40935 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40935 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40935 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40935 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40935 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40935 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40935 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40935 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40935 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40935 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40935 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40935 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40935 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40935 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40935 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40935 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40935 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40936 cache_mgr             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40936 cache_mgr             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40936 cache_mgr             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40936 cache_mgr             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40936 cache_mgr             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40936 cache_mgr             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40936 cache_mgr             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40936 cache_mgr             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40936 cache_mgr             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40936 cache_mgr             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40936 cache_mgr             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40936 cache_mgr             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40936 cache_mgr             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40936 cache_mgr             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40936 cache_mgr             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40936 cache_mgr             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40936 cache_mgr             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40937 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40937 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40937 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40937 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40937 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40937 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40937 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40937 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40937 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40937 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40937 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40937 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40937 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40937 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40937 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40937 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40937 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40938 cache_mgr             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40938 cache_mgr             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40938 cache_mgr             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40938 cache_mgr             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40938 cache_mgr             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40938 cache_mgr             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40938 cache_mgr             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40938 cache_mgr             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40938 cache_mgr             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40938 cache_mgr             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40938 cache_mgr             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40938 cache_mgr             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40938 cache_mgr             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40938 cache_mgr             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40938 cache_mgr             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40938 cache_mgr             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40938 cache_mgr             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40940 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40940 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40940 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40940 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40940 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40940 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40940 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40940 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40940 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40940 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40940 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40940 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40940 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40940 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40940 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40940 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40940 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40941 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40941 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40941 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40941 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40941 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40941 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40941 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40941 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40941 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40941 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40941 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40941 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40941 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40941 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40941 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40941 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40941 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40942 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40942 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40942 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40942 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40942 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40942 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40942 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40942 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40942 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40942 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40942 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40942 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40942 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40942 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40942 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40942 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40942 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40943 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   40943 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40943 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40943 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40943 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40943 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40943 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40943 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40943 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40943 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40943 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40943 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40943 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   40943 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   40943 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   40943 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   40943 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52805 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   52805 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52805 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52805 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52805 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52805 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52805 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52805 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52805 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52805 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52805 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52805 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52805 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52805 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52805 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52805 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52805 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52806 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   52806 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52806 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52806 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52806 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52806 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52806 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52806 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52806 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52806 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52806 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52806 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52806 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52806 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52806 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52806 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52806 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52807 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   52807 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52807 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52807 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52807 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52807 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52807 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52807 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52807 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52807 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52807 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52807 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52807 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52807 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52807 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52807 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52807 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52808 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   52808 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52808 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52808 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52808 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52808 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52808 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52808 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52808 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52808 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52808 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52808 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52808 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   52808 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   52808 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   52808 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   52808 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   54357 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   54357 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   54357 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   54357 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   54357 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   54357 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   54357 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   54357 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   54357 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   54357 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   54357 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   54357 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   54357 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   54357 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   54357 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   54357 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   54357 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   73288 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848   73288 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   73288 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   73288 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   73288 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   73288 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   73288 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   73288 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   73288 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   73288 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   73288 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   73288 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   73288 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848   73288 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848   73288 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848   73288 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848   73288 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  197469 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848  197469 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  197469 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  197469 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  197469 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  197469 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  197469 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  197469 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  197469 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  197469 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  197469 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  197469 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  197469 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  197469 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  197469 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  197469 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  197469 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  371185 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848  371185 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  371185 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  371185 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  371185 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  371185 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  371185 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  371185 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  371185 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  371185 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  371185 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  371185 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  371185 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  371185 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  371185 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  371185 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  371185 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  718695 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848  718695 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  718695 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  718695 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  718695 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  718695 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  718695 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  718695 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  718695 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  718695 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  718695 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  718695 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  718695 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  718695 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  718695 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  718695 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  718695 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  729264 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848  729264 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  729264 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  729264 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  729264 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  729264 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  729264 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  729264 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  729264 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  729264 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  729264 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  729264 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  729264 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848  729264 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848  729264 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848  729264 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848  729264 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 1442127 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848 1442127 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 1442127 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 1442127 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 1442127 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 1442127 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 1442127 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 1442127 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 1442127 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 1442127 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 1442127 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 1442127 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 1442127 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 1442127 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 1442127 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 1442127 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 1442127 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 4072004 dcgm-expo             root    3u      CHR            195,255       0t0                205 /dev/nvidiactl
dcgm-expo   40848 4072004 dcgm-expo             root    7u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 4072004 dcgm-expo             root    8u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 4072004 dcgm-expo             root    9u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 4072004 dcgm-expo             root   10u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 4072004 dcgm-expo             root   11u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 4072004 dcgm-expo             root   12u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 4072004 dcgm-expo             root   13u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 4072004 dcgm-expo             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 4072004 dcgm-expo             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 4072004 dcgm-expo             root   16u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 4072004 dcgm-expo             root   17u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 4072004 dcgm-expo             root   18u      CHR              195,3       0t0                213 /dev/nvidia3
dcgm-expo   40848 4072004 dcgm-expo             root   19u      CHR              195,0       0t0                206 /dev/nvidia0
dcgm-expo   40848 4072004 dcgm-expo             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
dcgm-expo   40848 4072004 dcgm-expo             root   21u      CHR              195,2       0t0                212 /dev/nvidia2
dcgm-expo   40848 4072004 dcgm-expo             root   22u      CHR              195,3       0t0                213 /dev/nvidia3
This is the second part of the result
nvidia-de   41730                               root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730                               root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730                               root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730                               root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730                               root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730                               root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730                               root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730                               root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730                               root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730                               root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730                               root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730                               root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730                               root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730                               root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730                               root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730                               root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730                               root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41777 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41777 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41777 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41777 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41777 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41777 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41777 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41777 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41777 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41777 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41777 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41777 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41777 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41777 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41777 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41777 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41777 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41778 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41778 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41778 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41778 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41778 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41778 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41778 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41778 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41778 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41778 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41778 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41778 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41778 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41778 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41778 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41778 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41778 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41779 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41779 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41779 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41779 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41779 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41779 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41779 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41779 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41779 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41779 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41779 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41779 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41779 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41779 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41779 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41779 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41779 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41780 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41780 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41780 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41780 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41780 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41780 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41780 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41780 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41780 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41780 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41780 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41780 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41780 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41780 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41780 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41780 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41780 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41781 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41781 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41781 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41781 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41781 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41781 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41781 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41781 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41781 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41781 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41781 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41781 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41781 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41781 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41781 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41781 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41781 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41782 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41782 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41782 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41782 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41782 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41782 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41782 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41782 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41782 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41782 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41782 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41782 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41782 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41782 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41782 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41782 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41782 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41783 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41783 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41783 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41783 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41783 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41783 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41783 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41783 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41783 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41783 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41783 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41783 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41783 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41783 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41783 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41783 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41783 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41784 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41784 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41784 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41784 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41784 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41784 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41784 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41784 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41784 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41784 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41784 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41784 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41784 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41784 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41784 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41784 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41784 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41785 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730   41785 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41785 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41785 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41785 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41785 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41785 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41785 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41785 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41785 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730   41785 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41785 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41785 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730   41785 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41785 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730   41785 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730   41785 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730  177626 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730  177626 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730  177626 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730  177626 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730  177626 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730  177626 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730  177626 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730  177626 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730  177626 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730  177626 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730  177626 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730  177626 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730  177626 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730  177626 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730  177626 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730  177626 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730  177626 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 1875764 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 1875764 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 1875764 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 1875764 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 1875764 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 1875764 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 1875764 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 1875764 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 1875764 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 1875764 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 1875764 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 1875764 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 1875764 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 1875764 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 1875764 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 1875764 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 1875764 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2263897 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2263897 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2263897 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2263897 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2263897 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2263897 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2263897 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2263897 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2263897 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2263897 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2263897 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2263897 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2263897 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2263897 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2263897 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2263897 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2263897 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770913 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2770913 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770913 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770913 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770913 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770913 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770913 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770913 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770913 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770913 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770913 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770913 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770913 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770913 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770913 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770913 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770913 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770914 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2770914 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770914 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770914 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770914 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770914 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770914 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770914 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770914 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770914 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770914 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770914 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770914 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770914 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770914 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770914 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770914 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770915 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2770915 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770915 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770915 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770915 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770915 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770915 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770915 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770915 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770915 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2770915 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770915 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770915 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2770915 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770915 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2770915 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2770915 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2777597 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2777597 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2777597 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2777597 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2777597 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2777597 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2777597 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2777597 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2777597 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2777597 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2777597 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2777597 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2777597 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2777597 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2777597 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2777597 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2777597 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2791165 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2791165 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2791165 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2791165 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2791165 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2791165 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2791165 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2791165 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2791165 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2791165 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2791165 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2791165 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2791165 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2791165 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2791165 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2791165 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2791165 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2910761 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 2910761 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2910761 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2910761 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2910761 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2910761 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2910761 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2910761 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2910761 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2910761 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 2910761 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2910761 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2910761 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 2910761 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2910761 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 2910761 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 2910761 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3415341 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 3415341 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3415341 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3415341 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3415341 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3415341 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3415341 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3415341 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3415341 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3415341 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3415341 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3415341 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3415341 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3415341 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3415341 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3415341 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3415341 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3532325 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 3532325 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3532325 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3532325 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3532325 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3532325 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3532325 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3532325 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3532325 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3532325 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3532325 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3532325 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3532325 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3532325 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3532325 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3532325 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3532325 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3608937 nvidia-de             root   12u      CHR            195,255       0t0                205 /dev/nvidiactl
nvidia-de   41730 3608937 nvidia-de             root   13u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3608937 nvidia-de             root   14u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3608937 nvidia-de             root   15u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3608937 nvidia-de             root   16u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3608937 nvidia-de             root   17u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3608937 nvidia-de             root   18u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3608937 nvidia-de             root   20u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3608937 nvidia-de             root   21u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3608937 nvidia-de             root   22u      CHR              195,0       0t0                206 /dev/nvidia0
nvidia-de   41730 3608937 nvidia-de             root   23u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3608937 nvidia-de             root   24u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3608937 nvidia-de             root   25u      CHR              195,1       0t0                208 /dev/nvidia1
nvidia-de   41730 3608937 nvidia-de             root   26u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3608937 nvidia-de             root   27u      CHR              195,3       0t0                213 /dev/nvidia3
nvidia-de   41730 3608937 nvidia-de             root   28u      CHR              195,2       0t0                212 /dev/nvidia2
nvidia-de   41730 3608937 nvidia-de             root   29u      CHR              195,3       0t0                213 /dev/nvidia3
The application names are truncated but obviously many services are using the nvidia modules
nvidia-pe… is the nvidia-persistenced daemon, like said, dcgm-ex(porter) is for prometheus monitoring, nvidia-de(???) for whatever.
You should know what’s running on your system.
