Hi, SivaRamaKrishna.
Here is the log captured by minicom between a reboot command and the login prompt:
[code]
Ubuntu 16.04 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: nvidia
Password:
Last login: Tue Jul 4 07:40:39 UTC 2017 on ttyS0
Welcome to Ubuntu 16.04 LTS (GNU/Linux 4.9.131-rt93-tegra aarch64)
5 packages can be updated.
0 updates are security updates.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
applicable law.
Welcome to Drive Linux running on Ubuntu 16.04!
nvidia@tegra-ubuntu:~$ sudo reboot
Stopping Hypervisor initiated Shutdown Service…
[ OK ] Stopped target Timers.
Stopping Daemon for power management…
Stopping Session c1 of user nvidia.
Stopping NVPTP_SLAVE…
Starting Unattended Upgrades Shutdown…
[ OK ] Stopped target Graphical Interface.
Stopping Fan control daemon…
[ OK ] Stopped target Multi-User System.
Stopping crash report submission daemon…
Stopping LSB: Starts or stops the xinetd daemon…
Stopping LSB: automatic crash report generation…
Stopping GPS (Global Positioning System) Daemon…
Stopping Accounts Service…
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Make remote CUPS printers available locally…
[ OK ] Stopped target Host and Network Name Lookups.
Stopping Authenticate and Authorize Users to Run Privileged Tasks…
[ OK ] Stopped target RPC Port Mapper.
Stopping Regular background program processing daemon…
Unmounting RPC Pipe File System…
Stopping LSB: Set the CPU Frequency Scaling governor to “ondemand”…
Stopping Ubuntu FAN network setup…
Stopping User Manager for UID 1001…
Stopping dnsmasq - A lightweight DHCP and caching DNS server…
[ OK ] Stopped Daily Cleanup of Temporary Directories.
Stopping LSB: Set up cgroupfs mounts…
Stopping Light Display Manager…
Stopping LSB: Advanced IEEE 802.11 management daemon…
Stopping Session 1 of user nvidia.
Stopping Disk Manager…
Stopping Modem Manager…
Stopping mnand refresh daemon service…
Stopping oFono Mobile telephony stack…
Stopping nv_tos_daemon_service assi…torage TA with FS operations…
Stopping Manage, Install and Generate Color Profiles…
Stopping DRIVE OTA Service…
Stopping System Logging Service…
[ OK ] Stopped target Login Prompts.
Stopping Getty on tty1…
Stopping Serial Getty on ttyS0…
Stopping OpenBSD Secure Shell server…
Stopping LSB: Speech Dispatcher…
Stopping Bluetooth service…
[ OK ] Unmounted /run/user/1001/gvfs.
[ OK ] Stopped nv_tos_daemon_service assis… storage TA with FS operations…
[ OK ] Stopped Regular background program processing daemon.
[ OK ] Stopped Accounts Service.
[ OK ] Stopped oFono Mobile telephony stack.
[ OK ] Stopped GPS (Global Positioning System) Daemon.
[ OK ] Stopped Hypervisor initiated Shutdown Service.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped Modem Manager.
[ OK ] Stopped Authenticate and Authorize Users to Run Privileged Tasks.
[ OK ] Stopped Make remote CUPS printers available locally.
[ OK ] Stopped OpenBSD Secure Shell server.
[ OK ] Stopped Light Display Manager.
[ OK ] Stopped Fan control daemon.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped User Manager for UID 1001.
[ OK ] Stopped NVPTP_SLAVE.
[ OK ] Stopped mnand refresh daemon service.
[ OK ] Stopped Daemon for power management.
[ OK ] Stopped Bluetooth service.
[ OK ] Stopped Manage, Install and Generate Color Profiles.
[ OK ] Stopped Disk Manager.
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Unmounted RPC Pipe File System.
[ OK ] Stopped Ubuntu FAN network setup.
[ OK ] Stopped LSB: Set up cgroupfs mounts…
[ OK ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Stopped Session 1 of user nvidia.
[ OK ] Started Unattended Upgrades Shutdown.
[ OK ] Stopped LSB: automatic crash report generation.
[ OK ] Stopped LSB: Starts or stops the xinetd daemon…
[ OK ] Stopped LSB: Set the CPU Frequency Scaling governor to “ondemand”.
[ OK ] Stopped dnsmasq - A lightweight DHCP and caching DNS server.
[ OK ] Stopped LSB: Speech Dispatcher.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped /etc/rc.local Compatibility.
[ OK ] Stopped target Network is Online.
Stopping Network Name Resolution…
[ OK ] Removed slice system-getty.slice.
Stopping CUPS Scheduler…
Stopping Avahi mDNS/DNS-SD Stack…
Stopping D-Bus System Message Bus…
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped CUPS Scheduler.
[ OK ] Stopped Network Name Resolution.
[ OK ] Unmounted /ota/pkg_data.
[ OK ] Stopped DRIVE OTA Service.
[ OK ] Stopped target Network.
Stopping Network Service…
Stopping Raise network interfaces…
[ OK ] Stopped Network Service.
[ OK ] Stopped Raise network interfaces.
[ OK ] Stopped crash report submission daemon.
[ OK ] Stopped Session c1 of user nvidia.
[ OK ] Removed slice User Slice of nvidia.
Stopping Permit User Sessions…
Stopping Login Service…
[ OK ] Stopped Login Service.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped target Remote File Systems (Pre).
[ OK ] Stopped target NFS client services.
Stopping RPC bind portmap service…
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Sockets.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed Socket activation for snappy daemon.
[ OK ] Closed CUPS Scheduler.
[ OK ] Closed GPS (Global Positioning System) Daemon Sockets.
[ OK ] Closed Syslog Socket.
[ OK ] Stopped target Paths.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped target Slices.
[ OK ] Stopped target User and Group Name Lookups.
[ OK ] Removed slice User and Session Slice.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Stopped RPC bind portmap service.
[ OK ] Closed RPCbind Server Activation Socket.
[ OK ] Stopped target System Initialization.
[ OK ] Stopped Apply Kernel Variables.
Stopping Load/Save Random Seed…
Stopping Update UTMP about System Boot/Shutdown…
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped target Swap.
Stopping LSB: Mount persistent filesystem for AV…
[ OK ] Stopped target Encrypted Volumes.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Unmounted /storage.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped LSB: Mount persistent filesystem for AV…
[ OK ] Stopped target Local File Systems.
Unmounting /run/user/1001…
[ OK ] Unmounted /run/user/1001.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Create Static Device Nodes in /dev.
Stopping Monitoring of LVM2 mirrors… dmeventd or progress polling…
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Reached target Shutdown.
[ 119.850733] reboot: Restarting system
ÿÿ [ 122.139] Start VM0(Guest OS) to VM_STATE_REBOOT
ÿÿError 6 asserting resetfor 21 to the device 20!
Error 6 asserting resetfor 21 to the device 21!
Error 6 asserting resetfor 21 to the device 154!
Error 6 asserting resetfor 21 to the device 155!
ÿÿ [ 122.202] End VM0(Guest OS) to VM_STATE_REBOOT
ÿÿ[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.131-rt93-tegra (buildbrain@mobile-u64-3034) (gcc version 4.9.4 20150629 (prerelease) (Linaro GCC 4.9-2015.06) ) #1 SMP PREEMPT RT Fri May 3 22:51:05 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ff00000
[ 0.000000] OF: fdt: - 100000000 , 5e9800000
[ 0.000000] earlycon: uart8250 at MMIO32 0x000000000c280000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node generic_carveout, compatible id nvidia,generic_carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 512 MiB at 0x000000009fc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc6695a9000 s55424 r8192 d30592 u94208
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 6359724
[ 0.000000] Kernel command line: fbcon=map:9 aurixfw=AFW root=/dev/vblkdev0p1 gpt rootwait ip=off rw gpt console=ttyS0,115200n8 tegra_keep_boot_clocks cma=536870912 disable_android_paranoid_network sdhci_tegra.en_boot_part_access=1 tegraid=19.1.2.0.0 uid=1645207840800000003ff01c0 bl_debug_data=65536@0x7f80020000 earlycon=uart8250,mmio32,0x0c280000 console=ttyS0,115200n8 bl_prof_dataptr=2048@0x7f8ab47000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 14, 67108864 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 24794220K/25842688K available (11838K kernel code, 2238K rwdata, 4900K rodata, 5312K init, 866K bss, 524180K reserved, 524288K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c10000 ( 11840 KB)
[ 0.000000] .rodata : 0xffffff8008c10000 - 0xffffff80090e0000 ( 4928 KB)
[ 0.000000] .init : 0xffffff80090e0000 - 0xffffff8009610000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009610000 - 0xffffff800983f808 ( 2239 KB)
[ 0.000000] .bss : 0xffffff800983f808 - 0xffffff8009918068 ( 867 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf19a60000 ( 410 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc669800000 ( 26264 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000010] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000437] Console: colour dummy device 80x25
[ 0.155386] kmemleak: Kernel memory leak detector disabled
[ 0.155413] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.155415] pid_max: default: 32768 minimum: 301
[ 0.155763] Security Framework initialized
[ 0.156005] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.156010] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.160598] Unable to find CPU node for /cpus/cpu@6
[ 0.177321] /cpus/cpu-map/cluster3/core0: Can’t get CPU for leaf core
[ 0.180225] sched-energy: Sched-energy-costs installed from DT
[ 0.182488] ASID allocator initialised with 65536 entries
[ 0.236042] tegra-id: chipid=21917.
[ 0.237511] tegra-id: opt_subrevision=0.
[ 0.239191] Tegra Revision: A02 SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.241764] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/automotive/kernel-dts/e3550/tegra194-e3550-0001-b03-B-linux-driveav-vm1.dts
[ 0.249282] DTB Build time: May 4 2019 05:43:36
[ 0.314038] CPU1: Booted secondary processor [4e0f0040]
[ 0.366538] CPU2: Booted secondary processor [4e0f0040]
[ 0.416035] CPU3: Booted secondary processor [4e0f0040]
[ 0.468045] CPU4: Booted secondary processor [4e0f0040]
[ 0.520461] CPU5: Booted secondary processor [4e0f0040]
[ 0.525453] Brought up 6 CPUs
[ 0.537109] SMP: Total of 6 processors activated.
[ 0.538883] CPU features: detected feature: User Access Override
[ 0.541034] CPU features: detected feature: 32-bit EL0 Support
[ 0.545766] CPU: All CPU(s) started at EL1
[ 0.547464] alternatives: patching kernel code
[ 0.569970] devtmpfs: initialized
[ 0.590048] Initilizing CustomIPI irq domain
[ 0.592245] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.595926] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.604807] pinctrl core: initialized pinctrl subsystem
[ 0.607824] regulator-dummy: no parameters
[ 0.609524] Initializing plugin-manager
[ 0.611052] Plugin module not found
[ 0.612324] Plugin-manager not available
[ 0.614825] tegra_hv: adding ivc242: rx_base=ffffff8009980000 tx_base = ffffff8009980880 size=880 irq = 5 (450)
[ 0.618571] tegra_hv: added ivc242
[ 0.619857] tegra_hv: adding ivc243: rx_base=ffffff8009980880 tx_base = ffffff8009980000 size=880 irq = 6 (451)
[ 0.623504] tegra_hv: added ivc243
[ 0.624792] tegra_hv: adding ivc240: rx_base=ffffff8009990000 tx_base = ffffff8009990880 size=880 irq = 7 (452)
[ 0.628419] tegra_hv: added ivc240
[ 0.629697] tegra_hv: adding ivc241: rx_base=ffffff8009990880 tx_base = ffffff8009990000 size=880 irq = 8 (453)
[ 0.633340] tegra_hv: added ivc241
[ 0.634643] tegra_hv: adding ivc238: rx_base=ffffff80099a0000 tx_base = ffffff80099b8080 size=18080 irq = 9 (454)
[ 0.638635] tegra_hv: added ivc238
[ 0.640247] tegra_hv: adding ivc239: rx_base=ffffff80099b8080 tx_base = ffffff80099a0000 size=18080 irq = 10 (455)
[ 0.644207] tegra_hv: added ivc239
[ 0.645503] tegra_hv: adding ivc232: rx_base=ffffff8009a00000 tx_base = ffffff8009a18080 size=18080 irq = 11 (456)
[ 0.649473] tegra_hv: added ivc232
[ 0.650834] tegra_hv: adding ivc233: rx_base=ffffff8009a80000 tx_base = ffffff8009a98080 size=18080 irq = 12 (457)
[ 0.654654] tegra_hv: added ivc233
[ 0.655952] tegra_hv: adding ivc385: rx_base=ffffff8009b00000 tx_base = ffffff8009b00280 size=280 irq = 13 (458)
[ 0.659833] tegra_hv: added ivc385
[ 0.661158] tegra_hv: adding ivc13: rx_base=ffffff8009b10000 tx_base = ffffff8009b10100 size=100 irq = 14 (459)
[ 0.664934] tegra_hv: added ivc13
[ 0.666180] tegra_hv: adding ivc12: rx_base=ffffff8009b20000 tx_base = ffffff8009b20100 size=100 irq = 15 (460)
[ 0.670069] tegra_hv: added ivc12
[ 0.671391] tegra_hv: adding ivc11: rx_base=ffffff8009b30000 tx_base = ffffff8009b30100 size=100 irq = 16 (461)
[ 0.675266] tegra_hv: added ivc11
[ 0.676561] tegra_hv: adding ivc10: rx_base=ffffff8009b40000 tx_base = ffffff8009b40100 size=100 irq = 17 (462)
[ 0.680407] tegra_hv: added ivc10
[ 0.681699] tegra_hv: adding ivc9: rx_base=ffffff8009b50000 tx_base = ffffff8009b50100 size=100 irq = 18 (463)
[ 0.685616] tegra_hv: added ivc9
[ 0.686917] tegra_hv: adding ivc8: rx_base=ffffff8009b60000 tx_base = ffffff8009b60100 size=100 irq = 19 (464)
[ 0.690820] tegra_hv: added ivc8
[ 0.692067] tegra_hv: adding ivc7: rx_base=ffffff8009b70000 tx_base = ffffff8009b70100 size=100 irq = 20 (465)
[ 0.695970] tegra_hv: added ivc7
[ 0.697227] tegra_hv: adding ivc6: rx_base=ffffff8009b80000 tx_base = ffffff8009b80100 size=100 irq = 21 (466)
[ 0.701076] tegra_hv: added ivc6
[ 0.702319] tegra_hv: adding ivc5: rx_base=ffffff8009b90000 tx_base = ffffff8009b90100 size=100 irq = 22 (467)
[ 0.706126] tegra_hv: added ivc5
[ 0.707392] tegra_hv: adding ivc4: rx_base=ffffff8009ba0000 tx_base = ffffff8009ba0100 size=100 irq = 23 (468)
[ 0.711234] tegra_hv: added ivc4
[ 0.712492] tegra_hv: adding ivc3: rx_base=ffffff8009bb0000 tx_base = ffffff8009bb0100 size=100 irq = 24 (469)
[ 0.716343] tegra_hv: added ivc3
[ 0.717594] tegra_hv: adding ivc2: rx_base=ffffff8009bc0000 tx_base = ffffff8009bc0100 size=100 irq = 25 (470)
[ 0.721427] tegra_hv: added ivc2
[ 0.722671] tegra_hv: adding ivc1: rx_base=ffffff8009bd0000 tx_base = ffffff8009bd0100 size=100 irq = 26 (471)
[ 0.726501] tegra_hv: added ivc1
[ 0.727794] tegra_hv: adding ivc0: rx_base=ffffff8009be0000 tx_base = ffffff8009be0100 size=100 irq = 27 (472)
[ 0.731631] tegra_hv: added ivc0
[ 0.732813] tegra_hv: adding ivc56: rx_base=ffffff8009c00000 tx_base = ffffff8009c00880 size=880 irq = 28 (473)
[ 0.736638] tegra_hv: added ivc56
[ 0.737899] tegra_hv: adding ivc31: rx_base=ffffff8009c10000 tx_base = ffffff8009c10180 size=180 irq = 29 (474)
[ 0.741680] tegra_hv: added ivc31
[ 0.742967] tegra_hv: adding ivc30: rx_base=ffffff8009c20000 tx_base = ffffff8009c20480 size=480 irq = 30 (475)
[ 0.746759] tegra_hv: added ivc30
[ 0.748084] tegra_hv: adding ivc29: rx_base=ffffff8009c30000 tx_base = ffffff8009c30280 size=280 irq = 31 (476)
[ 0.751816] tegra_hv: added ivc29
[ 0.753116] tegra_hv: adding ivc28: rx_base=ffffff8009c40000 tx_base = ffffff8009c40180 size=180 irq = 32 (477)
[ 0.756978] tegra_hv: added ivc28
[ 0.758253] tegra_hv: adding ivc32: rx_base=ffffff8008030000 tx_base = ffffff8008030100 size=100 irq = 33 (478)
[ 0.762044] tegra_hv: added ivc32
[ 0.763344] tegra_hv: adding ivc110: rx_base=ffffff8008050000 tx_base = ffffff8008050100 size=100 irq = 34 (479)
[ 0.767549] tegra_hv: added ivc110
[ 0.769128] tegra_hv: adding ivc237: rx_base=ffffff800a000000 tx_base = ffffff800a001080 size=1080 irq = 35 (480)
[ 0.772945] tegra_hv: added ivc237
[ 0.774204] tegra_hv: adding ivc234: rx_base=ffffff800a010000 tx_base = ffffff800a050280 size=40280 irq = 36 (481)
[ 0.778089] tegra_hv: added ivc234
[ 0.779337] tegra_hv: adding ivc231: rx_base=ffffff800a0a0000 tx_base = ffffff800a0e0280 size=40280 irq = 37 (482)
[ 0.783157] tegra_hv: added ivc231
[ 0.784443] tegra_hv: adding ivc127: rx_base=ffffff800a130000 tx_base = ffffff800a131080 size=1080 irq = 38 (483)
[ 0.788089] tegra_hv: added ivc127
[ 0.789371] tegra_hv: adding ivc126: rx_base=ffffff800a140000 tx_base = ffffff800a180280 size=40280 irq = 39 (484)
[ 0.793983] tegra_hv: added ivc126
[ 0.795757] tegra_hv: adding ivc118: rx_base=ffffff800a1d0000 tx_base = ffffff800a1d0100 size=100 irq = 40 (485)
[ 0.800539] tegra_hv: added ivc118
[ 0.802116] tegra_hv: adding ivc107: rx_base=ffffff800a1e0000 tx_base = ffffff800a1e0100 size=100 irq = 41 (486)
[ 0.806912] tegra_hv: added ivc107
[ 0.808517] tegra_hv: adding ivc105: rx_base=ffffff800a1f0000 tx_base = ffffff800a1f0100 size=100 irq = 42 (487)
[ 0.813262] tegra_hv: added ivc105
[ 0.814846] tegra_hv: adding ivc104: rx_base=ffffff800a200000 tx_base = ffffff800a200100 size=100 irq = 43 (488)
[ 0.819753] tegra_hv: added ivc104
[ 0.821285] tegra_hv: adding ivc101: rx_base=ffffff800a210000 tx_base = ffffff800a250280 size=40280 irq = 44 (489)
[ 0.825022] tegra_hv: added ivc101
[ 0.826237] tegra_hv: adding ivc42: rx_base=ffffff800a2a0000 tx_base = ffffff800a2a1080 size=1080 irq = 45 (490)
[ 0.829841] tegra_hv: added ivc42
[ 0.831014] tegra_hv: adding ivc39: rx_base=ffffff800a2b0000 tx_base = ffffff800a2f0280 size=40280 irq = 46 (491)
[ 0.834586] tegra_hv: added ivc39
[ 0.835832] tegra_hv: adding ivc38: rx_base=ffffff800a340000 tx_base = ffffff800a380280 size=40280 irq = 47 (492)
[ 0.839354] tegra_hv: added ivc38
[ 0.840519] tegra_hv: adding ivc35: rx_base=ffffff800a3d0000 tx_base = ffffff800a410280 size=40280 irq = 48 (493)
[ 0.844093] tegra_hv: added ivc35
[ 0.845292] tegra_hv: adding ivc76: rx_base=ffffff8009940000 tx_base = ffffff8009954180 size=14180 irq = 49 (494)
[ 0.848355] tegra_hv: added ivc76
[ 0.849322] tegra_hv: added mempool 0: ipa=7f80200000 size=400000 peer=7
[ 0.851273] tegra_hv: added mempool 1: ipa=7f80600000 size=800000 peer=7
[ 0.853238] tegra_hv: added mempool 2: ipa=7f80e00000 size=10000 peer=7
[ 0.855153] tegra_hv: added mempool 3: ipa=7f81000000 size=400000 peer=6
[ 0.857153] tegra_hv: added mempool 5: ipa=7f81400000 size=40000 peer=9
[ 0.859079] tegra_hv: added mempool 6: ipa=7f81600000 size=800000 peer=10
[ 0.861079] tegra_hv: added mempool 7: ipa=7f81e00000 size=10000 peer=8
[ 0.862987] tegra_hv: added mempool 8: ipa=7f82000000 size=800000 peer=10
[ 0.865007] tegra_hv: added mempool 9: ipa=7f82800000 size=800000 peer=10
[ 0.866983] tegra_hv: added mempool 10: ipa=7f83000000 size=40000 peer=11
[ 0.868972] tegra_hv: added mempool 11: ipa=7f83040000 size=100000 peer=11
[ 0.870942] tegra_hv: added mempool 14: ipa=7f83200000 size=800000 peer=10
[ 0.872959] tegra_hv: added mempool 15: ipa=7f83a00000 size=1000000 peer=10
[ 0.875009] tegra_hv: added mempool 47: ipa=7f84a00000 size=40000 peer=6
[ 0.876963] tegra_hv: added mempool 48: ipa=7f84c00000 size=800000 peer=10
[ 0.878956] tegra_hv: added mempool 49: ipa=7f85400000 size=800000 peer=10
[ 0.880979] tegra_hv: added mempool 50: ipa=7f85c00000 size=800000 peer=10
[ 0.882968] tegra_hv: added mempool 52: ipa=7f86400000 size=800000 peer=10
[ 0.885028] tegra_hv: added mempool 53: ipa=7f86c00000 size=800000 peer=10
[ 0.887040] tegra_hv: added mempool 54: ipa=7f87400000 size=800000 peer=10
[ 0.889081] tegra_hv: added mempool 56: ipa=7f87c00000 size=800000 peer=10
[ 0.891074] tegra_hv: added mempool 57: ipa=7f88400000 size=800000 peer=10
[ 0.893103] tegra_hv: added mempool 60: ipa=7f88c00000 size=1000000 peer=10
[ 0.895139] tegra_hv: initialized
[ 0.896607] NET: Registered protocol family 16
[ 0.903133] pstore: using zlib compression
[ 0.905572] console [pstore-1] enabled
[ 0.906658] pstore: Registered ramoops as persistent store backend
[ 0.908493] ramoops: attached 0x200000@0xbfd00000, ecc: 0/0
[ 0.931141] bpmp: mail init ok
[ 0.933750] t19x-arm-smmu 12000000.iommu: found 2 SMMUs
[ 0.935406] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.937376] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.938887] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.940575] t19x-arm-smmu 12000000.iommu: stream indexing with 128 indices
[ 0.942673] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.945823] t19x-arm-smmu 12000000.iommu: 24 context banks (0 stage-2 only)
[ 0.947872] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.956609] vdso: 2 pages (1 code @ ffffff8008c17000, 1 data @ ffffff8009614000)
[ 0.958731] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.961779] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.964503] Registering BPMP clocks…
[ 0.965747] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.967536] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.969469] tegra_powergate_init: DONE
[ 0.970653] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/automotive/kernel-dts/e3550/tegra194-e3550-0001-b03-B-linux-driveav-vm1.dts
[ 0.976125] DTB Build time: May 4 2019 05:43:36
[ 0.979428] Tegra reboot handler registered.
[ 0.985527] iommu: Adding device 14180000.pcie to group 0
[ 0.988015] iommu: Adding device 14100000.pcie to group 1
[ 0.990502] iommu: Adding device 14160000.pcie to group 2
[ 0.993016] iommu: Adding device 2490000.ether_qos to group 3
[ 0.995501] iommu: Adding device c280000.serial to group 4
[ 0.997806] tegra-pmc c360000.pmc: create /sys/kernel/debug/PMC/boot-chain-type
[ 1.000127] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 1.001967] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 1.003812] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 1.005615] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.007193] tegra-pmc: PMC Prod config success
[ 1.008721] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 1.010875] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 1.012897] iommu: Adding device 3400000.sdhci to group 5
[ 1.014933] iommu: Adding device 3230000.spi to group 6
[ 1.016841] iommu: Adding device 3300000.spi to group 7
[ 1.019074] iommu: Adding device 3160000.i2c to group 8
[ 1.020821] iommu: Adding device c240000.i2c to group 9
[ 1.022618] iommu: Adding device 3180000.i2c to group 10
[ 1.024490] iommu: Adding device 3190000.i2c to group 11
[ 1.026417] iommu: Adding device 31b0000.i2c to group 12
[ 1.028319] iommu: Adding device 31c0000.i2c to group 13
[ 1.030158] iommu: Adding device c250000.i2c to group 14
[ 1.032022] iommu: Adding device 31e0000.i2c to group 15
[ 1.034197] iommu: Adding device rtcpu@bc00000 to group 16
[ 1.036823] iommu: Adding device 13e10000.host1x to group 17
[ 1.038845] iommu: Adding device 13e10000.host1x:ctx0 to group 18
[ 1.041286] iommu: Adding device 13e10000.host1x:ctx1 to group 19
[ 1.043678] iommu: Adding device 13e10000.host1x:ctx2 to group 20
[ 1.046040] iommu: Adding device 13e10000.host1x:ctx4 to group 21
[ 1.048577] iommu: Adding device 15340000.vic to group 22
[ 1.050740] iommu: Adding device 15380000.nvjpg to group 23
[ 1.052613] iommu: Adding device 15480000.nvdec to group 24
[ 1.054441] iommu: Adding device 15140000.nvdec1 to group 25
[ 1.056243] iommu: Adding device 154c0000.nvenc to group 26
[ 1.057900] iommu: Adding device 15a80000.nvenc1 to group 27
[ 1.059735] iommu: Adding device 15880000.nvdla0 to group 28
[ 1.061630] iommu: Adding device 158c0000.nvdla1 to group 29
[ 1.064036] iommu: Adding device 14800000.isp to group 30
[ 1.066022] iommu: Adding device 14b00000.isp-thi to group 31
[ 1.068126] iommu: Adding device 16000000.pva0 to group 32
[ 1.070130] iommu: Adding device 16800000.pva1 to group 33
[ 1.071943] iommu: Adding device c1a0000.aon to group 34
[ 1.074113] iommu: Adding device d000000.bpmp to group 35
[ 1.075747] bpmp d000000.bpmp: Found mempool with id 3
[ 1.077083] bpmp d000000.bpmp: ivm 0x0000007f81000000
[ 1.078685] bpmp: ping status is 0
[ 1.079783] bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
[ 1.265626] bpmp d000000.bpmp: probe ok
[ 1.267683] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.269402] iommu: Adding device smmu_test to group 36
[ 1.271764] mc: mapped MMIO address: 0xffffff800a5a0000 -> 0x2c10000
[ 1.273735] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c20000
[ 1.275569] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c30000
[ 1.277361] mc: mapped MMIO address: 0xffffff800a600000 -> 0x2c40000
[ 1.279156] mc: mapped MMIO address: 0xffffff800a620000 -> 0x2c50000
[ 1.280969] mc: mapped MMIO address: 0xffffff800a640000 -> 0x2b80000
[ 1.282755] mc: mapped MMIO address: 0xffffff800a660000 -> 0x2b90000
[ 1.284576] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2ba0000
[ 1.286346] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2bb0000
[ 1.288163] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x1700000
[ 1.289929] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x1710000
[ 1.291715] mc: mapped MMIO address: 0xffffff800a700000 -> 0x1720000
[ 1.293481] mc: mapped MMIO address: 0xffffff800a720000 -> 0x1730000
[ 1.295290] mc: mapped MMIO address: 0xffffff800a740000 -> 0x1740000
[ 1.297057] mc: mapped MMIO address: 0xffffff800a760000 -> 0x1750000
[ 1.298842] mc: mapped MMIO address: 0xffffff800a780000 -> 0x1760000
[ 1.300654] mc: mapped MMIO address: 0xffffff800a7a0000 -> 0x1770000
[ 1.302427] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 1.303895] mc-err: mcerr ops are set to t19x
[ 1.308802] iommu: Adding device 2600000.dma to group 37
[ 1.316359] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.326048] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.330471] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.332193] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.334644] iommu: Adding device 3550000.xudc to group 38
[ 1.336712] iommu: Adding device 3610000.xhci to group 39
[ 1.339752] arm64_ras arm64_ras: probed
[ 1.344708] ras_fhi_enable: FHI 486 enabled on CPU0
[ 1.346228] ras_fhi_enable: FHI 487 enabled on CPU1
[ 1.347771] ras_fhi_enable: FHI 488 enabled on CPU2
[ 1.349350] ras_fhi_enable: FHI 489 enabled on CPU3
[ 1.351625] ras_fhi_enable: FHI 490 enabled on CPU4
[ 1.353183] ras_fhi_enable: FHI 491 enabled on CPU5
[ 1.354742] carmel_ras_enable: RAS enabled on cpu0
[ 1.354895] carmel_ras_enable: RAS enabled on cpu1
[ 1.355054] carmel_ras_enable: RAS enabled on cpu2
[ 1.355208] carmel_ras_enable: RAS enabled on cpu3
[ 1.355350] carmel_ras_enable: RAS enabled on cpu4
[ 1.355481] carmel_ras_enable: RAS enabled on cpu5
[ 1.355562] carmel_ras carmel_ras: probed
[ 1.365887] vdd_otp: 5000 mV
[ 1.366930] vdd_dummy: 5000 mV
[ 1.368123] vdd_otp_1v8: 1800 mV
[ 1.369232] vdd_otp_3v3: 3300 mV
[ 1.370301] vdd_otp_1v2: 1200 mV
[ 1.373189] iommu: Adding device vse@15810000 to group 40
[ 1.375121] iommu: Adding device vse@15820000 to group 41
[ 1.376900] iommu: Adding device vse@15830000 to group 42
[ 1.378597] iommu: Adding device vse@15840000 to group 43
[ 1.388489] max929x_i2c_client_init: called
[ 1.391420] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.393448] SCSI subsystem initialized
[ 1.394629] usbcore: registered new interface driver usbfs
[ 1.396265] usbcore: registered new interface driver hub
[ 1.397850] usbcore: registered new device driver usb
[ 1.414869] random: fast init done
[ 1.420765] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.423463] max77620 4-003c: Backup battery charging support disabled
[ 1.426303] max77620-sd0: at 1000 mV
[ 1.428170] max77620-sd1: at 1800 mV
[ 1.430033] max77620-sd2: at 1800 mV
[ 1.431859] max77620-sd3: at 1800 mV
[ 1.433841] max77620-sd4: at 1100 mV
[ 1.435824] max77620-ldo0: at 800 mV
[ 1.437541] max77620-ldo1: at 2375 mV
[ 1.439202] max77620-ldo2: at 3300 mV
[ 1.619987] max77620-ldo3: at 3300 mV
[ 1.621798] max77620-ldo4: at 1587 mV
[ 1.623542] max77620-ldo5: at 3300 mV
[ 1.625334] max77620-ldo6: at 3300 mV
[ 1.627104] max77620-ldo7: at 1200 mV
[ 1.628860] max77620-ldo8: at 1800 mV
[ 1.630425] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.635673] i2c i2c-4: deserialize_i2c ret -22
[ 1.636979] i2c i2c-4: — message dump for debugging —
[ 1.638466] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.639955] i2c i2c-4: 0d
[ 1.640716] i2c i2c-4: ef
[ 1.641499] i2c i2c-4:
[ 1.642192] max77620 4-003c: Failed to sync masks in d
[ 1.644027] max77620 4-003c: max77620 probe successful
[ 1.646621] media: Linux media interface: v0.10
[ 1.648183] Linux video capture interface: v2.00
[ 1.651058] pps_core: LinuxPPS API ver. 1 registered
[ 1.652545] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.655293] PTP clock support registered
[ 1.658403] tegra_hv_wdt tegra_hv_wdt: id=32 irq=33 peer=8 num=1 size=128
[ 1.658553] tegra_hv_wdt tegra_hv_wdt: ivc channel ready
[ 1.665606] trusty trusty: trusty version: Built: 18:04:45 May 4 2019
[ 1.667679] trusty trusty: selected api version: 3 (requested 3)
[ 1.670992] usb0-vbus: 5000 mV
[ 1.672259] usb1-vbus: 5000 mV
[ 1.673418] usb2-vbus: 5000 mV
[ 1.676045] camchar: rtcpu character device driver loaded
[ 1.678735] clocksource: Switched to clocksource arch_sys_counter
[ 1.698900] VFS: Disk quotas dquot_6.6.0
[ 1.700088] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.702300] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.705031] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.707660] tegra-carveouts tegra-carveouts: generic-0 :dma coherent mem declare 0x00000000bff00000,1073741824
[ 1.710535] tegra-carveouts tegra-carveouts: assigned reserved memory node generic_carveout
[ 1.712990] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.713245] tegra-gpcdma 2600000.dma: GPC DMA driver register 20 channels
[ 1.717026] nvmap_page_pool_init: Total RAM pages: 6329627
[ 1.718704] nvmap_page_pool_init: nvmap page pool size: 791203 pages (3090 MB)
[ 1.720357] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.720395] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.720433] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.720580] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.720640] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type tj-therm
[ 1.720690] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 1.728672] la/ptsa driver initialized.
[ 1.728988] NET: Registered protocol family 2
[ 1.729780] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.730303] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 1.730778] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.730820] UDP hash table entries: 16384 (order: 9, 2097152 bytes)
[ 1.731077] UDP-Lite hash table entries: 16384 (order: 9, 2097152 bytes)
[ 1.731504] NET: Registered protocol family 1
[ 1.732169] RPC: Registered named UNIX socket transport module.
[ 1.732170] RPC: Registered udp transport module.
[ 1.732171] RPC: Registered tcp transport module.
[ 1.732172] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.732562] Unpacking initramfs…
[ 1.743017] Freeing initrd memory: 4768K
[ 1.754300] t194_init_regs: Host1x HW syncpt ram init disabled
[ 1.756693] host1x 13e10000.host1x: initialized
[ 1.757782] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.758646] audit: initializing netlink subsys (disabled)
[ 1.758678] audit: type=2000 audit(1.728:1): initialized
[ 1.759202] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.763436] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.764160] NFS: Registering the id_resolver key type
[ 1.764172] Key type id_resolver registered
[ 1.764173] Key type id_legacy registered
[ 1.764180] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.764201] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.764734] fuse init (API version 7.26)
[ 1.769514] NET: Registered protocol family 38
[ 1.769610] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[ 1.769614] io scheduler noop registered (default)
[ 1.769616] io scheduler deadline registered
[ 1.769777] io scheduler cfq registered
[ 1.789093] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.789738] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.790254] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.792332] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.792475] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=2090250, vi_iso_bw=3436125, max_bw=3436125
[ 1.796923] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.797630] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.798511] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.799182] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.800186] vhost-client 15340000.vic: initialized
[ 1.800819] vhost-client 15380000.nvjpg: initialized
[ 1.801451] vhost-client 15480000.nvdec: initialized
[ 1.802047] vhost-client 15140000.nvdec1: initialized
[ 1.802601] vhost-client 154c0000.nvenc: initialized
[ 1.803047] vhost-client 15a80000.nvenc1: initialized
[ 1.804014] vhost-client 15a00000.nvcsi: initialized
[ 1.806918] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.807175] scare-pigeon 14b00000.isp-thi: initialized
[ 1.811443] pva 16000000.pva0: initialized
[ 1.816824] pva 16800000.pva1: initialized
[ 1.821048] nvdla 15880000.nvdla0: initialized
[ 1.825393] nvdla 158c0000.nvdla1: initialized
[ 1.826799] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.827040] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.827046] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.827120] tegradccommon 15200000.dc_common: dma mapping done
[ 1.828493] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor
[ 1.828533] generic_infoframe_type: 0x87
[ 1.828624] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.828664] tegradc 15200000.nvdisplay: Display dc.ffffff800c2d0000 registered with id=0
[ 1.830549] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.831860] kfuse 3830000.kfuse: initialized
[ 1.832260] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.834103] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.834108] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.834110] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 356000000 Hz
[ 1.834328] console [ttyS0] disabled
[ 1.834641] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.834645] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.837519] tegradc 15200000.nvdisplay: hdmi: board prod-setting covers partial!
[ 1.842077] tegradc 15200000.nvdisplay: probed
[ 214551] tegradc 15200000.nvdisplay: fb registered
[ 2.214571] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.214595] c280000.serial: ttyS0 at MMIO 0xc280000 (irq = 92, base_baud = 25500000) is a Tegra
[ 2.214908] misc nvmap: created heap generic-0 base 0x00000000bff00000 size (1048576KiB)
[ 2.223348] console [ttyS0] enabled
[ 2.223708] gpio tegra-gpio wake60 for gpio=96(M:0)
[ 2.228286] bootconsole [uart8250] disabled
[ 2.233259] tegra_hv_vblk tegra_virt_storage0: allocate drvdata buffer
[ 2.236933] vblk: send_config wait for ivc channel reset
[ 2.238733] tegra_hv_vblk tegra_virt_storage0: send config cmd to ivc #127
[ 2.241028] tegra_hv_vblk tegra_virt_storage1: allocate drvdata buffer
[ 2.241324] tegra_hv_vblk tegra_virt_storage0: get config data from ivc #127
[ 2.245419] Primary GPT is invalid, using alternate GPT.
[ 2.246623] vblk: send_config wait for ivc channel reset
[ 2.249399] vblkdev0: p1
[ 2.254537] tegra_hv_vblk tegra_virt_storage1: send config cmd to ivc #237
[ 2.256545] tegra_hv_vblk tegra_virt_storage2: allocate drvdata buffer
[ 2.256636] tegra_hv_vblk tegra_virt_storage1: get config data from ivc #237
[ 2.263023] vblk: send_config wait for ivc channel reset
[ 2.264602] tegra_hv_vblk tegra_virt_storage2: send config cmd to ivc #42
[ 2.266616] tegra_hv_vblk tegra_virt_storage3: allocate drvdata buffer
[ 2.266713] tegra_hv_vblk tegra_virt_storage2: get config data from ivc #42
[ 2.272088] vblk: send_config wait for ivc channel reset
[ 2.273822] tegra_hv_vblk tegra_virt_storage: send config cmd to ivc #234
[ 2.427759] tegra_hv_vblk tegra_virt_storage4: allocate drvdata buffer
[ 2.427847] tegra_hv_vblk tegra_virt_storage3: get config data from ivc #234
[ 2.428137] tegra_hv_vblk tegra_virt_storage3: IVC frames 1 less than possible max requests 32!
[ 2.429716] vblk: send_config wait for ivc channel reset
[ 2.434513] tegra_hv_vblk tegra_virt_storage4: send config cmd to ivc #126
[ 2.434563] tegra_profiler: version: 1.129, samples/io: 44/25
[ 2.434637] tegra_hv_vblk tegra_virt_storage4: get config data from ivc #126
[ 2.434727] tegra_profiler: auth: init
[ 2.435013] tegra_hv_vblk tegra_virt_storage4: Setting Max requests to 16, consider increasing mempool size !
[ 2.435016] tegra_hv_vblk tegra_virt_storage4: IVC frames 1 less than possible max requests 16!
[ 2.436103] libphy: Fixed MDIO Bus: probed
[ 2.436211] tun: Universal TUN/TAP device driver, 1.6
[ 2.436212] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.436413] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 2.436414] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 2.436479] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.436480] igb: Copyright © 2007-2014 Intel Corporation.
[ 2.437078] eqos 2490000.ether_qos: no PHY interrupt found
[ 2.437081] eqos 2490000.ether_qos: no PHY reset gpio found
[ 2.440545] eqos 2490000.ether_qos: No prod values found
[ 2.441253] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb cf 31
[ 2.442535] PPP generic driver version 2.4.2
[ 2.442646] PPP BSD Compression module registered
[ 2.442648] PPP Deflate Compression module registered
[ 2.442661] PPP MPPE Compression module registered
[ 2.442663] NET: Registered protocol family 24
[ 2.442712] usbcore: registered new interface driver asix
[ 2.442759] usbcore: registered new interface driver ax88179_178a
[ 2.442792] usbcore: registered new interface driver cdc_ether
[ 2.442811] usbcore: registered new interface driver smsc95xx
[ 2.442822] usbcore: registered new interface driver net1080
[ 2.442834] usbcore: registered new interface driver cdc_subset
[ 2.442845] usbcore: registered new interface driver zaurus
[ 2.442864] usbcore: registered new interface driver cdc_ncm
[ 2.442992] tegra_hv_net tegra_hv_net@0: Reserved IVC channel #232 - frame_size=1536
[ 2.442996] tegra_hv_net tegra_hv_net@0: No valid mac-address found, using fixed local address
[ 2.448576] tegra_hv_net tegra_hv_net@0: ready
[ 2.448670] tegra_hv_net tegra_hv_net@1: Reserved IVC channel #233 - frame_size=1536[ 2.448673] tegra_hv_net tegra_hv_net@1: No valid mac-address found, using fixed local address
[ 2.450692] tegra_hv_net tegra_hv_net@1: ready
[ 2.455550] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 2.455552] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 2.458316] Could not get extcon-dev /xhci@3610000:id(0)
[ 2.461037] usbcore: registered new interface driver uas
[ 2.461083] usbcore: registered new interface driver usb-storage
[ 2.461602] mousedev: PS/2 mouse device common for all mice
[ 2.461664] usbcore: registered new interface driver xpad
[ 2.462118] i2c /dev entries driver
[ 2.463312] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 2.463463] gpio tegra-gpio wake36 for gpio=125(P:5)
[ 2.463877] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 2.464418] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 2.464888] isc-mgr isc-mgr.3: isc_mgr_probeing…
[ 2.465038] gpio tegra-gpio wake40 for gpio=129(Q:1)
[ 2.466130] usbcore: registered new interface driver uvcvideo
[ 2.466132] USB Video Class driver (1.1.1)
[ 2.466585] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.467869] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 2.468245] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
[ 2.471969] device-mapper: uevent: version 1.0.3
[ 2.472359] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.472842] sdhci: Secure Digital Host Controller Interface driver
[ 2.472843] sdhci: Copyright© Pierre Ossman
[ 2.472844] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.473416] sdhci-tegra 3400000.sdhci: runtime pm disabled
[ 2.473728] tegra_hv_vse vse@15810000: Virtual SE Stream ID: 72
[ 2.473731] tegra_hv_vse vse@15810000: Virtual SE channel number: 76
[ 2.475689] tegra_hv_vse vse@15820000: Virtual SE Stream ID: 72
[ 2.476264] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.480735] tegra_hv_vse vse@15830000: Virtual SE Stream ID: 72
[ 2.483114] tegra_hv_vse vse@15840000: Virtual SE Stream ID: 72
[ 2.484176] hidraw: raw HID events driver © Jiri Kosina
[ 2.484767] usbcore: registered new interface driver usbhid
[ 2.484768] usbhid: USB HID core driver
[ 2.486391] tegra186-cam-rtcpu rtcpu@bc00000: deferring, 14800000.isp is not probed
[ 2.488092] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.488438] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.488916] Denver: backdoor intrface is NOT available.
[ 2.488946] denver_knobs_init:MTS_VERSION:43227828
[ 2.489360] t19x_cache tegra-cache: probed
[ 2.490442] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,3145728
[ 2.490447] misc nvmap: created heap cvsram base 0x0000000050000000 size (3072KiB)
[ 2.493984] nvpmodel: initialized successfully
[ 2.499346] trusty-virtio trusty:virtio: initializing
[ 2.499834] trusty_ipc virtio0: vring0: va(pa) ffffffc64580e000(0) qsz 32 notifyid 1
[ 2.499881] trusty_ipc virtio0: vring1: va(pa) ffffffc645980000(0) qsz 32 notifyid 2
[ 2.500688] trusty-virtio trusty:virtio: initializing done
[ 2.500761] trusty_ipc virtio0: is online
[ 2.502483] tegra_hv_pm_ctl tegra_hv_pm_ctl: tegra_hv_pm_ctl_probe: Probed
[ 2.509597] GACT probability NOT on
[ 2.509605] Mirror/redirect action on
[ 2.509633] u32 classifier
[ 2.509634] Actions configured
[ 2.509638] Netfilter messages via NETLINK v0.30.
[ 2.510057] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 2.510227] ctnetlink v0.93: registering with nfnetlink.
[ 2.510658] xt_time: kernel timezone is -0000
[ 2.510665] IPVS: Registered protocols ()
[ 2.510711] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.510838] IPVS: Creating netns size=1744 id=0
[ 2.511614] IPVS: ipvs loaded.
[ 2.511673] gre: GRE over IPv4 demultiplexor driver
[ 2.512261] ip_tables: © 2000-2006 Netfilter Core Team
[ 2.512458] arp_tables: arp_tables: © 2002 David S. Miller
[ 2.512613] Initializing XFRM netlink socket
[ 2.512972] NET: Registered protocol family 10
[ 2.514151] mip6: Mobile IPv6
[ 2.514220] ip6_tables: © 2000-2006 Netfilter Core Team
[ 2.515406] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.515978] ip6_gre: GRE over IPv6 tunneling driver
[ 2.516257] NET: Registered protocol family 17
[ 2.516269] NET: Registered protocol family 15
[ 2.516302] 8021q: 802.1Q VLAN Support v1.8
[ 2.516326] Key type dns_resolver registered
[ 2.516607] Registered cp15_barrier emulation handler
[ 2.516671] Registered setend emulation handler
[ 2.518278] registered taskstats version 1
[ 2.521844] vhost-client 15c10000.vi: initialized
[ 2.526517] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.535674] vhost-client 14800000.isp: initialized
[ 2.542926] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 2.542928] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 2.545974] tegra-xusb 3610000.xhci: extcon 0: ffffffc64605b000 id
[ 2.546691] tegra186-cam-rtcpu rtcpu@bc00000: Trace buffer configured at IOVA=0xbff00000
[ 2.549493] tegra-xusb 3610000.xhci: Firmware timestamp: 2018-03-29 14:24:42 UTC, Version: 60.05 release
[ 2.549505] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 2.549548] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 2.550414] egra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 2.551262] tegra-xusb 3610000.xhci: irq 484, io mem 0x03610000
[ 2.551394] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.551396] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.551397] usb usb1: Product: xHCI Host Controller
[ 2.551399] usb usb1: Manufacturer: Linux 4.9.131-rt93-tegra xhci-hcd
[ 2.551400] usb usb1: SerialNumber: 3610000.xhci
[ 2.551932] hub 1-0:1.0: USB hub found
[ 2.551980] hub 1-0:1.0: 4 ports detected
[ 2.552424] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 2.552434] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 2.552439] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.552532] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.552534] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.552536] usb usb2: Product: xHCI Host Controller
[ 2.552537] usb usb2: Manufacturer: Linux 4.9.131-rt93-tegra xhci-hcd
[ 2.552539] usb usb2: SerialNumber: 3610000.xhci
[ 2.552815] hub 2-0:1.0: USB hub found
[ 2.552840] hub 2-0:1.0: 4 ports detected
[ 2.568526] mmc0: Switching to 1.8V signalling voltage failed
[ 2.576871] mmc0: new DDR MMC card at address 0001
[ 2.577425] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 2.577801] mmcblk0boot0: mmc0:0001 008G30 partition 1 8.00 MiB
[ 2.578097] mmcblk0boot1: mmc0:0001 008G30 partition 2 8.00 MiB
[ 2.578361] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB
[ 3.184663] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 3.186700] Extcon HDMI: HPD enabled
[ 3.187752] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.574512] tegra186-cam-rtcpu rtcpu@bc00000: command: 0x00000000: response timeout
[ 4.577251] tegra186-cam-rtcpu rtcpu@bc00000: rce full reset, retry 1/2
[ 4.862513] tegra-xusb 3610000.xhci: entering ELPG
[ 4.868565] tegra-xusb 3610000.xhci: entering ELPG done
[ 6.590551] tegra186-cam-rtcpu rtcpu@bc00000: command: 0x00000000: empty mailbox timeout
[ 6.593328] tegra186-cam-rtcpu rtcpu@bc00000: rce full reset, retry 2/2
[ 8.606507] tegra186-cam-rtcpu rtcpu@bc00000: command: 0x00000000: empty mailbox timeout
[ 8.610248] tegra-ivc ivc-rtcpu@bc00000: region 0: iova=0xbfec0000-0xbfedffff size=131072
[ 8.613473] tegra-ivc ivc-rtcpu@bc00000:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 8.617225] tegra-ivc ivc-rtcpu@bc00000:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 8.621122] tegra-ivc ivc-rtcpu@bc00000:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 8.625144] tegra-ivc ivc-rtcpu@bc00000:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 8.629118] tegra-ivc ivc-rtcpu@bc00000:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 8.633946] tegra186-cam-rtcpu rtcpu@bc00000: using cam RTCPU IRQ (106)
[ 8.636261] tegra186-cam-rtcpu rtcpu@bc00000: tegra_camrtc_mon_create is successful
[ 8.638888] tegra186-cam-rtcpu rtcpu@bc00000: fw version 0 has no sha1
[ 10.654511] tegra186-cam-rtcpu rtcpu@bc00000: command: 0x06bfec00: empty mailbox timeout
[ 10.657152] tegra-hsp-mailbox ivc-rtcpu@bc00000: IOVM setup error: 110
[ 10.659342] tegra186-cam-rtcpu rtcpu@bc00000: ivc-bus boot sync failed: -5
[ 10.661633] tegra186-cam-rtcpu rtcpu@bc00000: firmware version cpu=rce cmd=0 sha1=0000000000000000000000000000000000000000
[ 10.666853] hvc_sysfs: log is available
[ 10.668224] hvc_sysfs: pct is unavailable
[ 10.675720] usb0-vbus: disabling
[ 10.676904] usb2-vbus: disabling
[ 10.680099] Freeing unused kernel memory: 5312K
[ 10.694924] INITRAMFS STARTS
Getting target_board from device-tree …
[ 10.873098] EXT4-fs (vblkdev0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 10.877241] EXT4-fs (vblkdev0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 10.887257] EXT4-fs (vblkdev0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.951090] Trying chroot to /new_root
[ 10.952753] INITRAMFS END
[ 11.020248] systemd[1]: System time before build time, advancing clock.
[ 11.049793] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.055298] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.064220] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 11.071905] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 16.04 LTS!
[ 11.077962] systemd[1]: Set hostname to .
[ 11.102184] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.243696] systemd[1]: nv_drive_mods.service: Service lacks both ExecStart= and ExecStop= setting. Refusing.
[ 11.279908] systemd[1]: nv_drive_mods.service: Cannot add dependency job, ignoring: Unit nv_drive_mods.service is not loaded properly: Invalid argument.
[ 11.288660] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ OK ] Listening on Device-mapper event daemon FIFOs.
[ 11.294836] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 11.298828] systemd[1]: Reached target Encrypted Volumes.
[ OK ] Reached target Encrypted Volumes.
[ 11.302742] systemd[1]: Listening on LVM2 poll daemon socket.
[ OK ] Listening on LVM2 poll daemon socket.
[ 11.306997] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Swap.
[ OK ] Listening on LVM2 metadata daemon socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target User and Group Name Lookups.
[ OK ] Created slice System Slice.
Starting nv-run-date.service…
Starting Load Kernel Modules…
Starting Create list of required st… nodes for the current kernel…
[ OK ] Started Braille Device Support.
[ OK ] Reached target Slices.
Starting Set CPUs online[ 11.366508] usbcore: registered new interface driver rndis_host
service…
Mounting RPC Pipe File System…
[ 11.377816] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
Starting Monitoring of LVM2 mirr[ 11.383740] OF: PCI: host bridge /pcie@14180000 ranges:
ors… d[ 11.386195] OF: PCI: IO 0x38100000…0x381fffff -> 0x38100000
meventd [ 11.389140] OF: PCI: MEM 0x38200000…0x39ffffff -> 0x38200000
or progr[ 11.391894] OF: PCI: MEM 0x1800000000…0x1bffffffff -> 0x1800000000
ess polling…
Mounting POSIX Message Queue File System…
[ OK ] Listening on Journal Audit Socket.
Mounting Debug File System…
[ OK ] Listening on Journal Socket (/dev/log).
Starting Remount Root and Kernel File Systems…
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Journal Service…
[ OK ] Mounted RPC Pipe File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Started nv-run-date.service.
[ OK ] Started Create list of required sta…ce nodes for the current kernel.
[ OK ] Started Set CPUs online service.
[ OK ] Started Remount Root and Kernel File Systems.
[ 11.502562] tegra-pcie-dw 14180000.pcie: link is up
[ 11.505417] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 11.508243] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 11.510580] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 11.514589] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
[ 11.517447] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
[ OK ] Started LVM2 metadata daemon.
[ 11.526226] iommu: Adding device 0000:00:00.0 to group 44
Starting udev Coldplug all Devices…
[ 11.541547] iommu: Adding device 0000:01:00.0 to group 45
Starting Load/Save Random Seed…
[ 11.557507] iommu: Adding device 0000:01:00.1 to group 46
Starting Create Static Device Nodes in /dev…
[ 11.570960] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 11.590076] iommu: Adding device 0000:02:00.0 to group 47
[ 11.603953] iommu: Adding device 0000:02:01.0 to group 48
[ 11.607214] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 11.610907] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 11.626797] iommu: Adding device 0000:03:00.0 to group 49
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Static Device Nodes in /dev.
[ 11.646354] iommu: Adding device 0000:04:00.0 to group 50
Starting udev Kernel Device Manager…
[ 11.661906] pci 0000:00:00.0: BAR 15: assigned [mem 0x1800000000-0x1805ffffff 64bit pref]
[ 11.665314] pci 0000:00:00.0: BAR 14: assigned [mem 0x38200000-0x389fffff]
[ 11.668057] pci 0000:00:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 11.670617] pci 0000:01:00.1: BAR 4: assigned [mem 0x1800000000-0x1803ffffff 64bit pref]
[ 11.673891] pci 0000:01:00.1: BAR 0: assigned [mem 0x1804000000-0x18043fffff 64bit pref]
[ 11.677722] pci 0000:01:00.1: BAR 2: assigned [mem 0x1804400000-0x18047fffff 64bit pref]
[ 11.681756] pci 0000:01:00.0: BAR 14: assigned [mem 0x38200000-0x389fffff]
[ 11.684940] pci 0000:01:00.0: BAR 15: assigned [mem 0x1804800000-0x1804bfffff 64bit pref]
[ 11.688935] pci 0000:01:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 11.691832] pci 0000:02:00.0: BAR 14: assigned [mem 0x38200000-0x387fffff]
[ 11.695147] pci 0000:02:00.0: BAR 15: assigned [mem 0x1804800000-0x18049fffff 64bit pref]
[ 11.698686] pci 0000:02:01.0: BAR 14: assigned [mem 0x38800000-0x389fffff]
[ 11.701774] pci 0000:02:01.0: BAR 15: assigned [mem 0x1804a00000-0x1804bfffff 64bit pref]
[ 11.705510] pci 0000:02:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 11.708442] pci 0000:02:01.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 11.711461] pci 0000:03:00.0: BAR 4: assigned [mem 0x38400000-0x387fffff 64bit]
[ 11.715144] pci 0000:03:00.0: BAR 6: assigned [mem 0x38200000-0x3823ffff pref]
[ 11.718692] pci 0000:03:00.0: BAR 0: assigned [mem 0x38240000-0x3824ffff 64bit]
[ 11.722392] pci 0000:03:00.0: BAR 2: assigned [mem 0x38250000-0x38250fff 64bit]
[ 11.725814] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 11.728160] pci 0000:02:00.0: bridge window [io 0x1000-0x1fff]
[ 11.730977] pci 0000:02:00.0: bridge window [mem 0x38200000-0x387fffff]
[ 11.734187] pci 0000:02:00.0: bridge window [mem 0x1804800000-0x18049fffff 64bit pref]
[ 11.738550] pci 0000:04:00.0: BAR 2: assigned [mem 0x38800000-0x3883ffff 64bit]
[ 11.742330] pci 0000:04:00.0: BAR 0: assigned [mem 0x38840000-0x3885ffff 64bit]
[ 11.746077] pci 0000:04:00.0: BAR 6: assigned [mem 0x38860000-0x3886ffff pref]
[ 11.749583] pci 0000:02:01.0: PCI bridge to [bus 04]
[ 11.752113] pci 0000:02:01.0: bridge window [io 0x2000-0x2fff]
[ 11.755165] pci 0000:02:01.0: bridge window [mem 0x38800000-0x389fffff]
[ 11.758702] pci 0000:02:01.0: bridge window [mem 0x1804a00000-0x1804bfffff 64bit pref]
[ 11.762958] pci 0000:01:00.0: PCI bridge to [bus 02-04]
[ 11.765587] pci 0000:01:00.0: bridge window [io 0x1000-0x2fff]
[ 11.768630] pci 0000:01:00.0: bridge window [mem 0x38200000-0x389fffff]
[ OK 11.772954] pci 0000:01:00.0: bridge window [mem 0x1804800000-0x1804bfffff 64bit pref]
m[ 11.777187] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 11.779769] pci 0000:00:00.0: bridge window [io 0x1000-0x2fff]
] Starte[ 11.782207] pci 0000:00:00.0: bridge window [mem 0x38200000-0x389fffff]
d udev Kernel De[ 11.785403] pci 0000:00:00.0: bridge window [mem 0x1800000000-0x1805ffffff 64bit pref]
vice Manager.
[ 11.789111] pci 0000:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 11.793351] pci 0000:01:00.0: Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128
[ 11.797181] pci 0000:02:00.0: Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128
[ 11.800935] pci 0000:03:00.0: Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512
[ 11.804554] pci 0000:02:01.0: Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128
[ 11.808144] pci 0000:04:00.0: Max Payload Size set to 128/4096 (was 128), Max Read Rq 512
[ 11.811655] pci 0000:01:00.1: Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512
[ 11.822902] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 11.826009] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 11.828951] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 11.831780] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 11.834192] pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
[ 11.836899] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 11.839415] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 11.852520] pcieport 0000:01:00.0: enabling device (0000 -> 0003)
[ 11.868321] pcieport 0000:02:00.0: enabling device (0000 -> 0003)
[ 11.895353] pcieport 0000:02:01.0: enabling device (0000 -> 0003)
[ 11.923628] atlantic 0000:03:00.0: enabling device (0000 -> 0002)
[ 11.927674] switchtec 0000:01:00.1: enabling device (0000 -> 0002)
[ 11.947400] switchtec switchtec0: Management device registered.
[ 11.954370] switchtec: loaded.
[ 12.225953] switchtec switchtec0: NTB device registered
[ OK ] Started Monitoring of LVM2 mirrors,…ng dmeventd or progress polling.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Clean up any mess left by 0dns-up…
Starting Set console keymap…
Starting LSB: AppArmor initialization…
[ 12.592149] mvsas 0000:04:00.0: mvsas: driver version 0.8.16
[ 12.594612] mvsas 0000:04:00.0: enabling device (0000 -> 0002)
[ 12.598782] mvsas 0000:04:00.0: mvsas: PCI-E x4, Bandwidth Usage: 5.0 Gbps
Starting Preprocess NFS configuration…
[ 12.793476] ran
