Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
[*] other
Could you please explain why you need to control SOC_GPIO32 (GPIO3_PS.07)? Additionally, could you provide the source of the image you shared? Specifically, which Excel file is it from? Also, please share your DRIVE OS version by running the following command:
It’s in our hardware manual。
I found that there are some similar GPIO problems in our forum but not same as my case ,I’m not sure it’s pinmux error or something else,Can you give me some idea of what to look for。
thanks !
Is the hardware manual from NVIDIA? If so, could you specify which manual you’re referring to? Were the GPIO problems you mentioned discussed in this forum? If yes, could you provide the links to those topics?
For issues related to pinmux or other hardware configurations within the PDK scope, it’s best to reach out to your NVIDIA representative to ensure you’re directed to the appropriate support channels.
