Can't get Waveshare MCP2515 HAT to work on my Jetson Nano
Hi!
I’m struggling to get the following Hat to work with my Jetson Nano Development Board:
I tried to follow this guide on my current Setup, which looks like this:
NVIDIA Jetson Nano Development Kit B01
Jetpack 4.6.1
L4T 32.7.1
The OS is running on an SSD connected via USB3
I made the following changes to the provided jetson-mcp251x.dts:
fragment@0 {
clock-frequency = <8000000>;
fragment@1 {
interrupts = <&gpio HDR40_PIN29_GPIO 0x1>;
because the Clock of the Hat is 8Mhz and the Interrupt PIN on the 40-Pin Header is 29.
The dts wouldn’t Build on this Setup and exited with the following error:
tba@linux:~/tri/Linux_for_Tegra/source/public/kernel/kernel-4.9$ make ARCH=arm64 tegra_defconfig
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
tba@linux:~/tri/Linux_for_Tegra/source/public/kernel/kernel-4.9$ make ARCH=arm64 dtbs
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     scripts/mod/devicetable-offsets.h
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00-auo-1080p-edp.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-android-devkit.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-imx274-dp-hdmi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-base-p2595-0000-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-p2595-0000-a00-00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit_as_TM660M.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-as-p3448-0003.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00-hdmi-dsi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdmi-dsi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-hdmi-dsi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr40.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-sph0645lm4h.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-uda1334a.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-fe-pi-audio.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-respeaker-4-mic-array.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-respeaker-4-mic-lin-array.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-m2ke.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-csi.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr30.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-adafruit-sph0645lm4h.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-adafruit-sph0645lm4h.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-adafruit-uda1334a.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-adafruit-uda1334a.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-fe-pi-audio.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-fe-pi-audio.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-hdr40.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdr40.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-respeaker-4-mic-array.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-respeaker-4-mic-array.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-respeaker-4-mic-lin-array.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-respeaker-4-mic-lin-array.dtbo
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo
ERROR (duplicate_label): Duplicate label 'jetson_io_pinmux' on /fragment@3/__overlay__/header-40pin-pinmux and /fragment@2/__overlay__/exp-header-pinmux
ERROR: Input tree has errors, aborting (use -f to force output)
arch/arm64/boot/dts/Makefile:133: recipe for target 'arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo' failed
make[1]: *** [arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo] Error 2
arch/arm64/Makefile:154: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
To make sure the Build error does not come from the newer Jetpack or my System Setup, i switched to the same Setup as the Author of the guide and installed a fresh copy of Jetpack 4.6 to an SD-Card and i did not make any Changes to this Setup except of Setting up my Network.
So this new Setup looks like this:
Jetpack 4.6
L4T 32.6.1
As before i followed the guide, edited the dts to my needs and this time the dts would build, though the filename differs for some Reason:
Filename in the Guide: tegra210-p3348-0003-p3542-0000-mcp251x.dtbo
Filename on my System after Build: tegra210-p3448-0003-p3542-0000-mcp251x.dtbo
But the jetson-io.py Tool gave me the following error when trying to configure mcp251x :
 |                            FATAL ERROR!                            |
 |                 Failed to get pin number for node                  |
 |        /fragment@2/__overlay__/header-40pin-pinmux/pin37/!         |
 |                     Press any key to terminate                     |
Did i miss anything?
I also tried the guide at the End of this Thread, but did not have any luck with that one either.
Any help would be greatly appreciated.
Thank You
Timo
Please refer to below thread to see if can gain some ideas:
CAN with Jetson Nano Production Module - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
@kayccc Thank you, i will check the thread and post updates here!
Unfortunately, the link did not help me, as i am already on Jetpack 4.6.1. Any other hints/ideas?
Thank you
Timo
I finally got it working on Jetpack 4.6.1. Unfortunately, the Main problem was bad wiring.
Here is what I did to get it working, in case it’s of use for anyone else using the Waveshare CAN Hat for the NVIDIA Jetson Nano:
I mostly followed this guide to build the DTBO File:
My changes to this guide are the following:
  1. I edited the dtbs provided in this post to work with the Waveshare HAT, which is attached here:
    jetson-waveshare-mcp251x.dts (3.8 KB)
  2. I did not delete any files in the /boot folder
  3. I did not use jetson-io, because it won’t work on my system for some reason. Instead after Bulding the dtbo and copying it to /boot/, i found out that there is a more convenient way to load the dtbo for my use case. One can simply edit the extlinux.conf in /boot/extlinux/ and add the following line:
    FDTOVERLAYS /boot/jetson-waveshare-mcp251x.dtbo
After a reboot everything worked as expected.
Thanks for the help
Timo
