Hi guys, can anyone help me build my device tree overlay for the following product :
Currently i use this device tree overlay
// SPDX-License-Identifier: GPL-2.0-only
* Jetson Device-tree overlay for
* MCP2515
* Copyright (c) 2020 Seeed Technology Co,Ltd - https://www.seeed.cc.
* All rights reserved.
/dts-v1/;
/plugin/;
#include <dt-bindings/pinctrl/pinctrl-tegra.h>
#include <dt-bindings/gpio/tegra-gpio.h>
overlay-name = "MCP251x CAN Controller";
jetson-header-name = "Jetson 40pin Header";
compatible = "nvidia,p3449-0000-b00+p3448-0000-b00\0nvidia,p3449-0000-a02+p3448-0000-a02";
fragment@0 {
target-path = "/";
__overlay__ {
clocks {
can_clock: can_clock {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <8000000>;
clock-accuracy = <100>;
fragment@1 {
target = <&spi0>;
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
spi@0 {
status = "okay";
compatible = "microchip,mcp2515";
reg = <0x0>;
spi-max-frequency = <10000000>;
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x7>;
clocks = <&can_clock>;
interrupt-parent = <&gpio>;
interrupts = <TEGRA_GPIO(DD, 0) 0x1>;
controller-data {
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
nvidia,tx-clk-tap-delay = <0x0>;
spi@1 {
status = "disabled";
fragment@2 {
target = <&spi1>;
__overlay__ {
#size-cells = <0>;
spi@0 {
spi@1 {
status = "okay";
reg = <0x0>;
interrupts = <TEGRA_GPIO(V, 0) 0x1>;
controller-data {
fragment@3 {
target = <&pinmux>;
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&jetson_io_pinmux>;
jetson_io_pinmux: exp-header-pinmux {
hdr40-pin19 {
nvidia,pins = "spi1_mosi_pc0";
nvidia,function = "spi1";
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
hdr40-pin21 {
nvidia,pins = "spi1_miso_pc1";
hdr40-pin23 {
nvidia,pins = "spi1_sck_pc2";
hdr40-pin24 {
nvidia,pins = "spi1_cs0_pc3";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
and I can get the can0 up with:
sudo ip link set can0 up type can bitrate 500000
but i cannot send or receive any messages at all. Please help. I have the B01 version with 4 Gb
I have followed the steps from here
