Can't install Digits correctly on TX2
I tried to install the Digits recently, but I failed.
Environments:
JetPack 3.3.1
ubuntu16.04
After I flashed the TX2 I just executed:
sudo apt update
sudo apt upgrade
Then I executed without doing any other things:
sudo apt install --no-install-recommends git graphviz python-dev python-flask python-flaskext.wtf python-gevent python-h5py python-numpy python-pil python-scipy python-tk
git clone http://github.com/NVIDIA/Digits ~/Digits
sudo -H pip install -r ~/Digits/requirements.txt
then it occurred :
ERROR: Command errored out with exit status 1:
command: /usr/bin/python -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-ypn992_r/scipy/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-ypn992_r/scipy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base /tmp/pip-install-ypn992_r/scipy/pip-egg-info
cwd: /tmp/pip-install-ypn992_r/scipy/
Complete output (161 lines):
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/_generator.pyx
File “/tmp/easy_install-aapxsh1s/numpy-1.18.0/tools/cythonize.py”, line 61, in process_pyx
from Cython.Compiler.Version import version as cython_version
ImportError: No module named ‘Cython’
During handling of the above exception, another exception occurred:
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/tools/cythonize.py", line 238, in <module>
    main()
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/tools/cythonize.py", line 234, in main
    find_process_files(root_dir)
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/tools/cythonize.py", line 225, in find_process_files
    process(root_dir, fromfile, tofile, function, hash_db)
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/tools/cythonize.py", line 191, in process
    processor_function(fromfile, tofile)
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/tools/cythonize.py", line 66, in process_pyx
    raise OSError('Cython needs to be installed in Python as a module')
OSError: Cython needs to be installed in Python as a module
Running from numpy source directory.
/tmp/easy_install-aapxsh1s/numpy-1.18.0/setup.py:425: UserWarning: Unrecognized setuptools command, proceeding with generating Cython sources and expanding templates
  run_build = parse_setuppy_commands()
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 154, in save_modules
    yield saved
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 195, in setup_context
    yield
  File "/usr/lib/python3.5/contextlib.py", line 77, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 64, in save_path
    yield saved
    yield
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 55, in save_argv
    yield saved
    yield
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 82, in override_temp
    yield
    yield
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 92, in pushd
    yield saved
    yield
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 243, in run_setup
    DirectorySandbox(setup_dir).run(runner)
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 273, in run
    return func()
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 242, in runner
    _execfile(setup_script, ns)
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 46, in _execfile
    exec(code, globals, locals)
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/setup.py", line 450, in <module>
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/setup.py", line 433, in setup_package
  File "/tmp/easy_install-aapxsh1s/numpy-1.18.0/setup.py", line 240, in generate_cython
    try:
RuntimeError: Running cythonize failed!
  File "<string>", line 1, in <module>
  File "/tmp/pip-install-ypn992_r/scipy/setup.py", line 265, in <module>
    setup_package()
  File "/tmp/pip-install-ypn992_r/scipy/setup.py", line 262, in setup_package
    setup(**metadata)
  File "/usr/lib/python3.5/distutils/core.py", line 108, in setup
    _setup_distribution = dist = klass(attrs)
  File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 269, in __init__
    self.fetch_build_eggs(attrs['setup_requires'])
  File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 313, in fetch_build_eggs
    replace_conflicting=True,
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 826, in resolve
    dist = best[req.key] = env.best_match(req, ws, installer)
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1092, in best_match
    return self.obtain(req, installer)
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1104, in obtain
    return installer(requirement)
  File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 380, in fetch_build_egg
    return cmd.easy_install(req)
  File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 663, in easy_install
    return self.install_item(spec, dist.location, tmpdir, deps)
  File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 693, in install_item
    dists = self.install_eggs(spec, download, tmpdir)
  File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 873, in install_eggs
    return self.build_and_install(setup_script, setup_base)
  File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1101, in build_and_install
    self.run_setup(setup_script, setup_base, args)
  File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1087, in run_setup
    run_setup(setup_script, args)
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 246, in run_setup
    raise
    yield
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 178, in save_pkg_resources_state
    yield saved
    yield
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 166, in save_modules
    saved_exc.resume()
  File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 141, in resume
    six.reraise(type, exc, self._tb)
  File "/usr/lib/python3/dist-packages/pkg_resources/_vendor/six.py", line 685, in reraise
    raise value.with_traceback(tb)
    yield saved
    yield
    yield saved
    yield
    yield saved
    yield
    yield
    yield
    yield saved
    yield
    return func()
    try:
Cythonizing sources
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
I don’t know how to solve it ,
Is here anybody willing to help me,
thank you very much!
DIGITs doesn’t support Jetson platform.
The root cause is that the required nvidia-smi is not available for ARM system.
To apply training on the Jetson, you can install TensorFlow/pyTorch/Caffe directly.
