Can't load texture using mjcf importer in python but works well for GUI
Isaac Sim Version
4.1.0
Operating System
Ubuntu 20.04
GPU Information
  • Model:
  • Driver Version:
Topic Description
Detailed Description
Hi, i try to use mjcf importer with example python code. But the texture cannot be loaded. While it works well if i do not use python but GUI
Screenshots or Videos
##loading with python compared with loading with GUI button
Have you also noticed the issue with the ‘nv_ant.xml’ MJCF file used in the example Python code?
No, it works well for nv_ant.xml because the texture for ant is RGB value instead of image file. For the kitchen scene in my case, the texture in the xml is like:
material name=“counter_1_front_group_counter_base” texture=“flat/dark_blue” shininess=“0.1” reflectance=“0.1”/>
So the conclusion is texture file ‘flat/dark_blue’ cannot be loaded through python code.
Cry. Could anyone help?
