I am working with a Jetson AGX and have followed the complete tutorial to set up Isaac ROS along with FoundationPose. I’m currently running FoundationPose tracking, which is said to support up to 120 fps. However, when using rosbags, I can only achieve a maximum of 23 fps. Could you please help identify the factors that might be limiting its performance?
Rosbag input frequency is varied from 1fps to 100 fps but max output frequency reached is 23 fps
Jetson GUI:
Mode: 50W
Output frequency: /tracking/output
