Can't stream ucf studio to omniverse stream / webrtc stream, it shows nothing
I use google nvidia VMI, and here are my logs:
"2024-06-26 21:52:40 [2,050ms] [Warning] [gpu.foundation.plugin] ECC is enabled for device 0. This will reduce rendering performance.
2024-06-26 21:52:40 [2,050ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2024-06-26 21:52:40 [2,050ms] [Warning] [gpu.foundation.plugin] !!! Local system validation failed! Incorrect configuration detected.
2024-06-26 21:52:40 [2,050ms] [Warning] [gpu.foundation.plugin] Summary below. Details above.
2024-06-26 21:52:40 [2,050ms] [Warning] [gpu.foundation.plugin] - ECC: FAILED
2024-06-26 21:52:40 [2,050ms] [Warning] [gpu.foundation.plugin] - IOMMU: OK
[2.188s] [ext: omni.kit.pipapi-0.0.0] startup
[2.191s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.192s] [ext: omni.kit.loop-default-0.2.0] startup
[2.193s] [ext: omni.kit.test-0.0.0] startup
[2.270s] [ext: omni.mtlx-0.1.0] startup
[2.271s] [ext: omni.usd.config-1.0.3] startup
[2.278s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.279s] [ext: omni.usd.libs-1.0.0] startup
[2.424s] [ext: omni.appwindow-1.1.1] startup
2024-06-26 21:52:40 [2,316ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:40 [2,317ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[2.430s] [ext: omni.kit.renderer.core-0.0.0] startup
2024-06-26 21:52:40 [2,324ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:40 [2,325ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-06-26 21:52:40 [2,337ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:40 [2,337ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[2.448s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.453s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2024-06-26 21:52:40 [2,349ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:40 [2,349ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-06-26 21:52:40 [2,351ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:40 [2,351ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-06-26 21:52:41 [2,353ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:41 [2,353ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[2.783s] [ext: carb.audio-0.1.0] startup
[2.788s] [ext: omni.ui-2.16.8] startup
[2.810s] [ext: omni.uiaudio-1.0.0] startup
[2.812s] [ext: omni.kit.mainwindow-1.0.0] startup
[2.815s] [ext: omni.kit.uiapp-0.0.0] startup
[2.815s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[3.023s] [ext: omni.usd.schema.anim-0.0.0] startup
[3.080s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[3.090s] [ext: omni.usd.schema.semantics-0.0.0] startup
[3.095s] [ext: omni.usd.schema.audio-0.0.0] startup
[3.101s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[3.110s] [ext: omni.usd.schema.physics-0.0.0] startup
[3.138s] [ext: omni.graph.exec-0.2.7] startup
[3.139s] [ext: omni.kit.exec.core-0.4.1] startup
[3.142s] [ext: omni.kit.window.popup_dialog-2.0.22] startup
[3.150s] [ext: omni.kit.actions.core-1.0.0] startup
[3.153s] [ext: omni.usd_resolver-1.0.0] startup
2024-06-26 21:52:41 [3,044ms] [Warning] [omni.ext.plugin] [ext: omni.usd_resolver-1.0.0] Native plugin search dir contains several files: /tmp/.tmpNvXaPpBuilder/run/kit/exts/omni.usd_resolver/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[3.162s] [ext: omni.kit.commands-1.4.6] startup
[3.168s] [ext: omni.usd.core-1.1.5] startup
[3.175s] [ext: omni.kit.widget.nucleus_connector-1.1.0] startup
[3.179s] [ext: omni.timeline-1.0.9] startup
[3.183s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[3.196s] [ext: omni.ui.scene-1.6.12] startup
[3.206s] [ext: omni.resourcemonitor-105.0.0] startup
[3.211s] [ext: omni.activity.core-1.0.1] startup
[3.216s] [ext: omni.kit.widget.path_field-2.0.7] startup
[3.218s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[3.220s] [ext: omni.hydra.usdrt_delegate-7.2.19] startup
[3.246s] [ext: omni.kit.widget.browser_bar-2.0.8] startup
[3.247s] [ext: omni.usd-1.10.11] startup
[3.330s] [ext: omni.kit.notification_manager-1.0.6] startup
[3.333s] [ext: omni.kit.helper.file_utils-0.1.5] startup
[3.373s] [ext: omni.kit.widget.nucleus_info-1.0.1] startup
[3.374s] [ext: omni.kit.widget.filebrowser-2.3.34] startup
[3.384s] [ext: omni.kit.search_core-1.0.4] startup
[3.385s] [ext: omni.kit.widget.versioning-1.4.4] startup
[3.390s] [ext: omni.kit.widget.search_delegate-1.0.3] startup
[3.392s] [ext: omni.kit.clipboard-1.0.3] startup
[3.393s] [ext: omni.kit.window.filepicker-2.10.2] startup
[3.419s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[3.422s] [ext: omni.kit.renderer.cuda_interop-1.0.1] startup
[3.426s] [ext: omni.kit.documentation.builder-1.0.9] startup
2024-06-26 21:52:42 [3,362ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.actions.core-1.0.0) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,363ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.collaboration.telemetry-1.0.0) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,364ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.commands-1.4.6) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,364ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.helper.file_utils-0.1.5) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,364ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.pipapi-0.0.0) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,364ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.widget.filebrowser-2.3.34) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,364ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.window.popup_dialog-2.0.22) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,366ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.ui-2.16.8) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,366ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/Omni UI Scene Doc) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,366ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.usd-1.10.11) - Extension needs dependency to omni.kit.menu.utils
2024-06-26 21:52:42 [3,366ms] [Warning] [omni.kit.ui.editor_menu] omni.kit.menu.utils not loaded for add_item(Help/API/omni.kit.documentation.builder) - Extension needs dependency to omni.kit.menu.utils
[3.476s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[3.480s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[3.483s] [ext: omni.kit.usd.layers-2.1.17] startup
[3.512s] [ext: omni.kit.widget.prompt-1.0.5] startup
[3.515s] [ext: omni.kit.context_menu-1.6.3] startup
[3.521s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[3.524s] [ext: omni.services.facilities.base-1.0.3] startup
[3.526s] [ext: omni.kit.menu.utils-1.5.3] startup
[3.536s] [ext: omni.kit.widget.graph-1.8.1] startup
[3.551s] [ext: omni.kit.widget.searchfield-1.1.1] startup
[3.558s] [ext: omni.services.core-1.6.3] startup
[3.763s] [ext: omni.kit.window.console-0.2.5] startup
[3.781s] [ext: omni.kit.graph.delegate.default-1.1.1] startup
[3.783s] [ext: omni.kit.window.property-1.9.6] startup
[3.788s] [ext: omni.services.transport.server.base-1.1.1] startup
[3.789s] [ext: omni.kit.window.title-1.1.3] startup
2024-06-26 21:52:42 [3,683ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:42 [3,683ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-06-26 21:52:42 [3,684ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-26 21:52:42 [3,684ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[3.795s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[3.799s] [ext: omni.kit.graph.delegate.modern-1.9.1] startup
[3.805s] [ext: omni.services.transport.server.http-1.3.0] startup
2024-06-26 21:52:42 [3,698ms] [Warning] [omni.services.transport.server.http.server] http server was meant to start on 8011 but port is taken, starting on port 8017 instead
[3.856s] [ext: omni.exp.graph.core-1.5.2] startup
[3.868s] [ext: omni.kit.livestream.core-2.2.1] startup
[3.871s] [ext: omni.kit.widget.settings-1.0.3] startup
[3.874s] [ext: omni.services.streaming.manager-0.3.8] startup
[3.882s] [ext: omni.kit.streamsdk.plugins-2.3.7] startup
[3.882s] [ext: omni.ucf.graph.appbuilder-2.0.0] startup
2024-06-26 21:52:42 [3,774ms] [Warning] [omni.kit.app._impl] carb.imgui is deprecated. Use omni.kit.imgui instead.
2024-06-26 21:52:42 [4,021ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.ucf.graph.appbuilder. Error: cannot import name ‘HelmChartHelper’ from partially initialized module ‘utils.helm_chart_helper’ (most likely due to a circular import) (/tmp/.tmpNvXaPpBuilder/run/./utils/helm_chart_helper.py). Traceback:
File “/tmp/.tmpNvXaPpBuilder/run/kit/kernel/py/omni/ext/_impl/custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File “/tmp/.tmpNvXaPpBuilder/run/kit/python/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/tmp/.tmpNvXaPpBuilder/run/appbuilder/omni.ucf.graph.appbuilder/omni/ucf/graph/appbuilder/init.py”, line 9, in
from .extension import GraphComposerExtension
File “/tmp/.tmpNvXaPpBuilder/run/appbuilder/omni.ucf.graph.appbuilder/omni/ucf/graph/appbuilder/extension.py”, line 22, in
from .builder import Builder
File “/tmp/.tmpNvXaPpBuilder/run/appbuilder/omni.ucf.graph.appbuilder/omni/ucf/graph/appbuilder/builder.py”, line 18, in
from .graph_widget import GraphWidget
File “/tmp/.tmpNvXaPpBuilder/run/appbuilder/omni.ucf.graph.appbuilder/omni/ucf/graph/appbuilder/graph_widget.py”, line 22, in
from .graph_configurator import PreferencesWindow
File “/tmp/.tmpNvXaPpBuilder/run/appbuilder/omni.ucf.graph.appbuilder/omni/ucf/graph/appbuilder/graph_configurator.py”, line 18, in
from appbuilder.backend.app_secret import UcfK8sSecret, UcfVaultSecret, UcfCsiDriverSecret, UcfCertificateSecret, UcfAppSecret
File “/tmp/.tmpNvXaPpBuilder/run/./appbuilder/backend/init.py”, line 9, in
from .registry import UcfRegistryContext
File “/tmp/.tmpNvXaPpBuilder/run/./appbuilder/backend/registry.py”, line 19, in
from utils.helm_chart_helper import HelmChartHelper
File “/tmp/.tmpNvXaPpBuilder/run/./utils/helm_chart_helper.py”, line 20, in
import utils.utils
File “/tmp/.tmpNvXaPpBuilder/run/./utils/utils.py”, line 10, in
from registry.core.core import UcfRegistryCore
File “/tmp/.tmpNvXaPpBuilder/run/./registry/core/core.py”, line 27, in
ImportError: cannot import name ‘HelmChartHelper’ from partially initialized module ‘utils.helm_chart_helper’ (most likely due to a circular import) (/tmp/.tmpNvXaPpBuilder/run/./utils/helm_chart_helper.py)
2024-06-26 21:52:42 [4,021ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.ucf.graph.appbuilder’ in ‘/tmp/.tmpNvXaPpBuilder/run/appbuilder/omni.ucf.graph.appbuilder’ failed to load.
At:
/tmp/.tmpNvXaPpBuilder/run/kit/kernel/py/omni/ext/_impl/_internal.py(213): startup
/tmp/.tmpNvXaPpBuilder/run/kit/kernel/py/omni/ext/_impl/_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
2024-06-26 21:52:42 [4,021ms] [Error] [omni.ext.plugin] [ext: omni.ucf.graph.appbuilder-2.0.0] Failed to startup python extension.
[4.248s] [ext: omni.kit.livestream.native-2.3.0] startup
Active user not found. Using default user [kiosk]Streaming server started.
2024-06-26 21:52:46 [8,152ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription View Online Documentation *********************
2024-06-26 21:52:46 [8,152ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] View Online Documentation uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2024-06-26 21:52:46 [8,153ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription View Online Documentation *********************
2024-06-26 21:52:46 [8,153ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] View Online Documentation uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2024-06-26 21:52:46 [8,157ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription 10.138.0.9 *********************
2024-06-26 21:52:46 [8,157ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] 10.138.0.9 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2024-06-26 21:52:46 [8,157ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription View Online Documentation *********************
2024-06-26 21:52:46 [8,157ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] View Online Documentation uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[8.267s] [ext: app-2.0.0] startup
[8.429s] app ready
main: thread_init: already added for thread
2024-06-26 21:53:23 [44,557ms] [Error] [carb.livestream.plugin] nvstPushStreamData timeout for eye 0, stream 0x7549a80415c0.
2024-06-26 21:53:23 [44,650ms] [Error] [carb.livestream.plugin] nvstPushStreamData timeout for eye 0, stream (nil).
I tried everything but it shows nothing when i try to stream.
Same exact thing going on with me.
Just looking at the title of this post, you cannot stream to Omniverse. Only from Omniverse. Can you clarify what you were trying to do please.
Give me your exact hardware, software, platform etc.
Have you solved it?
Sorry for late reply, I am working with different engine for now. If I get back to this and get same error, I will update.
Originally, I used Google Nvidia VM.
Ok thanks for letting us know. Good luck
