[carb.graphics-vulkan.plugin] GPU crash is detected
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA RTX 3500 Ada
  • Driver Version: 553.05
Topic Description
Detailed Description
I am trying to follow the stereolabs tutorial to start camera streaming. The zedx camera seems to connect and the moment it starts streaming I get the GPU crash detected message and everything freezes.
In my environment there is a floor and a zedx camera. It is a very basic setup.
Steps to Reproduce
  1. Follow the tutorial (Link : Setting up ZED Camera in Isaac™ Sim - Stereolabs )
Error Messages
Additional Information
What I’ve Tried
Installing the Isaac sim Assets locally.
Tried downgrading the Drivers to the 537.70.
Related Issues
Additional Context
kit_20250409_130045.log (1.0 MB)
Which installation method did you follow? Workstation Installation — Isaac Sim Documentation? Have you ever successfully run any Isaac Sim applications on 4.5.0?
I notice these messages from the log. Could you address the OneDrive issues?
2025-04-09 17:01:28 [42,965ms] [Error] [omni.kit.stage_templates.new_stage] Failed to create directory C:/Users/AadeshVarude/OneDrive - MVP Robotics, Inc/Documents/Kit/apps/Isaac-Sim Full/scripts/new_stage
2025-04-09 17:01:38 [52,873ms] [Error] [isaacsim.gui.menu.edit_menu.screenshot_page] Failed to create directory C:/Users/AadeshVarude/OneDrive - MVP Robotics, Inc/Documents/Kit/shared/screenshots/
2025-04-09 17:02:08 [82,929ms] [Error] [rtx.neuraylib.plugin] Cannot find `Documents/Kit/shared` directory.
2025-04-09 17:05:33 [288,191ms] [Info] [sl.sensor.camera.ogn.nodes.SlCameraStreamer] ZED_X - Starting stream to the ZED SDK
2025-04-09 17:05:33 [288,191ms] [Info] [sl.sensor.camera.ogn.nodes.SlCameraStreamer] ZED_X - Setting initial streaming time stamp to: 1744218333977722900
2025-04-09 17:05:34 [288,326ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Edit
2025-04-09 17:05:34 [288,930ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-000001be30d3c0f0-000001be4e53b2c0.nvdbg
2025-04-09 17:05:34 [288,931ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,932ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-000001be30d3c0f0-000001be152e4720.nvdbg
2025-04-09 17:05:34 [288,933ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,934ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-000001be30d3c0f0-000001be152e3a30.nvdbg
2025-04-09 17:05:34 [288,934ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,936ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-000001be30d3c0f0-000001be52a459b0.nvdbg
2025-04-09 17:05:34 [288,937ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,938ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-000001be30d3c0f0-000001be52a45560.nvdbg
2025-04-09 17:05:34 [288,939ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,940ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-25f62cc0370e596c-000001b0ead97320.nvdbg
2025-04-09 17:05:34 [288,941ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,943ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-a9b40c275c9946d5-000001bdfebedd50.nvdbg
2025-04-09 17:05:34 [288,944ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,946ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-1a988ab9aaeb365b-000001bde2b305c0.nvdbg
2025-04-09 17:05:34 [288,946ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,947ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-04994957e16a138c-000001b1225eb060.nvdbg
2025-04-09 17:05:34 [288,948ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,949ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-949248f388d1a122-000001b19a906100.nvdbg
2025-04-09 17:05:34 [288,949ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-04-09 17:05:34 [288,952ms] [Warning] [carb.graphics-vulkan.plugin] GPU pagefault occured on virtual address(0x000000000e610000)
2025-04-09 17:05:34 [288,952ms] [Warning] [carb.graphics-vulkan.plugin] GPU pagefault no associated data found closest allocations were:
2025-04-09 17:05:34 [288,953ms] [Warning] [carb.graphics-vulkan.plugin] 1: AddressRange(0x0000000000000000 - 0x0000000000000000) with name(dummy to ignore)
2025-04-09 17:05:34 [288,953ms] [Warning] [carb.graphics-vulkan.plugin] 2: AddressRange(0xffffffffffffffff - 0xffffffffffffffff) with name(dummy to ignore)
2025-04-09 17:05:34 [288,955ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-04-09 17:05:34 [288,956ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-04-09 17:05:34 [288,957ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-04-09 17:05:34 [288,960ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-04-09 17:05:34 [288,961ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-04-09 17:05:34 [288,971ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write crash dump into: C:/Users/AadeshVarude/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_130045-0.nv-gpudmp
2025-04-09 17:05:34 [288,972ms] [Error] [carb.graphics-vulkan.plugin] GPU crash dump is successfully written
2025-04-09 17:05:34 [288,974ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_DEVICE_LOST
2025-04-09 17:05:34 [288,974ms] [Error] [carb.graphics-vulkan.plugin] vkWaitForFences failed for command queue.
2025-04-09 17:05:34 [288,974ms] [Error] [gpu.foundation.plugin] A GPU crash occurred. Exiting the application...
Reasons for the failure: a device lost, out of memory, or an unexpected bug.
2025-04-09 17:05:34 [288,975ms] [Warning] [gpu.foundation.plugin] polling aftermath dump status ...
2025-04-09 17:05:34 [289,026ms] [Warning] [gpu.foundation.plugin] successfully waited and produced aftermath dump
2025-04-09 17:05:36 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-04-09 17:05:36 [11ms] [Warning] [carb.crashreporter-breakpad.plugin] Launched process 'py-spy.exe' as PID 32776
2025-04-09 17:05:36 [331ms] [Error] [carb.crashreporter-breakpad.plugin] 'py-spy.exe' exited with code 1
2025-04-09 17:05:36 [340ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 14 files into 'C:/Users/AadeshVarude/AppData/Local/ov/data/Kit/Isaac-Sim Full/4.5\7c840928-ceba-4d04-b475-52a2b29963dc.dmp.zip' for upload.
2025-04-09 17:05:37 [1,267ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file 'C:/Users/AadeshVarude/AppData/Local/ov/data/Kit/Isaac-Sim Full/4.5\7c840928-ceba-4d04-b475-52a2b29963dc.dmp' with 10 retries remaining.
2025-04-09 17:05:37 [1,270ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file 'C:/Users/AadeshVarude/AppData/Local/ov/data/Kit/Isaac-Sim Full/4.5\7c840928-ceba-4d04-b475-52a2b29963dc.dmp.toml' with 10 retries remaining.
2025-04-09 17:05:37 [1,289ms] [Warning] [carb.crashreporter-breakpad.plugin] Launched process 'crashreport.gui.exe' as PID 28200
2025-04-09 17:06:07 [31,290ms] [Warning] [carb.crashreporter-breakpad.plugin]    ... waiting for PID 28200 to exit ...
2025-04-09 17:06:37 [61,301ms] [Warning] [carb.crashreporter-breakpad.plugin]    ... waiting for PID 28200 to exit ...
2025-04-09 17:07:07 [91,312ms] [Warning] [carb.crashreporter-breakpad.plugin]    ... waiting for PID 28200 to exit ...
2025-04-09 17:07:37 [121,314ms] [Warning] [carb.crashreporter-breakpad.plugin]    ... waiting for PID 28200 to exit ...
2025-04-09 17:07:49 [133,777ms] [Error] [carb.crashreporter-breakpad.plugin] 'crashreport.gui.exe' exited with code 3221225786
The One Drive error is where isaac sim is tryin to store files on my OneDrive but it does not have access to it.
Is there any way where I can change the path to a different location?
For installation I have followed the official Workstation Installation documentation, but still somehow it tries to access my OneDrive folders.
I am able to run the getting started tutorials from the official website successfully.
Could you try using the driver version recommended in Isaac Sim Requirements — Isaac Sim Documentation?
I have already tried using the recommended version of drivers. Did not work with that.
Thank you .
Is there anything else that I should be debugging or checking?
Or any other approach that I should try to fix this issue ?
Any help on this would be appreciated.
Thank you
Please share the full log of the issue using the recommended version. Thanks.
Hello!
Best regards,
