Yes it’s done.
Here is my entire boot log. I don’t find anything to explain that
[0000.202] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c700205d)
[0000.210] I> bit @ 0xd480000
[0000.213] I> Boot-device: eMMC
[0000.220] I> sdmmc bdev is already initialized
[0000.225] I> pmic: reset reason (nverc) : 0x40
[0000.257] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.276] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.282] W> No valid slot number is found in scratch register
[0000.287] W> Return default slot: _a
[0000.291] I> A/B: bin_type (16) slot 0
[0000.294] I> Loading partition bpmp-fw at 0xd7800000
[0000.299] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.305] I> Addr: 0xd7800000, start-block: 29417480, num_blocks: 1
[0000.329] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.335] W> No valid slot number is found in scratch register
[0000.341] W> Return default slot: _a
[0000.344] I> A/B: bin_type (17) slot 0
[0000.348] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.353] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.359] I> Addr: 0xd79f0000, start-block: 29419896, num_blocks: 1
[0000.380] I> Binary(17) of size 314992 is loaded @ 0xd79b3000
[0000.502] I> Loading SCE-FW ...
[0000.505] W> No valid slot number is found in scratch register
[0000.511] W> Return default slot: _a
[0000.515] I> A/B: bin_type (12) slot 0
[0000.518] I> Loading partition sce-fw at 0xd7300000
[0000.523] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.528] I> Addr: 0xd7300000, start-block: 29423992, num_blocks: 1
[0000.547] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.553] I> Init SCE
[0000.555] I> Loading APE-FW ...
[0000.558] W> No valid slot number is found in scratch register
[0000.564] W> Return default slot: _a
[0000.568] I> A/B: bin_type (11) slot 0
[0000.571] I> Loading partition adsp-fw at 0xd7400000
[0000.576] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.581] I> Addr: 0xd7400000, start-block: 29401096, num_blocks: 1
[0000.600] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.606] I> Copy BTCM section
[0000.609] W> No valid slot number is found in scratch register
[0000.615] W> Return default slot: _a
[0000.618] I> A/B: bin_type (13) slot 0
[0000.622] I> Loading partition cpu-bootloader at 0x96000000
[0000.628] I> Reading two headers - addr:0x96000000 blocks:1
[0000.633] I> Addr: 0x96000000, start-block: 29380616, num_blocks: 1
[0000.654] I> Binary(13) of size 284816 is loaded @ 0x96000000
[0000.659] W> No valid slot number is found in scratch register
[0000.665] W> Return default slot: _a
[0000.668] I> A/B: bin_type (20) slot 0
[0000.672] I> Loading partition bootloader-dtb at 0x8520f400
[0000.677] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.683] I> Addr: 0x8520f400, start-block: 29382664, num_blocks: 1
[0000.705] I> Binary(20) of size 362240 is loaded @ 0x8520f400
[0000.711] W> No valid slot number is found in scratch register
[0000.716] W> Return default slot: _a
[0000.720] I> A/B: bin_type (14) slot 0
[0000.723] I> Loading partition secure-os at 0x8530f600
[0000.728] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.734] I> Addr: 0x8530f600, start-block: 29384712, num_blocks: 1
[0000.756] I> Binary(14) of size 366000 is loaded @ 0x8530f600
[0000.763] I> TOS boot-params @ 0x85000000
[0000.767] I> TOS params prepared
[0000.770] I> Loading EKS ...
[0000.773] I> A/B: bin_type (15) slot 0
[0000.777] I> Loading partition eks at 0x8590f800
[0000.781] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.787] I> Addr: 0x8590f800, start-block: 29397000, num_blocks: 1
[0000.805] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.811] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.816] I> Copied encrypted keys
[0000.820] I> boot profiler @ 0x175844000
[0000.823] I> boot profiler for TOS @ 0x175844000
[0000.828] I> Unhalting SCE
[0000.831] I> Primary Memory Start:80000000 Size:70000000
[0000.836] I> Extended Memory Start:f0110000 Size:856f0000
[0000.843] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):41d46a9cf
NOTICE: BL31: Built : 21:14:44, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.150] I> Welcome to Cboot
[0001.153] I> Cboot Version: t186-02737b3e
[0001.156] I> CPU-BL Params @ 0x175800000
[0001.160] I> 0) Base:0x00000000 Size:0x00000000
[0001.165] I> 1) Base:0x177f00000 Size:0x00100000
[0001.169] I> 2) Base:0x177e00000 Size:0x00100000
[0001.174] I> 3) Base:0x177d00000 Size:0x00100000
[0001.178] I> 4) Base:0x177c00000 Size:0x00100000
[0001.183] I> 5) Base:0x177b00000 Size:0x00100000
[0001.187] I> 6) Base:0x177800000 Size:0x00200000
[0001.192] I> 7) Base:0x177400000 Size:0x00400000
[0001.196] I> 8) Base:0x177a00000 Size:0x00100000
[0001.201] I> 9) Base:0x177300000 Size:0x00100000
[0001.205] I> 10) Base:0x176800000 Size:0x00800000
[0001.210] I> 11) Base:0x30000000 Size:0x00040000
[0001.214] I> 12) Base:0xf0000000 Size:0x00100000
[0001.219] I> 13) Base:0x30040000 Size:0x00001000
[0001.223] I> 14) Base:0x30048000 Size:0x00001000
[0001.227] I> 15) Base:0x30049000 Size:0x00001000
[0001.232] I> 16) Base:0x3004a000 Size:0x00001000
[0001.236] I> 17) Base:0x3004b000 Size:0x00001000
[0001.241] I> 18) Base:0x3004c000 Size:0x00001000
[0001.245] I> 19) Base:0x3004d000 Size:0x00001000
[0001.250] I> 20) Base:0x3004e000 Size:0x00001000
[0001.254] I> 21) Base:0x3004f000 Size:0x00001000
[0001.258] I> 22) Base:0x00000000 Size:0x00000000
[0001.263] I> 23) Base:0xf0100000 Size:0x00010000
[0001.267] I> 24) Base:0x00000000 Size:0x00000000
[0001.272] I> 25) Base:0x00000000 Size:0x00000000
[0001.276] I> 26) Base:0x00000000 Size:0x00000000
[0001.281] I> 27) Base:0x00000000 Size:0x00000000
[0001.285] I> 28) Base:0x84400000 Size:0x00400000
[0001.289] I> 29) Base:0x30000000 Size:0x00010000
[0001.294] I> 30) Base:0x178000000 Size:0x08000000
[0001.298] I> 31) Base:0x00000000 Size:0x00000000
[0001.303] I> 32) Base:0x176000000 Size:0x00600000
[0001.307] I> 33) Base:0x80000000 Size:0x70000000
[0001.312] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.316] I> 35) Base:0x00000000 Size:0x00000000
[0001.321] I> 36) Base:0x00000000 Size:0x00000000
[0001.325] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.330] I> 38) Base:0x84000000 Size:0x00400000
[0001.334] I> 39) Base:0x96000000 Size:0x02000000
[0001.338] I> 40) Base:0x85000000 Size:0x01200000
[0001.343] I> 41) Base:0x175800000 Size:0x00500000
[0001.347] I> 42) Base:0x00000000 Size:0x00000000
[0001.352] I> 43) Base:0x00000000 Size:0x00000000
[0001.356] GIC-SPI Target CPU: 4
[0001.360] Interrupts Init done
[0001.363] calling constructors
[0001.366] initializing heap
[0001.369] initializing threads
[0001.372] initializing timers
[0001.375] creating bootstrap completion thread
[0001.380] top of bootstrap2()
[0001.383] CPU: ARM Cortex A57
[0001.386] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.391] initializing platform
[0001.394] I> Bl_dtb @0x8520f400
[0001.397] I> gpio framework initialized
[0001.404] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.414] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.421] I> GPIO framework and drivers are initialized.
[0001.426] I> Boot-device: eMMC
[0001.434] I> sdmmc bdev is already initialized
[0001.464] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.482] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.487] W> opt-in fuse is not set, skip fuse_burning
[0001.492] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.498] W> No valid slot number is found in scratch register
[0001.503] W> Return default slot: _a
[0001.507] I> A/B: bin_type (21) slot 0
[0001.510] I> Loading kernel-dtb from partition
[0001.515] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.532] I> Kernel_dtb @0x80000000
[0001.535] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.544] E> I2C: slave not found in slaves.
[0001.548] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.555] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.561] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.571] E> tca9539_device_init: failed to write polar reg
[0001.576] E> tegrabl_tca9539_init: failed to init device!
[0001.581] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.588] E> I2C: slave not found in slaves.
[0001.592] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.600] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.606] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.615] E> tca9539_device_init: failed to write polar reg
[0001.620] E> tegrabl_tca9539_init: failed to init device!
[0001.628] I> fixed regulator driver initialized
[0001.661] I> register 'maxim' power off handle
[0001.667] I> virtual i2c enabled
[0001.670] I> registered 'maxim,max77620' pmic
[0001.675] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.683] W> No board IDs available
[0001.710] I> enabling 'vdd-hdmi' regulator
[0001.714] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.723] E> cannot find any other nvdisp nodes
[0001.727] E> no valid display unit config found in dtb
[0001.733] W> display init failed
[0001.736] initializing target
[0001.739] calling apps_init()
[0001.742] starting app kernel_boot_app
[0001.873] I> decompressor handler not found
[0001.877] I> Kernel type = Normal
[0001.880] I> Loading kernel-bootctrl from partition
[0001.885] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0001.905] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0001.912] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0001.919] I> ########## Fixed storage boot ##########
[0001.924] W> No valid slot number is found in scratch register
[0001.929] W> Return default slot: _a
[0001.933] I> A/B: bin_type (24) slot 0
[0001.948] I> Boot image size read from image header: 746bc
[0001.954] I> Boot image load address: 0x80400000
[0001.958] I> Loading kernel from partition
[0001.962] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.214] I> Validate kernel ...
[0003.217] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.224] I> kernel-dtb is already loaded
[0003.228] I> Validate kernel-dtb ...
[0003.232] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.239] I> Checking boot.img header magic ... [0003.243] I> [OK]
[0003.245] I> Kernel hdr @0x80400000
[0003.249] I> Kernel dtb @0x80000000
[0003.252] I> decompressor handler not found
[0003.256] I> Copying kernel image (476860 bytes) from 0x80400800 to 0x80600000 ... [0003.263] I> Done
[0003.265] I> Move ramdisk (len: 0) from 0x80475000 to 0x947b0000
[0003.272] I> Updated bpmp info to DTB
[0003.278] I> Ramdisk: Base: 0x947b0000; Size: 0x0
[0003.283] I> Updated initrd info to DTB
[0003.286] W> WARN: Fail to override "console=none" in commandline
[0003.292] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.299] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.307] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.314] I> disabled_core_mask: 0xffffff0c
[0003.318] W> No valid slot number is found in scratch register
[0003.323] W> Return default slot: _a
[0003.327] I> Active slot suffix:
[0003.330] I> add_boot_slot_suffix: slot_suffix =
[0003.334] I> Linux Cmdline: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 ignore_loglevel fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1
[0003.381] I> Updated bootarg info to DTB
[0003.385] W> No MAC address type 0 available
[0003.389] E> Failed to get WIFI MAC address
[0003.393] W> No MAC address type 1 available
[0003.397] E> Failed to get Bluetooth MAC address
[0003.401] W> No MAC address type 2 available
[0003.405] E> Failed to get Ethernet MAC address
[0003.410] E> Found no plugin manager ids in source DT
[0003.414] W> Add plugin manager ids from board info
[0003.419] W> "plugin-manager" doesn't exist, creating
[0003.424] W> "ids" doesn't exist, creating
[0003.428] W> "connection" doesn't exist, creating
[0003.433] W> "configs" doesn't exist, creating
[0003.437] W> No board IDs available
[0003.440] W> Board id is not supported, booting without board id
[0003.446] W> "odm-data" doesn't exist, creating
[0003.451] I> Adding /chosen/plugin-manager/odm-data
[0003.460] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.466] I> added [base:0xf0200000, size:0x85600000] to /memory
[0003.472] I> added [base:0x175e00000, size:0x200000] to /memory
[0003.478] I> added [base:0x176600000, size:0x200000] to /memory
[0003.483] I> added [base:0x177000000, size:0x200000] to /memory
[0003.489] I> Updated memory info to DTB
[0003.494] E> add_disp_param: failed to get display params for du=0
[0003.501] W> "reset" doesn't exist, creating
[0003.505] W> "pmc-reset-reason" doesn't exist, creating
[0003.511] W> "pmic-reset-reason" doesn't exist, creating
[0003.517] I> Adding ecid(00000001645ca4420800000002ff0080) to DT
[0003.523] I> disabled_core_mask: 0xffffff0c
[0003.536] W> No serial number available, using 0
[0003.540] E> Failed to get serial number
[0003.544] I> Plugin-manager override starting
[0003.549] I> node /plugin-manager/fragement@0 matches
[0003.559] I> node /plugin-manager/fragement@4 matches
[0003.617] I> Disable plugin-manager status in FDT
[0003.621] I> Plugin-manager override finished successfully
[0003.626] I> tegrabl_load_kernel_and_dtb: Done
[0003.631] E> tegrabl_display_clear: display is not initialized
[0003.636] W> Boot logo display failed...
[0003.640] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2016.07-dirty (Aug 14 2020 - 08:28:16 +0200)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 3.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Can't find nvidia,ether-mac property in cboot DTB
Net:
Error: ethernet@2490000 address not set.
No ethernet found.
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
873 bytes read in 145 ms (5.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565615 bytes read in 256 ms (20.7 MiB/s)
Retrieving file: /boot/Image
34723848 bytes read in 867 ms (38.2 MiB/s)
append: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 ignore_loglevel fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 ignore_loglevel fbcon=map:0 net.ifnames=0 isolcpus=1-2
## Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 000000008005cdda
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (root@ubuntu) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #2 SMP PREEMPT Wed Aug 12 10:08:52 CEST 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 85600000
[ 0.000000] OF: fdt: - 175e00000 , 200000
[ 0.000000] OF: fdt: - 176600000 , 200000
[ 0.000000] OF: fdt: - 177000000 , 200000
[ 0.000000] debug: ignoring loglevel setting.
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1006592
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 7624 pages used for memmap
[ 0.000000] Normal zone: 482816 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0f676a000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 990776
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 ignore_loglevel fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 ignore_loglevel fbcon=map:0 net.ifnames=0 isolcpus=1-2
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29152(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3845972K/4026368K available (15294K kernel code, 2934K rwdata, 7052K rodata, 8576K init, 609K bss, 114860K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009660000 ( 7104 KB)
[ 0.000000] .init : 0xffffff8009660000 - 0xffffff8009ec0000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009ec0000 - 0xffffff800a19d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a19d808 - 0xffffff800a235f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03dc8000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0f7200000 ( 3954 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009825] Console: colour dummy device 80x25
[ 0.014474] console [tty0] enabled
[ 0.018017] bootconsole [uart8250] disabled
[ 0.022378] kmemleak: Kernel memory leak detector disabled
[ 0.022394] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022408] pid_max: default: 32768 minimum: 301
[ 0.022722] Security Framework initialized
[ 0.022881] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.022891] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023462] ftrace: allocating 47104 entries in 185 pages
[ 0.147106] sched-energy: Sched-energy-costs installed from DT
[ 0.147127] ASID allocator initialised with 65536 entries
[ 0.184167] tegra-id: chipid=21817.
[ 0.184182] tegra-id: opt_subrevision=1.
[ 0.184205] Tegra Revision: A02p SKU: 0x94 CPU Process: 0 SoC Process: 0
[ 0.184220] DTS File Name: /home/altaneos/nvidia/nvidia_sdk_4gb/JetPack_4.4_Linux_JETSON_TX2_4GB/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-tegra-lys-cam-a00-00-base.dts
[ 0.184239] DTB Build time: <unknown>
[ 0.230003] CPU1: Booted secondary processor [4e0f0030]
[ 0.261637] CPU2: Booted secondary processor [4e0f0030]
[ 0.293419] CPU3: Booted secondary processor [411fd073]
[ 0.325398] CPU4: Booted secondary processor [411fd073]
[ 0.357395] CPU5: Booted secondary processor [411fd073]
[ 0.357449] Brought up 6 CPUs
[ 0.357491] SMP: Total of 6 processors activated.
[ 0.357503] CPU features: detected feature: 32-bit EL0 Support
[ 0.358281] CPU: All CPU(s) started at EL2
[ 0.358338] alternatives: patching kernel code
[ 0.360811] devtmpfs: initialized
[ 0.398061] Initilizing CustomIPI irq domain
[ 0.398275] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.398304] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.399160] pinctrl core: initialized pinctrl subsystem
[ 0.399386] OS set in device tree is not L4T.
[ 0.399542] regulator-dummy: no parameters
[ 0.399687] Initializing plugin-manager
[ 0.399751] Plugin module not found
[ 0.399795] Plugin-manager status disabled
[ 0.401636] NET: Registered protocol family 16
[ 0.402422] pstore: using zlib compression
[ 0.402855] console [pstore-1] enabled
[ 0.402867] pstore: Registered ramoops as persistent store backend
[ 0.402881] ramoops: attached 0x200000@0x175880000, ecc: 0/0
[ 0.413434] cpuidle: using governor menu
[ 0.414975] bpmp: waiting for handshake
[ 0.414992] bpmp: handshake completed
[ 0.415018] bpmp: synchronizing channels
[ 0.415034] bpmp: channels synchronized
[ 0.415046] bpmp: mail init ok
[ 0.417081] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.417101] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.417115] arm-smmu 12000000.iommu: stage 1 translation
[ 0.417128] arm-smmu 12000000.iommu: stage 2 translation
[ 0.417140] arm-smmu 12000000.iommu: nested translation
[ 0.417155] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.417174] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.417193] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.417208] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.417222] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.419454] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009ec4000)
[ 0.419488] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421664] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.423725] Registering BPMP clocks...
[ 0.423821] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.424729] Serial: AMBA PL011 UART driver
[ 0.425873] tegra_powergate_init: DONE
[ 0.425894] DTS File Name: /home/altaneos/nvidia/nvidia_sdk_4gb/JetPack_4.4_Linux_JETSON_TX2_4GB/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-tegra-lys-cam-a00-00-base.dts
[ 0.425927] DTB Build time: <unknown>
[ 0.428003] Tegra reboot handler registered.
[ 0.429515] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.429595] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.429618] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.429632] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.429644] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.429808] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.429835] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.430168] iommu: Adding device 3460000.sdhci to group 0
[ 0.430637] iommu: Adding device 3440000.sdhci to group 1
[ 0.431092] iommu: Adding device 3400000.sdhci to group 2
[ 0.432157] iommu: Adding device 3507000.ahci-sata to group 3
[ 0.432183] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.432638] iommu: Adding device 3160000.i2c to group 4
[ 0.433083] iommu: Adding device c240000.i2c to group 5
[ 0.433469] iommu: Adding device 3180000.i2c to group 6
[ 0.433813] iommu: Adding device 3190000.i2c to group 7
[ 0.434233] iommu: Adding device 31b0000.i2c to group 8
[ 0.434573] iommu: Adding device 31c0000.i2c to group 9
[ 0.434913] iommu: Adding device 31e0000.i2c to group 10
[ 0.436408] iommu: Adding device 3210000.spi to group 11
[ 0.436748] iommu: Adding device c260000.spi to group 12
[ 0.437098] iommu: Adding device 3240000.spi to group 13
[ 0.437812] iommu: Adding device 3100000.serial to group 14
[ 0.439160] iommu: Adding device 2490000.ether_qos to group 15
[ 0.439192] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.439864] iommu: Adding device b000000.rtcpu to group 16
[ 0.442028] iommu: Adding device 13e10000.host1x to group 17
[ 0.442370] iommu: Adding device 13e10000.host1x:ctx0 to group 18
[ 0.442677] iommu: Adding device 13e10000.host1x:ctx1 to group 19
[ 0.442985] iommu: Adding device 13e10000.host1x:ctx2 to group 20
[ 0.443312] iommu: Adding device 13e10000.host1x:ctx3 to group 21
[ 0.443618] iommu: Adding device 13e10000.host1x:ctx4 to group 22
[ 0.443930] iommu: Adding device 13e10000.host1x:ctx5 to group 23
[ 0.444238] iommu: Adding device 13e10000.host1x:ctx6 to group 24
[ 0.444560] iommu: Adding device 13e10000.host1x:ctx7 to group 25
[ 0.445039] iommu: Adding device 150c0000.nvcsi to group 26
[ 0.445704] iommu: Adding device 15700000.vi to group 27
[ 0.446061] iommu: Adding device 15600000.isp to group 28
[ 0.446538] iommu: Adding device 15210000.nvdisplay to group 29
[ 0.447133] iommu: Adding device 15340000.vic to group 30
[ 0.447357] iommu: Adding device 154c0000.nvenc to group 31
[ 0.447574] iommu: Adding device 15480000.nvdec to group 32
[ 0.447917] iommu: Adding device 15380000.nvjpg to group 33
[ 0.448137] iommu: Adding device 15500000.tsec to group 34
[ 0.448353] iommu: Adding device 15100000.tsecb to group 35
[ 0.449032] iommu: Adding device 15810000.se to group 36
[ 0.449261] iommu: Adding device 15820000.se to group 37
[ 0.449494] iommu: Adding device 15830000.se to group 38
[ 0.449716] iommu: Adding device 15840000.se to group 39
[ 0.450591] iommu: Adding device smmu_test to group 40
[ 0.451192] mc: mapped MMIO address: 0xffffff800a710000 -> 0x2c10000
[ 0.451216] mc: mapped MMIO address: 0xffffff800a730000 -> 0x2c20000
[ 0.451237] mc: mapped MMIO address: 0xffffff800a750000 -> 0x2c30000
[ 0.451257] mc: mapped MMIO address: 0xffffff800a770000 -> 0x2c40000
[ 0.451276] mc: mapped MMIO address: 0xffffff800a790000 -> 0x2c50000
[ 0.451295] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.451315] mc-err: mcerr ops are set to t18x
[ 0.451468] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.452613] iommu: Adding device 3530000.xhci to group 41
[ 0.452641] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.453090] iommu: Adding device 3550000.xudc to group 42
[ 0.453114] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.453861] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.453881] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.454451] iommu: Adding device 17000000.gp10b to group 43
[ 0.455492] tegra-reset 5000000.clock: registered 193 resets.
[ 0.457716] iommu: Adding device d000000.bpmp to group 44
[ 0.457938] bpmp: ping status is 0
[ 0.458043] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.460530] bpmp d000000.bpmp: probe ok
[ 0.463658] iommu: Adding device 2600000.dma to group 45
[ 0.465016] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.468868] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.470580] iommu: Adding device sound to group 46
[ 0.470960] iommu: Adding device 3510000.hda to group 47
[ 0.478000] iommu: Adding device c1a0000.aon to group 48
[ 0.478448] vdd-ac-bat: 5000 mV
[ 0.480143] vdd-1v8-ap: 1800 mV
[ 0.506084] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.508775] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.508971] SCSI subsystem initialized
[ 0.509107] libata version 3.00 loaded.
[ 0.509263] usbcore: registered new interface driver usbfs
[ 0.509309] usbcore: registered new interface driver hub
[ 0.509381] usbcore: registered new device driver usb
[ 0.511529] random: fast init done
[ 0.519558] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.525594] vddio-ddr: at 1125 mV
[ 0.529429] avdd_dsi_csi: 1200 mV
[ 0.533429] vdd-1v8: 1800 mV
[ 0.537428] vdd-3v3-sys: 3300 mV
[ 0.538019] max77620-sd4: at 600 mV
[ 0.539022] spmic-ldo0: at 1800 mV
[ 0.539753] spmic-ldo1: at 800 mV
[ 0.541428] vddio-3v3: 3300 mV
[ 0.542046] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.545429] vdd-rtc: at 800 mV
[ 0.546194] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.549428] spmic-ldo6: at 1500 mV
[ 0.553428] vdd-pex-1v00: 1000 mV
[ 0.554083] dvdd-pex: 1000 mV
[ 0.556315] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.556481] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.556651] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.556840] max77620 4-003c: max77620 probe successful
[ 0.557220] media: Linux media interface: v0.10
[ 0.557258] Linux video capture interface: v2.00
[ 0.560925] pps_core: LinuxPPS API ver. 1 registered
[ 0.560939] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.560967] PTP clock support registered
[ 0.561167] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.561378] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.561441] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.562820] trusty trusty: trusty version: Built: 21:16:26 Jun 25 2020
[ 0.562853] trusty trusty: selected api version: 3 (requested 3)
[ 0.563645] Advanced Linux Sound Architecture Driver Initialized.
[ 0.563981] Bluetooth: Core ver 2.22
[ 0.564021] NET: Registered protocol family 31
[ 0.564035] Bluetooth: HCI device and connection manager initialized
[ 0.564051] Bluetooth: HCI socket layer initialized
[ 0.564065] Bluetooth: L2CAP socket layer initialized
[ 0.564088] Bluetooth: SCO socket layer initialized
[ 0.564674] en-vdd-sd: 3300 mV
[ 0.564901] en-vdd-cam: 1800 mV
[ 0.569410] vdd-hdmi: 5000 mV
[ 0.569759] vdd-usb0-5v: 5000 mV
[ 0.570000] vdd-usb1-5v: 5000 mV
[ 0.570235] en-vdd-ts-1v8: 1800 mV
[ 0.570471] en-vdd-ts-hv-3v3: 3300 mV
[ 0.570711] en-vdd-disp-3v3: 3300 mV
[ 0.570970] en-mdm-pwr-3v7: 3700 mV
[ 0.571220] en-vdd-disp-1v8: 1800 mV
[ 0.571471] en-vdd-cam-hv-2v8: 2800 mV
[ 0.571726] en-vdd-cam-1v2: 1200 mV
[ 0.572065] vdd-fan: 5000 mV
[ 0.572340] vdd-3v3: 3300 mV
[ 0.572610] dis-vdd-1v2: 1200 mV
[ 0.572879] en-vdd-vcm-2v8: 2800 mV
[ 0.573177] vdd-usb2-5v: 5000 mV
[ 0.573455] vdd-sys-bl: 3300 mV
[ 0.573737] en-vdd-sys: 1200 mV
[ 0.575841] camchar: rtcpu character device driver loaded
[ 0.576359] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.578131] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.578969] clocksource: Switched to clocksource arch_sys_counter
[ 0.601357] VFS: Disk quotas dquot_6.6.0
[ 0.601446] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.601696] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.602207] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.602227] nvmap_page_pool_init: Total RAM pages: 977877
[ 0.602240] nvmap_page_pool_init: nvmap page pool size: 122234 pages (477 MB)
[ 0.602320] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.604814] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.610495] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.610685] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.611104] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.611196] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.611318] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.611433] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.611610] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.611820] la/ptsa driver initialized.
[ 0.611838] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.611851] pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
[ 0.612167] NET: Registered protocol family 2
[ 0.612795] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.612972] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.613282] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.613343] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.613414] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.613691] NET: Registered protocol family 1
[ 0.614119] RPC: Registered named UNIX socket transport module.
[ 0.614137] RPC: Registered udp transport module.
[ 0.614149] RPC: Registered tcp transport module.
[ 0.614161] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.614176] PCI: CLS 0 bytes, default 64
[ 0.614294] Trying to unpack rootfs image as initramfs...
[ 0.780341] Freeing initrd memory: 5432K
[ 0.796066] host1x 13e10000.host1x: initialized
[ 0.797336] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.799449] audit: initializing netlink subsys (disabled)
[ 0.799487] audit: type=2000 audit(0.680:1): initialized
[ 0.799935] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.806419] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.807450] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.807967] 9p: Installing v9fs 9p2000 file system support
[ 0.810067] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.810165] io scheduler noop registered
[ 0.810373] io scheduler cfq registered (default)
[ 0.813576] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.917777] iommu: Adding device aconnect@2a41000:adsp_audio to group 49
[ 0.951699] iommu: Adding device 2993000.adsp to group 50
[ 0.952768] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.955054] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.958739] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.959969] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.961045] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.962114] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.964451] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.965400] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.965740] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.965767] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.965900] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.965922] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 0.969438] tsec 15500000.tsec: initialized
[ 0.970571] tsec 15100000.tsecb: initialized
[ 0.973976] nvdec 15480000.nvdec: initialized
[ 0.980091] falcon 15340000.vic: initialized
[ 0.981496] falcon 154c0000.nvenc: initialized
[ 0.982876] falcon 15380000.nvjpg: initialized
[ 0.984705] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.986072] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.987460] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.988802] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.990142] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.991527] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.992858] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.994192] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.997422] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.997446] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.997483] tegradccommon 15200000.dc_common: dma mapping done
[ 0.997586] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=384
[ 0.998111] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.998169] generic_infoframe_type: 0x87
[ 0.998251] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.998275] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 0.998278] tegradc 15210000.nvdisplay: Display dc.ffffff800abe0000 registered with id=0
[ 0.998506] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 0.998533] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 0.998691] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 0.998706] tegra_cec 3960000.tegra_cec: probed
[ 1.006794] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.006820] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.006840] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.007041] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.007061] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.010574] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.010597] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.013240] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.013906] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.013961] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.014417] kfuse 3830000.kfuse: initialized
[ 1.015760] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.019179] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.021681] console [ttyS0] disabled
[ 1.021739] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 35, base_baud = 25500000) is a Tegra
[ 1.043352] Reserved SVD code 0
[ 1.043354] Reserved SVD code 0
[ 1.043355] Reserved SVD code 0
[ 1.045848] tegradc 15210000.nvdisplay: probed
[ 1.390446] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.794609] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.007577] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.007581] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.198760] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.200777] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.303525] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 2.303770] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.363478] console [ttyS0] enabled
[ 3.363834] Console: switching to colour frame buffer device 240x67
[ 3.365157] [drm] Initialized
[ 3.376787] tegradc 15210000.nvdisplay: fb registered
[ 3.382128] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.385790] brd: module loaded
[ 3.389122] loop: module loaded
[ 3.389186] tegra_profiler: version: 1.141, samples/io: 48/28
[ 3.389258] tegra_profiler: auth: init
[ 3.389860] THERMAL EST: found 3 subdevs
[ 3.389863] THERMAL EST num_resources: 0
[ 3.389866] [THERMAL EST subdev 0]
[ 3.389869] [THERMAL EST subdev 1]
[ 3.389872] [THERMAL EST subdev 2]
[ 3.390124] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.390126] THERMAL EST: thz register success.
[ 3.390209] THERMAL EST: end of probe, return err: 0
[ 3.390808] sd: No Scsi addr parsed to reserve index
[ 3.390829] hisi_sas: driver version v1.6
[ 3.449176] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3.455309] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3.462354] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 3.475244] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.475648] Parent Clock set for DC plld2
[ 3.479358] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 3.480593] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 3.480599] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 3.510702] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.512328] Reserved SVD code 0
[ 3.512330] Reserved SVD code 0
[ 3.512332] Reserved SVD code 0
[ 3.515870] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 3.515872] Extcon AUX1(HDMI) enable
[ 3.541138] scsi host0: tegra_ahci
[ 3.544936] scsi host1: tegra_ahci
[ 3.548501] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.556432] ata2: DUMMY
[ 3.564090] libphy: Fixed MDIO Bus: probed
[ 3.568901] tun: Universal TUN/TAP device driver, 1.6
[ 3.573974] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.580831] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.586685] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.592647] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.599615] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.605227] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.613060] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.619074] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.626066] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.643051] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 3.653701] eqos_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac: null.
[ 3.661816] eqos 2490000.ether_qos (unnamed net_device) (uninitialized): ether-mac read from DT failed -99
[ 3.665483] Reserved SVD code 0
[ 3.665485] Reserved SVD code 0
[ 3.665486] Reserved SVD code 0
[ 3.680908] eqos 2490000.ether_qos (unnamed net_device) (uninitialized): EQOS using random MAC address: ee:7f:cb:8e:ae:46
[ 3.680924] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.681012] libphy: dwc_phy: probed
[ 3.681308] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.683262] PPP generic driver version 2.4.2
[ 3.683381] PPP BSD Compression module registered
[ 3.683383] PPP Deflate Compression module registered
[ 3.683396] PPP MPPE Compression module registered
[ 3.683399] NET: Registered protocol family 24
[ 3.683440] usbcore: registered new interface driver r8152
[ 3.683473] usbcore: registered new interface driver asix
[ 3.683503] usbcore: registered new interface driver ax88179_178a
[ 3.683529] usbcore: registered new interface driver cdc_ether
[ 3.683556] usbcore: registered new interface driver net1080
[ 3.683581] usbcore: registered new interface driver cdc_subset
[ 3.683609] usbcore: registered new interface driver zaurus
[ 3.683652] usbcore: registered new interface driver cdc_ncm
[ 3.683778] VFIO - User Level meta-driver version: 0.3
[ 3.684605] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.684615] ehci-pci: EHCI PCI platform driver
[ 3.684645] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.684650] ohci-pci: OHCI PCI platform driver
[ 3.684677] ohci-platform: OHCI generic platform driver
[ 3.689375] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 3.691067] tegra-xusb 3530000.xhci: extcon 0: ffffffc0f11d8400 id
[ 3.691760] usbcore: registered new interface driver uas
[ 3.691798] usbcore: registered new interface driver usb-storage
[ 3.691862] usbcore: registered new interface driver usbserial
[ 3.693464] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 3.696188] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.697174] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 3.719004] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 3.719019] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 3.719722] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 3.719749] tegra-xusb 3530000.xhci: irq 66, io mem 0x03530000
[ 3.719878] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.719882] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.719885] usb usb1: Product: xHCI Host Controller
[ 3.719888] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.719890] usb usb1: SerialNumber: 3530000.xhci
[ 3.720223] hub 1-0:1.0: USB hub found
[ 3.720252] hub 1-0:1.0: 4 ports detected
[ 3.720585] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 3.720593] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 3.720716] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.720720] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.720723] usb usb2: Product: xHCI Host Controller
[ 3.720725] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.720728] usb usb2: SerialNumber: 3530000.xhci
[ 3.721010] hub 2-0:1.0: USB hub found
[ 3.721038] hub 2-0:1.0: 3 ports detected
[ 3.730755] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 3.730757] Extcon AUX1(HDMI) disable
[ 3.757221] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 3.757704] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 3.761960] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 3.824772] usb usb1: usb_suspend_both: status 0
[ 3.874688] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.888444] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 3.888466] tegra-usb-cd usb_cd: connected to SDP
[ 3.888592] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 3.889791] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 3.894909] mousedev: PS/2 mouse device common for all mice
[ 3.895583] usbcore: registered new interface driver xpad
[ 4.042581] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.051723] Wake73 for irq=42
[ 4.053964] rtc rtc1: alarm rtc device
[ 4.054094] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.054230] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.056026] i2c /dev entries driver
[ 4.066627] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 4.090962] parse_throttle_dt_data: Num cap clks = 4
[ 4.091111] parse_throttle_dt_data: clk=mcpu type=1
[ 4.091119] parse_throttle_dt_data: clk=bcpu type=2
[ 4.091195] parse_throttle_dt_data: clk=gpu type=4
[ 4.091200] parse_throttle_dt_data: clk=emc type=3
[ 4.096304] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.099789] FAN dev name: pwm-fan
[ 4.100233] FAN:gpio request success.
[ 4.100279] FAN: can't find tach_gpio
[ 4.100538] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.101732] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.101748] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.107293] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.107300] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.107307] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.107311] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.107313] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.107317] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.107320] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.107323] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.107326] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.107329] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.112126] device-mapper: uevent: version 1.0.3
[ 4.113896] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.116006] CPU EMC frequency mapping table: default setting
[ 4.133922] cpufreq: platform driver Initialization: pass
[ 4.134497] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.134614] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.135278] tegradc 15210000.nvdisplay: unblank
[ 4.135463] sdhci: Secure Digital Host Controller Interface driver
[ 4.135465] sdhci: Copyright(c) Pierre Ossman
[ 4.135466] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.136320] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.136485] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.136589] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 4.137889] Parent Clock set for DC plld2
[ 4.138880] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.141277] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4.141856] CMDQ: cmdq_platfm_init successful
[ 4.142630] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4.142636] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.143158] CQE: CMD_TIMING bit set for R1B DCMD
[ 4.145648] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.152680] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.158653] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.159519] tegra-se-nvhost 15810000.se: initialized
[ 4.160592] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.161170] tegra-se-nvhost 15820000.se: initialized
[ 4.162081] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.162629] tegra-se-nvhost 15830000.se: initialized
[ 4.163450] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.164039] tegra-se-nvhost 15840000.se: initialized
[ 4.164915] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.165154] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.166088] usbcore: registered new interface driver usbhid
[ 4.166089] usbhid: USB HID core driver
[ 4.168733] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.170940] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 4.171252] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.171398] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 4.171622] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 4.172427] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 4.172520] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 4.172600] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 4.172669] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 4.172806] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 4.173144] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (47)
[ 4.173146] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.173697] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 4.174464] Reserved SVD code 0
[ 4.174466] Reserved SVD code 0
[ 4.174467] Reserved SVD code 0
[ 4.175300] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.175728] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.175888] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.175958] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.176275] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176278] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 4.176279] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.176335] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176337] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 4.176338] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.176385] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176387] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 4.176388] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.176435] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176437] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 4.176438] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.176482] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176484] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 4.176485] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.176529] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176533] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 4.176534] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.176578] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176583] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 4.176584] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.176628] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176632] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 4.176634] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.176678] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176682] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 4.176683] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 4.176727] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176729] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 4.176730] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 4.176775] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176779] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 4.176781] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 4.176827] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176831] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 4.176833] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 4.176879] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176883] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 4.176885] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 4.176936] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176940] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 4.176942] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 4.176987] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.176991] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 4.176992] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 4.177047] **** A57 ECC: Enabled
[ 4.177049] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 4.177107] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 4.177544] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.177944] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 4.178063] denver_knobs_init:MTS_VERSION:47926945
[ 4.178071] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.178073] Extcon AUX1(HDMI) enable
[ 4.179940] nvpmodel: initialized successfully
[ 4.180809] trusty-virtio trusty:virtio: initializing
[ 4.180911] trusty_ipc virtio0: vring0: va(pa) ffffffc0eb1b0000(0) qsz 32 notifyid 1
[ 4.180919] trusty_ipc virtio0: vring1: va(pa) ffffffc0eb1b2000(0) qsz 32 notifyid 2
[ 4.180982] trusty-virtio trusty:virtio: initializing done
[ 4.181075] trusty_ipc virtio0: is online
[ 4.182206] usbcore: registered new interface driver snd-usb-audio
[ 4.183012] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.194991] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.202981] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.206339] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.206459] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.214562] OPE platform probe
[ 4.214627] OPE platform probe successful
[ 4.224785] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.238637] mmc0: periodic cache flush enabled
[ 4.238646] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.243086] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 4.247230] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 4.251580] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 4.255746] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 4.262889] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 4.264377] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.264451] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.264519] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.264582] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.264647] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.264711] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.264778] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.264841] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.264905] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.264970] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.265034] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.265101] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.265166] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.265231] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.265301] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.265376] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.265451] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.265551] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.265618] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.265681] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.285954] u32 classifier
[ 4.285955] Actions configured
[ 4.286012] Initializing XFRM netlink socket
[ 4.286550] NET: Registered protocol family 10
[ 4.287138] NET: Registered protocol family 17
[ 4.287146] NET: Registered protocol family 15
[ 4.287201] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.287244] Bluetooth: RFCOMM socket layer initialized
[ 4.287252] Bluetooth: RFCOMM ver 1.11
[ 4.287255] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.287259] Bluetooth: HIDP socket layer initialized
[ 4.287273] 9pnet: Installing 9P2000 support
[ 4.287305] Key type dns_resolver registered
[ 4.287577] Registered cp15_barrier emulation handler
[ 4.287596] Registered setend emulation handler
[ 4.288414] registered taskstats version 1
[ 4.292038] isp 15600000.isp: initialized
[ 4.296607] nvcsi 150c0000.nvcsi: initialized
[ 4.298299] tegra-vi4 15700000.vi: using default number of vi channels,15
[ 4.302524] tegra-vi4 15700000.vi: initialized
[ 4.302530] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.302606] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.302677] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.302800] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.303576] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 4.303579] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 4.335669] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:15 UTC (946688415)
[ 4.336921] mmcblk mmc0:0001: Card claimed for testing.
[ 4.365173] bpmp: mounted debugfs mirror
[ 4.366529] bwmgr: missing cdev-type property
[ 4.371796] spmic-ldo0: disabling
[ 4.371955] spmic-ldo1: disabling
[ 4.372099] vdd-usb0-5v: disabling
[ 4.372104] vdd-fan: disabling
[ 4.372106] vdd-3v3: disabling
[ 4.372108] en-vdd-vcm-2v8: disabling
[ 4.372110] vdd-sys-bl: disabling
[ 4.372112] ALSA device list:
[ 4.372114] #0: tegra-hda at 0x3518000 irq 379
[ 4.372115] #1: tegra-snd-t186ref-mobile-rt565x
[ 6.847234] Wake76 for irq=199
[ 6.847235] Wake77 for irq=199
[ 6.847236] Wake78 for irq=199
[ 6.847237] Wake79 for irq=199
[ 6.847238] Wake80 for irq=199
[ 6.847239] Wake81 for irq=199
[ 6.847240] Wake82 for irq=199
[ 6.847264] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 6.847268] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 6.951101] usb usb2: usb_suspend_both: status 0
[ 8.351577] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 8.353897] Freeing unused kernel memory: 8576K
[ 8.365452] Extcon HDMI: HPD enabled
[ 8.365475] tegradc 15210000.nvdisplay: hdmi: plugged
[ 8.395307] Root device found: mmcblk0p1
[ 8.401211] Found dev node: /dev/mmcblk0p1
[ 8.449979] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 8.456456] EXT4-fs (mmcblk0p1): recovery complete
[ 8.467413] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.477398] Rootfs mounted over mmcblk0p1
[ 8.500231] Switching from initrd to actual rootfs
[ 8.598478] systemd[1]: System time before build time, advancing clock.
[ 8.622207] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.637443] cgroup: cgroup2: unknown option "nsdelegate"
[ 8.651836] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.676959] systemd[1]: Detected architecture arm64.
[ 8.701815] systemd[1]: Set hostname to <linux>.
[ 8.785952] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.804648] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.890985] tegra-xusb 3530000.xhci: entering ELPG
[ 8.899955] tegra-xusb 3530000.xhci: entering ELPG done
[ 8.930448] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.938747] systemd[1]: Reached target Swap.
[ 8.944881] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.953324] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.962565] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.970823] systemd[1]: Reached target User and Group Name Lookups.
[ 8.980116] systemd[1]: Created slice System Slice.
[ 8.986888] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.052146] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.270239] systemd-journald[2225]: Received request to flush runtime journal from PID 1
[ 9.778650] using random self ethernet address
[ 9.791411] using random host ethernet address
[ 9.835844] random: crng init done
[ 9.840915] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.296236] Mass Storage Function, version: 2009/09/11
[ 10.324559] LUN: removable file: (no medium)
[ 10.336376] using random self ethernet address
[ 10.354465] using random host ethernet address
[ 10.391387] rndis0: HOST MAC 1a:da:05:a7:b3:ec
[ 10.398682] rndis0: MAC 1a:da:05:a7:b3:ed
[ 10.405648] usb0: HOST MAC 1a:da:05:a7:b3:ee
[ 10.412177] usb0: MAC 1a:da:05:a7:b3:ef
[ 10.418464] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 10.457288] tegra-xusb 3530000.xhci: exiting ELPG
[ 10.467020] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 10.479207] tegra-xusb 3530000.xhci: exiting ELPG done
[ 10.498379] l4tbr0: port 1(rndis0) entered blocking state
[ 10.512959] l4tbr0: port 1(rndis0) entered disabled state
[ 10.521075] device rndis0 entered promiscuous mode
[ 10.565500] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 10.598317] l4tbr0: port 2(usb0) entered blocking state
[ 10.606819] l4tbr0: port 2(usb0) entered disabled state
[ 10.615574] device usb0 entered promiscuous mode
[ 10.636482] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.650201] android_work: did not send uevent (0 0 (null))
[ 10.683131] android_work: sent uevent USB_STATE=CONNECTED
[ 10.711021] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 10.739824] usb 1-2: New USB device found, idVendor=0424, idProduct=2807
[ 10.748846] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.758379] usb 1-2: Product: USB2807 Hub
[ 10.764527] usb 1-2: Manufacturer: Microchip
[ 10.772191] hub 1-2:1.0: USB hub found
[ 10.778308] hub 1-2:1.0: 7 ports detected
[ 10.794640] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.851737] CPU1: shutdown
[ 10.856538] psci: CPU1 killed.
[ 10.860286] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 10.880720] usb 2-1: New USB device found, idVendor=0424, idProduct=5807
[ 10.889566] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.899246] usb 2-1: Product: USB5807 Hub
[ 10.900509] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 10.904501] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.920741] usb 2-1: Manufacturer: Microchip
[ 10.938443] hub 2-1:1.0: USB hub found
[ 10.945364] CPU2: shutdown
[ 10.945787] hub 2-1:1.0: 7 ports detected
[ 10.957898] psci: CPU2 killed.
[ 10.983017] usb 1-2: usb_suspend_both: status 0
[ 10.989925] usb usb1: usb_suspend_both: status 0
[ 11.060408] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.094058] android_work: sent uevent USB_STATE=CONNECTED
[ 11.107003] usb 2-1: usb_suspend_both: status 0
[ 11.113518] usb usb2: usb_suspend_both: status 0
[ 11.149039] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.192801] android_work: sent uevent USB_STATE=CONNECTED
[ 11.240627] zram: Added device: zram0
[ 11.252289] zram: Added device: zram1
[ 11.263361] zram: Added device: zram2
[ 11.275832] zram: Added device: zram3
[ 11.308131] zram0: detected capacity change from 0 to 502468608
[ 11.350999] Adding 490688k swap on /dev/zram0. Priority:5 extents:1 across:490688k SS
[ 11.375492] zram1: detected capacity change from 0 to 502468608
[ 11.384042] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.413002] Adding 490688k swap on /dev/zram1. Priority:5 extents:1 across:490688k SS
[ 11.416778] android_work: sent uevent USB_STATE=CONNECTED
[ 11.444770] zram2: detected capacity change from 0 to 502468608
[ 11.463539] Adding 490688k swap on /dev/zram2. Priority:5 extents:1 across:490688k SS
[ 11.471823] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.493687] zram3: detected capacity change from 0 to 502468608
[ 11.514841] android_work: sent uevent USB_STATE=CONNECTED
[ 11.521308] Adding 490688k swap on /dev/zram3. Priority:5 extents:1 across:490688k SS
[ 11.694111] configfs-gadget gadget: high-speed config #1: c
[ 11.701336] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 11.709845] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 11.718265] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 11.726826] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 11.735253] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 11.743437] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 11.751741] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 11.759986] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 11.768315] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 11.772679] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 11.784669] android_work: sent uevent USB_STATE=CONFIGURED
[ 12.289656] tegradc 15210000.nvdisplay: blank - powerdown
[ 12.295854] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 12.295870] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 12.296007] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 12.300340] tegra-xudc-new 3550000.xudc: ep 13 disabled
[ 12.300432] tegra-xudc-new 3550000.xudc: ep 8 disabled
[ 12.329094] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 12.329110] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 12.342820] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 12.342822] Extcon AUX1(HDMI) disable
[ 12.364869] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 12.364950] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 12.365608] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 12.445084] tegradc 15210000.nvdisplay: unblank
[ 12.447452] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 12.447546] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 12.447632] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 12.449054] Parent Clock set for DC plld2
[ 12.452289] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 12.453600] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 12.453607] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 12.485740] Reserved SVD code 0
[ 12.485742] Reserved SVD code 0
[ 12.485743] Reserved SVD code 0
[ 12.489452] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 12.489455] Extcon AUX1(HDMI) enable
[ 12.559929] tegradc 15210000.nvdisplay: unblank
[ 12.951421] tegra-xusb 3530000.xhci: entering ELPG
[ 12.959437] tegra-xusb 3530000.xhci: entering ELPG done
[ 13.027793] fuse init (API version 7.26)
Ubuntu 18.04.4 LTS linux ttyS0
linux login: [ 14.040294] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.049382] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.866270] l4tbr0: port 2(usb0) entered blocking state
[ 14.871513] l4tbr0: port 2(usb0) entered forwarding state
[ 14.876970] l4tbr0: port 1(rndis0) entered blocking state
[ 14.882388] l4tbr0: port 1(rndis0) entered forwarding state
[ 14.888539] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 15.051021] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
