In using CentOS 7 with the latest NVIDIA K4000 and drivers (390.67 & 396.18 beta) and kernel 3.10-862.2.3 or 3.10-862.3.3, you end up with Xid 69: Illegal Class Error and the X server will not start. It fails trying to allocate memory.
Yet if I backout to 3.10-693.19 and 384.90 everything starts to work once more.
I tried 340.107 with the newer kernels and it once more failed, so I think it is the integration with the kernel. I could not try 384.90 with the newer kernels due to compile issues.
Any ideas how to solve, I rather use the later kernels.
However, nvidia-smi worked just fine. So I know you can access the device, but X would not start due to the Illegal Class Error.
xorg.conf contains:
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
FontPath "/usr/share/fonts/default/Type1"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-0"
HorizSync 30.0 - 200.0
VertRefresh 40.0 - 300.0
ModeLine "1920x1080_60.00" 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync
ModeLine "1920x1200_60.00" 193.16 1920 2048 2256 2592 1200 1201 1204 1242 -hsync +vsync
ModeLine "1920x1440_60.00" 234.59 1920 2064 2272 2624 1440 1441 1444 1490 -hsync +vsync
ModeLine "2048x1152_60.00" 197.97 2048 2184 2408 2768 1152 1153 1156 1192 -hsync +vsync
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro K4000"
BusID "PCI:0:5:0"
Option "ConnectToAcpid" "off"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "CustmEDID" "CRT-0:/etc/X11/asus.bin"
Option "DPI" "96 x 96"
Option "metamodes" "1920x1080_60.00 +0+0; nvidia-auto-select +0+0; 1280x1024_60 +0+0; 1024x768_60 +0+0; 800x600 +0+0; 640x480 +0+0; 1280x1024 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
There are no module settings for the nvidia drivers.
Error in /var/log/messages
Jun 20 17:32:37 liberte kernel: NVRM: Xid (PCI:0000:00:05): 69, Illegal Class Error: ChID 0008, Class 00000000, Offset 0000010c, Data 00000000
Error in Xorg.0.log
Failed to allocate sofware rendering cache surface: out of memory error.
Thank you,
Texiwill
