Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.3.10904
Host Machine Version
Hi, I am trying to create a CGF node that performs object detection and tracking. I called this node detectAndTrack.
Since /usr/local/driveworks-5.14/samples/src/dnn/sample_object_detector_tracker/main.cpp already does this, I decide to copy the its core parts into a CGF node. So, onInitialize method has become part of the detectAndTrack constructor, onProcess has become the detectAndTrack::processPass and so no.
Since I implemented this node step by step I am sure that the detection part works correctly, but as soon as I added the tracking part the application gets stuck. By adding several logs to the code I realized that the line where the app gets stuck is this one:
CHECK_DW_ERROR(dwFeatureHistoryArray_copyAsync(&m_featureHistoryCPU, &m_featureHistoryGPU, 0));
This is how I initialized and use m_featureHistoryCPU and m_featureHistoryGPU, which is the same way as sample_object_detector_tracker/main.cpp from above does:
From detectAndTrackImpl.hpp
dwContextHandle_t m_sdk = DW_NULL_HANDLE;
uint32_t m_maxFeatureCount;
uint32_t m_historyCapacity;
dwFeatureHistoryArray m_featureHistoryCPU = {};
dwFeatureHistoryArray m_featureHistoryGPU = {};
From detectAndTrackImpl.cpp
// detectAndTrackImpl::initialize() {
dwContextParameters sdkParams = {};
CHECK_DW_ERROR(dwInitialize(&m_sdk, DW_VERSION, &sdkParams));
m_historyCapacity = 3;
m_maxFeatureCount = 2000;
CHECK_DW_ERROR(dwFeatureHistoryArray_createNew(&m_featureHistoryCPU, m_maxFeatureCount, m_historyCapacity, DW_MEMORY_TYPE_CPU, nullptr, m_sdk));
CHECK_DW_ERROR(dwFeatureHistoryArray_createNew(&m_featureHistoryGPU, m_maxFeatureCount, m_historyCapacity, DW_MEMORY_TYPE_CUDA, nullptr, m_sdk));
// } // end detectAndTrackImpl::initialize()
// detectAndTrackImpl::trackFeatures() { // called from runTracker(), called from processPass()
// **This is the line where the code gets stuck:**
// } // end detectAndTrackImpl::trackFeatures()
Here there are CGF logs:
launcher.log
[22-01-2024 12:20:40] [INFO] Current State of schedule_manager: PRE_READY
[22-01-2024 12:20:40] [INFO] Current State of schedule_manager: READY
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX96712 Link 1: PHY optimization was enabled
MAX96712 Link 2: PHY optimization was enabled
MAX96712 Link 3: PHY optimization was enabled
MAX9295: Revision 8 detected!
Sensor AR0820 GRBG Rev 2.1 detected!
SSM_LATENCY::4 mainClient
SSM_LATENCY::0 1849ms
SSM_LATENCY::9 mainClient_runStateMachine
SSM_LATENCY::0 1850ms
[2024-01-22T11:21:06.114649Z][INFO][tid:0][Launcher.cpp:1198][Launcher] Got signal: 15 (Terminated), si_pid: 5569
[2024-01-22T11:21:06.114766Z][INFO][tid:0][Launcher.cpp:1205][Launcher] This is user exit signal: 15. Wait for gracefully exit done.
[STM ERROR]:[av/stm/runtime/src/core/synchronization.c][stmCondSemTimedWaitForValue] [122]: CondSem Wait Timed Out. err=5
[STM ERROR]:[av/stm/runtime/src/client/sync.c][stmFenceWait] [72]: Could not wait on stmOsFence f47 in iteration: 1 stmError=5
[STM ERROR]:[av/stm/runtime/src/client/commands/wof.c][opExecuteWof] [28]: [Thread pool6] [Time 12:22:02.640778320] Fence timeout: f47. Iteration: 1
[STM ERROR]:[av/stm/runtime/src/client/stm.c][stmEnterScheduler] [1105]: Thread 0 [pool1] did not terminate (currently at command #86)
[STM] Starting thread pool0
[STM] Starting thread pool1
[STM] Starting thread pool2
[STM] Starting thread pool3
[STM] Starting thread pool4
[STM] Starting thread pool5
[STM] Starting thread pool6
[STM] Starting thread pool7
[STM] Starting thread pool8
[STM] Current thread stopCount = 1, time: 12:21:06.134758756
[STM] Thread pool0 exiting, thread exit count 2, time: 12:21:06.134781508
[STM] Thread pool6 exiting, thread exit count 6, time: 12:22:02.640794064
[STM INFO]:[av/stm/runtime/src/client/commands/cusub.c][opPrintCusub] [CORE 1] [Time 12:22:02.640874833] CUSUB Stuck at: f43, CUDA_STREAM0, miniPipeline_detectAndTrack_pass_1
[STM ERROR]:[av/stm/runtime/src/client/commands/wof.c][opExecuteWof] [28]: [Thread pool7] [Time 12:22:02.640911890] Fence timeout: f47. Iteration: 1
[STM ERROR]:[av/stm/runtime/src/client/commands/wof.c][opExecuteWof] [28]: [Thread pool8] [Time 12:22:02.641022259] Fence timeout: f47. Iteration: 1
[STM ERROR]:[av/stm/runtime/src/client/commands/wof.c][opExecuteWof] [28]: [Thread pool4] [Time 12:22:02.641105396] Fence timeout: f47. Iteration: 1
[STM ERROR]:[av/stm/runtime/src/client/stm.c][stmEnterScheduler] [1105]: Thread 0 [pool2] did not terminate (currently at command #13)
[STM] Thread pool7 exiting, thread exit count 7, time: 12:22:02.640952594
[STM] Thread pool8 exiting, thread exit count 8, time: 12:22:02.641042355
[STM] Thread pool4 exiting, thread exit count 9, time: 12:22:02.641125076
[STM INFO]:[av/stm/runtime/src/client/commands/wof.c][opPrintWof] [CORE 2] [Time 12:22:02.641175605] WOF Stuck at: f17
[STM ERROR]:[av/stm/runtime/src/client/stm.c][stmEnterScheduler] [1105]: Thread 0 [pool3] did not terminate (currently at command #3)
[STM INFO]:[av/stm/runtime/src/client/commands/wof.c][opPrintWof] [CORE 3] [Time 12:22:02.641254582] WOF Stuck at: f16
[STM ERROR]:[av/stm/runtime/src/client/stm.c][stmEnterScheduler] [1105]: Thread 0 [pool5] did not terminate (currently at command #0)
[STM INFO]:[av/stm/runtime/src/client/commands/wof.c][opPrintWof] [CORE 5] [Time 12:22:02.641299062] WOF Stuck at: f47
FATAL: exception not rethrown
***** Backtrace disabled *****
[2024-01-22T11:22:03.247126Z][INFO][tid:0][Launcher.cpp:1198][Launcher] Got signal: 17 (Child exited), si_pid: 5596
[2024-01-22T11:22:03.247219Z][DEBUG][tid:0][Launcher.cpp:1270][Launcher] Sending SIGINT: /usr/local/driveworks/bin//ScheduleManager, name: schedule_manager
[2024-01-22T11:22:03.247367Z][FATAL][tid:0][Launcher.cpp:1039][Launcher] Process mainClient:5596 terminated by signal: 6 (Aborted)
[2024-01-22T11:22:03.247393Z][ERROR][tid:0][Launcher.cpp:1299][Launcher] There is child process exited abnormally.
[2024-01-22T11:22:03.247415Z][ERROR][tid:0][Launcher.cpp:1392][Launcher] Running processes:
[2024-01-22T11:22:03.247426Z][ERROR][tid:0][Launcher.cpp:1397][Launcher] ssm: 5595
[2024-01-22T11:22:03.247436Z][ERROR][tid:0][Launcher.cpp:1397][Launcher] schedule_manager: 5597
[2024-01-22T11:22:03.247445Z][ERROR][tid:0][Launcher.cpp:1397][Launcher] stm_master: 5598
[2024-01-22T11:22:03.247456Z][ERROR][tid:0][Launcher.cpp:1356][Launcher] Killing all live child processes with SIGTERM...
[STM][ERROR] sem_timedwait failed; errno: 4 (Interrupted system call)
[STM ERROR]:[av/stm/runtime/src/core/comm.c][stmReceiveStateData] [63]: recv failed to receive state data
[STM ERROR]:[av/stm/runtime/src/core/state.c][recvGlobalScheduleState] [701]: Could not receive updated schedule state from Master
av/stm/runtime/src/core/state.c:702 assertion failure, errno=4 (Interrupted system call)
[2024-01-22T11:22:03.257316Z][FATAL][tid:0][Launcher.cpp:1039][Launcher] Process schedule_manager:5597 terminated by signal: 6 (Aborted)
[2024-01-22T11:22:03.298195Z][FATAL][tid:0][Launcher.cpp:1039][Launcher] Process ssm:5595 terminated by signal: 15 (Terminated)
[2024-01-22T11:22:33.298373Z][ERROR][tid:0][Launcher.cpp:1327][Launcher] sigtimedwait() timeout.
[2024-01-22T11:22:33.298499Z][ERROR][tid:0][Launcher.cpp:1384][Launcher] Killing all live child processes with SIGKILL...
[2024-01-22T11:22:33.300750Z][FATAL][tid:0][Launcher.cpp:1039][Launcher] Process stm_master:5598 terminated by signal: 9 (Killed)
[2024-01-22T11:22:33.300803Z][INFO][tid:0][Launcher.cpp:1095][Launcher] waitForChildExit: No more child process!
[2024-01-22T11:22:33.300859Z][ERROR][tid:0][Launcher.cpp:1345][Launcher] All child processes has been killed successfully.
[2024-01-22T11:22:33.300910Z][FATAL][tid:0][Launcher.cpp:1565][Launcher] launcher exit status: 33
[2024-01-22T11:22:33.300985Z][DEBUG][tid:0][Launcher.cpp:1589][Launcher] swc_list.txt content:
line 1 : mainClient,127.0.0.1
line 2 : schedule_manager,127.0.0.1
line 3 :
[2024-01-22T11:22:33.301222Z][ERROR][tid:0][Launcher.cpp:1601][Launcher] Failed to remove SWC/SSM temp files: Inappropriate ioctl for device
mainClient_0.log
mainClient_0.log (4.5 MB)
ssm.log
Finding port: schedule_manager
<13>1 2024-01-22T12:20:40.438044+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:180][SSM] [SSM] clients ready
<13>1 2024-01-22T12:20:40.438107+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] SSMStart: [1705922440438]
<13>1 2024-01-22T12:20:40.438205+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:104][SSM] [SSM] run pre init
<13>1 2024-01-22T12:20:40.438258+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Current State of SSM: PRE_INIT
<13>1 2024-01-22T12:20:40.438306+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: SSM => PRE_INIT [1705922440438]
<13>1 2024-01-22T12:20:40.441962+01:00 - ssm 5595 - - [0us][DEBUG][tid:1][vanilla_main.cpp:98][SSM] SSM Server Init Signalling: 2 2
<13>1 2024-01-22T12:20:40.442114+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: mainClient => PRE_INIT [1705922440441979]
<13>1 2024-01-22T12:20:40.448514+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: schedule_manager => PRE_INIT [1705922440448456]
<13>1 2024-01-22T12:20:40.452248+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:106][SSM] [SSM] pre init completed
<13>1 2024-01-22T12:20:40.452269+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:108][SSM] [SSM] run init
<13>1 2024-01-22T12:20:40.452294+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitBroadcast: SSM => INIT [1705922440452]
<13>1 2024-01-22T12:20:40.452312+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] InitBroadcast: SSM => INIT [1705922440452] [mainClient,schedule_manager,]
<13>1 2024-01-22T12:20:40.468919+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: schedule_manager => INIT [1705922440468843]
<13>1 2024-01-22T12:20:40.502534+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Current State of SSM: INIT
<13>1 2024-01-22T12:20:40.502652+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: SSM => INIT [1705922440502]
<13>1 2024-01-22T12:20:40.502737+01:00 - ssm 5595 - - [0us][DEBUG][tid:1][vanilla_main.cpp:98][SSM] SSM Server Init Signalling: 2 2
<13>1 2024-01-22T12:20:40.561680+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: mainClient => INIT [1705922440561591]
<13>1 2024-01-22T12:20:40.563378+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:110][SSM] [SSM] init completed
<13>1 2024-01-22T12:20:40.563401+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:112][SSM] [SSM] run post init
<13>1 2024-01-22T12:20:40.563431+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitBroadcast: SSM => POST_INIT [1705922440563]
<13>1 2024-01-22T12:20:40.563450+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] InitBroadcast: SSM => POST_INIT [1705922440563] [mainClient,schedule_manager,]
<13>1 2024-01-22T12:20:40.580311+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: schedule_manager => POST_INIT [1705922440580229]
<13>1 2024-01-22T12:20:40.613735+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Current State of SSM: POST_INIT
<13>1 2024-01-22T12:20:40.613836+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: SSM => POST_INIT [1705922440613]
<13>1 2024-01-22T12:20:40.613910+01:00 - ssm 5595 - - [0us][DEBUG][tid:1][vanilla_main.cpp:98][SSM] SSM Server Init Signalling: 2 2
<13>1 2024-01-22T12:20:40.641722+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: mainClient => POST_INIT [1705922440641640]
<13>1 2024-01-22T12:20:40.644187+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:114][SSM] [SSM] post init completed
<13>1 2024-01-22T12:20:40.644212+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:116][SSM] [SSM] run pre ready
<13>1 2024-01-22T12:20:40.644237+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitBroadcast: SSM => PRE_READY [1705922440644]
<13>1 2024-01-22T12:20:40.644254+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] InitBroadcast: SSM => PRE_READY [1705922440644] [mainClient,schedule_manager,]
<13>1 2024-01-22T12:20:40.661532+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: schedule_manager => PRE_READY [1705922440661452]
<13>1 2024-01-22T12:20:40.662404+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: mainClient => PRE_READY [1705922440662328]
<13>1 2024-01-22T12:20:40.662448+01:00 - ssm 5595 - - [0us][DEBUG][tid:1][vanilla_main.cpp:98][SSM] SSM Server Init Signalling: 2 2
<13>1 2024-01-22T12:20:40.662509+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Current State of SSM: PRE_READY
<13>1 2024-01-22T12:20:40.662573+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: SSM => PRE_READY [1705922440662]
<13>1 2024-01-22T12:20:40.662587+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:118][SSM] [SSM] pre ready completed
<13>1 2024-01-22T12:20:40.662595+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:120][SSM] [SSM] run ready
<13>1 2024-01-22T12:20:40.662611+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitBroadcast: SSM => READY [1705922440662]
<13>1 2024-01-22T12:20:40.662626+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] InitBroadcast: SSM => READY [1705922440662] [mainClient,schedule_manager,]
<13>1 2024-01-22T12:20:40.681854+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: schedule_manager => READY [1705922440681779]
<13>1 2024-01-22T12:20:40.712816+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Current State of SSM: READY
<13>1 2024-01-22T12:20:40.712899+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: SSM => READY [1705922440712]
<13>1 2024-01-22T12:20:40.712984+01:00 - ssm 5595 - - [0us][DEBUG][tid:1][vanilla_main.cpp:98][SSM] SSM Server Init Signalling: 2 2
<13>1 2024-01-22T12:20:42.532238+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] InitPhaseComplete: mainClient => READY [1705922442532144]
<13>1 2024-01-22T12:20:42.536820+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:122][SSM] [SSM] ready completed
<13>1 2024-01-22T12:20:42.536867+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] InitBroadcast: SSM => ENTER_STATE_MACHINE [1705922442536]
<13>1 2024-01-22T12:20:42.536886+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] InitBroadcast: SSM => ENTER_STATE_MACHINE [1705922442536] [mainClient,schedule_manager,]
<13>1 2024-01-22T12:20:42.537026+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:189][SSM] [SSM] Starting SSM...
<13>1 2024-01-22T12:20:42.537105+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:90][SSM] [PERF] StateChange: SSM => Manual [1705922442537]
<13>1 2024-01-22T12:20:42.537186+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Broadcasting activate: SSM ==> mainClient
<13>1 2024-01-22T12:20:42.537228+01:00 - ssm 5595 - - [0us][DEBUG][tid:0][vanilla_main.cpp:98][SSM] Broadcasting activate: SSM ==> schedule_manager
<13>1 2024-01-22T12:20:42.542367+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] StateChange: mainClient => INIT_CLONE [1705922442542296]
<13>1 2024-01-22T12:20:42.542420+01:00 - ssm 5595 - - [0us][DEBUG][tid:2][vanilla_main.cpp:90][SSM] [PERF] StateChange: mainClient => Manual [1705922442542374]
stm_master.log
[STM ERROR]:[av/stm/runtime/src/core/state.c][clientBarrierWait] [180]: 1 clients have already exited
[STM ERROR]:[av/stm/runtime/src/core/state.c][setExitState] [237]: Error during clients exit sync, time: 12:22:03.248164689
[STM ERROR]:[av/stm/runtime/src/core/state.c][stmSetState] [634]: Incorrect state transition request., time: 12:22:03.302991867
detectAndTrack.node.json
"comment": "Generated by the nodedescriptor tool based on data provided by the C++ API of the node class",
"generated": true,
"library": "libminipipeline_nodes.so",
"name": "dw::framework::detectAndTrack",
"inputPorts": {
"IN_IMG": {
"type": "dwImageHandle_t",
"bindingRequired": true
"outputPorts": {
"BOX_ARR": {
"type": "YoloScoreRectArray",
"BOX_NUM": {
"type": "uint32_t"
"parameters": {},
"passes": [
"name": "SETUP",
"processorTypes": [
"CPU"
"name": "PROCESS",
"processorTypes": [
"GPU"
"name": "TEARDOWN",
"processorTypes": [
"CPU"
If you need further information, let me know.
Thank you.
