I have created a particle system using a particle sampler to create a liquid simulation. However, when the cube is very small Isaac Sim creates perhaps 10 particles in the system, in order to accurately simulate the liquid I need more than this. Is there a way to modify the number of particles in a system, and perhaps the size?
Hi @arjunsohal12 ,
I assume you use the particle sampler to convert a mesh to particles? If yes, please read both about the particle system configuration:
https://docs.omniverse.nvidia.com/extensions/latest/ext_physics/physics-particles.html#particle-system-configuration
And about the sampler:
https://docs.omniverse.nvidia.com/extensions/latest/ext_physics/physics-particles.html#particle-sampler
Using appropriate offsets and sampler parameters will let you achieve a higher particle resolution.
Philipp
