Changing the location of spawn -- with forklift_prim: AttributeError: __enter__ Simulation App Shutting Down
I am initially spawning a forklift after main() and then spawn other objects every frame around it.
So, now, I am interested in changing the location of spawn forklift every frame too.
Could you guide me how to fix this?
The code is:
def main():
    # Open the environment in a new stage
    print(f"Loading Stage {ENV_URL}")
    open_stage(prefix_with_isaac_asset_server(ENV_URL))
    # Create a custom scope for newly added prims
    stage = get_current_stage()
    floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
    bb_cache = bounds_utils.create_bbox_cache()
    combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=floor_prims)
    margin = 0.5
    min_x, min_y, min_z, max_x, max_y, max_z = combined_range_arr
    position = (np.random.uniform(min_x + margin, max_x - margin),  # x
            np.random.uniform(min_y + margin, max_y - margin),  # y
            0)                                                  # z
    scope = UsdGeom.Scope.Define(stage, SCOPE_NAME) # mona score is not used anywhere!!!
    # Spawn a custom forklift at a random pose
    forklift_prim = prims.create_prim(
        prim_path=f"{SCOPE_NAME}/Custom_Forklift",
        position = position,
        orientation=euler_angles_to_quat([0, 0, random.uniform(0, math.pi)]), random.uniform(0, math.pi)]),
        usd_path=CUSTOM_FORKLIFT_URL,
        semantic_label="Forklift",
    with rep.trigger.on_frame(num_frames=CONFIG["num_frames"]):
        0)                                                  # z
        rep.randomizer.scatter_boxes()
        rep.randomizer.randomize_lights()
        rep.randomizer.randomize_color()
        with forklift_prim:
            rep.modify.pose(
                position=position,
                rotation=rep.distribution.uniform((-90,-180, 0), (-90, 180, 0)),
The error is:
2023-02-21 18:16:26 [24,074ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_44/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-02-21 18:16:26 [24,074ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_45/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-02-21 18:16:26 [24,074ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_46/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-02-21 18:16:26 [24,074ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_47/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-02-21 18:16:26 [24,074ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_48/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-02-21 18:16:26 [24,074ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_49/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
Simulation stopped after 217 steps
2023-02-21 18:16:29 [26,988ms] [Warning] [carb.flatcache.plugin] UsdRelationship /Replicator/SDGPipeline/OgnGroup_08.inputs:prims has multiple targets, which is not supported
/buildAgent/work/f25a4639a4b1bdc1/source/foundation/FdFoundation.cpp (162) : invalid operation : Foundation object exists already. Only one instance per process can be created.
inspect.signature(rep.randomizer.scatter_2d):  (surface_prims: Union[omni.replicator.core.scripts.utils.utils.ReplicatorItem, List[str]], seed: int = None, offset: int = 0, check_for_collisions: bool = False, input_prims: Union[omni.replicator.core.scripts.utils.utils.ReplicatorItem, List[str]] = None)
2023-02-21 18:16:37 [35,141ms] [Error] [__main__] Exception: __enter__
  File "/home/mona/SDG/omniverse-sdg/offline_generation.py", line 752, in <module>
    main()
  File "/home/mona/SDG/omniverse-sdg/offline_generation.py", line 599, in main
    with forklift_prim:
[35.521s] Simulation App Shutting Down
Actually, I wrote this function and I am not getting error. The change of position of forklift is minimal and hard to judge
    def randomize_forklift_position(position):
        forklift = rep.get.prims(semantics=[('Custom_Forklift')])
        with forklift:
            rep.modify.pose(
                position=position,
        return forklift.node
    rep.randomizer.register(randomize_forklift_position)
and now I call it like this:
        0)                                                  # z
        rep.randomizer.scatter_pallets()
        rep.randomizer.randomize_forklift_position(position)
Please let me know about your thoughts.
Somehow the rotation of forklift is not changing at all.
Can you check if your rep.get.prims returns the requested prims?
For such questions it is always best to provide a script that we can reproduce. Best case in a very simple scenario containing only the function producing the issue. This way we can quickly test and check for a solution.
