When I want to use the Export as prop of Revit plug-in to export the BIM model and generate USD file,every time the progress bar reaches about 60%,the plug-in will crash and disappear,regardless of the number of components
Related topics
| Revit to create | 4 | 1106 | February 15, 2022 | |
| Chinese UI version revit export | 1 | 974 | August 3, 2022 | |
| Autodesk revit connector error | 9 | 1236 | December 8, 2022 | |
| Revit crashes when using the Connector | 3 | 560 | April 9, 2024 | |
| Revit 202x Japanese UI version can't export USD data and Material | 4 | 1030 | May 14, 2021 | |
| Message "Failure to open MDL Table" show when export data to usd | 12 | 1880 | December 2, 2021 | |
| Omniverse Revit Connector v202.0.2400 | 1 | 601 | June 20, 2023 | |
| Omniverse Revit Connector v201.1.2338 | 0 | 645 | March 9, 2023 | |
| I got my vdb converted to mesh, but exported USD crash Composer | 2 | 762 | August 2, 2023 | |
| Revit Connector issue [Send to view failed] | 6 | 944 | December 22, 2020 |
