Trouble controlling robotiq gripper using Isaac Lab
Hey guys,
I created a custom USD with robotiq gripper and a couple of prismatic joints to be able to move around the gripper once the object is grasped. When I set the velocity target to “finger joint” and “right_outer_knuckle_joint” in the Isaac Sim UI, I can see that the gripper is able to grasp the object.
But when I import the USD into my Isaac Lab interactive scene cfg and try to set the velocity target using “set_joint_velocity_target”, the joints move even after the fingers make contact with the object. Has anybody seen this before? Any pointers is welcome. I am unable to find documentation for this.
USD file is in the attached zip and below is the code. Do you see any obvious point that I may be missing here?
import argparse
from isaaclab.app import AppLauncher
# create argparser
parser = argparse.ArgumentParser(description="Tutorial on spawning prims into the scene.")
# append AppLauncher cli args
AppLauncher.add_app_launcher_args(parser)
# parse the arguments
args_cli = parser.parse_args()
# launch omniverse app
app_launcher = AppLauncher(args_cli)
simulation_app = app_launcher.app
"""Rest everything follows."""
import numpy as np
import torch
import time
import isaacsim
import isaacsim.core.utils.prims as prim_utils
from  isaacsim.robot.manipulators.grippers import ParallelGripper
import isaaclab.sim as sim_utils
from isaaclab.assets import ArticulationCfg, AssetBaseCfg, RigidObjectCfg
from isaaclab.scene import InteractiveScene, InteractiveSceneCfg
from isaaclab.sim import SimulationContext
from isaaclab.utils import configclass
from isaaclab.utils.assets import ISAACLAB_NUCLEUS_DIR
from isaaclab.actuators import ImplicitActuatorCfg
from isaaclab.managers import SceneEntityCfg
from isaacsim.core.utils.types import ArticulationAction
import isaaclab.envs.mdp as mdp
@configclass
class RobotiqGripper(InteractiveSceneCfg):
    # ground plane
    ground = AssetBaseCfg(prim_path="/World/defaultGroundPlane", spawn=sim_utils.GroundPlaneCfg(), init_state=AssetBaseCfg.InitialStateCfg(pos=[0, 0, -0.1]))
    # lights
    dome_light = AssetBaseCfg(
        prim_path="/World/Light", spawn=sim_utils.DomeLightCfg(intensity=3000.0, color=(0.75, 0.75, 0.75))
    # Add Robotiq gripper articulation
    gripper = ArticulationCfg(
        prim_path="/World/Gripper",
        spawn=sim_utils.UsdFileCfg(
            usd_path="<insert_usd_path_here",
            rigid_props=sim_utils.RigidBodyPropertiesCfg(
                disable_gravity=False,
                max_depenetration_velocity=5,
        init_state = ArticulationCfg.InitialStateCfg(pos = [0, 0, 0]),
         actuators={
            "finger_joint": ImplicitActuatorCfg(
                joint_names_expr=["finger_joint"],
                velocity_limit=80,
                effort_limit=2,
                stiffness=0.0,
                damping=5000.0,
            "right_outer_knuckle_joint": ImplicitActuatorCfg(
                joint_names_expr=["right_outer_knuckle_joint"],
                velocity_limit=80,
                effort_limit=2,
                stiffness=0.0,
                damping=5000.0,
            "left_outer_finger_joint": ImplicitActuatorCfg(
                joint_names_expr=["left_outer_finger_joint"],
                velocity_limit=0,
                effort_limit=0,
                stiffness=0.05,
                damping=0.0,
            "right_outer_finger_joint": ImplicitActuatorCfg(
                joint_names_expr=["right_outer_finger_joint"],
                velocity_limit=0,
                effort_limit=0,
                stiffness=0.05,
                damping=0.0,
            "left_inner_finger_joint": ImplicitActuatorCfg(
                joint_names_expr=["left_inner_finger_joint"],
                velocity_limit=0,
                effort_limit=0,
                stiffness=0.0,
                damping=0.0,
            "right_inner_finger_joint": ImplicitActuatorCfg(
                joint_names_expr=["right_inner_finger_joint"],
                velocity_limit=0,
                effort_limit=0,
                stiffness=0.0,
                damping=0.0,
            "left_inner_finger_knuckle_joint": ImplicitActuatorCfg(
                joint_names_expr=["left_inner_finger_knuckle_joint"],
                velocity_limit=0,
                effort_limit=0,
                stiffness=0.0,
                damping=0.0,
            "right_inner_finger_knuckle_joint": ImplicitActuatorCfg(
                joint_names_expr=["right_inner_finger_knuckle_joint"],
                velocity_limit=0,
                effort_limit=0,
                stiffness=0.0,
                damping=0.0,
def run_simulator(sim: sim_utils.SimulationContext, scene: InteractiveScene):
    robot = scene["gripper"]
    print(robot.data.joint_names)
    count = 0
    while simulation_app.is_running():
        if count % 500 == 0:
            # reset counter
            count = 0
            root_state = robot.data.default_root_state.clone()
            root_state[:, :3] += scene.env_origins
            robot.write_root_pose_to_sim(root_state[:, :7])
            robot.write_root_velocity_to_sim(root_state[:, 7:])
            # set joint positions with some noise
            joint_pos, joint_vel = robot.data.default_joint_pos.clone(), robot.data.default_joint_vel.clone()
            joint_pos += torch.zeros_like(joint_pos)
            robot.write_joint_state_to_sim(joint_pos, joint_vel)
            # clear internal buffers
            scene.reset()
            print("[INFO]: Resetting robot state...")
        target_velocity = torch.zeros(1, 10).to(robot.device)
        target_velocity[0, 2:4] = 5
        robot.set_joint_velocity_target(target_velocity)
        robot.write_data_to_sim()
        count += 1
        sim.step()
def main():
    """Main function."""
    # Load kit helper
    sim_cfg = sim_utils.SimulationCfg()
    sim_cfg.dt = 0.005
    sim = SimulationContext(sim_cfg)
    sim.set_camera_view([2.5, 0.0, 2.5], [0.0, 0.0, 1.0])
    # Design scene
    scene_config = RobotiqGripper(num_envs=1, env_spacing=2.0)
    scene = InteractiveScene(scene_config)
    sim.reset()
    print("[INFO]: Setup complete...")
    # Run the simulator
    run_simulator(sim, scene)
if __name__ == "__main__":
    # run the main function
    main()
    # close sim app
    simulation_app.close()
barebone_test.zip (5.6 KB)
