We use CloudXR on AWS with EC2 Instances (g5.4xlarge). We now have a voice server running that we can use for collaboration and it works fine using NICE DCV. Currently we need also NICE DCV, because we want to allow to turn VR on and off as needed. So we also wanted to test it in VR with CloudXR, but we found the problem that actually there audio seems to not work yet. Both not hearing audio as well as sending audio through the mic. Interestingly, sometimes in the SteamVR Menu (which I guess is also streamed) I get some sounds when I press on buttons, but that is only sometimes the case and so for I was not able to reproduce when exactly. However inside of the apps when we activate VR it keeps using the regular Microphone and Speakers (there we can still hear stuff).
Now we looked through the stuff required and seem to have everything, the required ports are open, we use the needed console parameter on server and client and we installed the CloudXR server plus Subcomponents after the GPU driver. However to be sure that the installation of the audio driver also worked, we see this on the instances:
In some forum posts we saw that there should probably be a “Nvidia Virtual Audio Device” ? (like here: No virtual audio devices on AWS cloudXR - #9 by huong) Is it possible that the automated installation does not install the audio driver? We did use the /S Option. Can we ensure somehow it was correctly installed?
Best
Xaver
