Coil whine noise of Jetson Orin Nano
Although you probably do not have time for this right now, if you run into this again, then it would be interesting if you could record the noise. Examining the noise to see what frequency it is, and if frequency changes under load, might correspond to some power component’s operating range, e.g., a switching power supply’s clock.
