I didn’t know what I’m looking if serial console connected. The case is quite simliar as I have mentioned above. And I’m quite sure it’s NOT Jetpack 5.1.4 /L4T35.6 issue. As it just caught my attention since CUDA upgrade. But I’m NOT sure what makes the noise.
You mentioned this noise happened before nvidia logo, so you could check at which stage of boot flow that this noise started to happened and them share that log to me. Or point out a rough stage where you saw it.
This actually sounds something that do not make sense. What you reported is something before UEFI bootloader stage. But CUDA installation is after kernel.
I think the uart log as you requested I have attached above.
The issue is loud noise fan (100PWM, I think) before log prints “Jetson UEFI firmware (version 6.0-37391689 built on 2024-08-28T08:47:11+00:00)”.
There is no mis-understanding of the expression.
Now, what rootcause or probable issue it is?
As you have said “Previous stage is totally non open source bootloader software and installing CUDA won’t really bring any impact to it theoretically.”
Is it possbile there is any configuration caused trouble?(As we have no idea about NVIDIA’s private code)
EDIT: As update procedure is automatically, I could miss key points that might be related with the fan issue, something like configuration, software (including non-open-souce, such as NVIDIA’s private code)
EDIT2: I don’t think it’s hardware issue, as it’s quite ok when enterning desktop controlled by nvfancontrol. My guess is software/configuration. I hope someone can help to provide debug methods to do the test. Re-flashing the syetem is the last option.
If this is “software problem”, then reflash the software shall restore the situation, right? That is what I want to confirm for now. Could you help and confirm that?
Is this a NV devkit or custom board?
No one ever reported this on Orin NX/Nano before. I am not able to directly tell you “the root cause” just according to such little information
This post you shared is based on custom board. The fan spec might be different from NV devkit situation. Thus, the information from it is not sufficient either.
