The Jetson Nano won't power on because the fan isn't working
I want to continue my project, but when I plug in the power cord, the green power indicator light comes on, but the fan doesn’t turn on. After a while, the power indicator light goes out (I suspect the computer overheated and tripped). Therefore, I can’t force it to boot using the flash memory. Has anyone had a similar experience and can help me?
Are you using Jetson Nano or Orin Nano?
Which JetPack SW?
Orin jetson nano devkit
JetPack 6.2.1
Please place the device in recovery mode and perform a full flash using the SDK Manager.
Thank you.
I’ve tried several times, but the flashing process failed. However, something strange happened: initially, the power indicator light didn’t light up when I plugged in the power cord, but it suddenly turned on halfway through the flashing process.
I just re-downloaded the SD card image file and the computer booted up successfully! Thank you all for your help and suggestions.
