I have installed jetson-multimedia-api through sudo apt-get install jetson-multimedia-api
I have tried to compile 00_video_decode like above picture.
What am I supposed todo?
Thank you.
Thank you.
Looks like you don’t install CUDA. You may install it through SDKManager, or remove -lcudart from Rules.mk.
I have installed with flash.sh not sdk manager.
Can I install CUDA seperately?
Thank you.
You may download nvidia-container-csv-cuda_10.2.89-1_arm64.deb from SDKManager, copy it to Nano and install it by executing
sudo apt install nvidia-container-csv-cuda_10.2.89-1_arm64.deb
Should be cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
명령어가 잘못된 거 같습니다.
I copied nvidia-container-csv-cuda_10.2.89-1_arm64.deb with sdkmanager.
Installation is not possible with the following command.
What am I supposed to do?
Thank you.
The deb file is not right, please copy
Hi neuezeal,
Please reference below steps to install CUDA:
$ sudo dpkg -i cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
$ sudo apt-key add /var/cuda-repo-10-2-local-10.2.89/7fa2af80.pub
$ sudo apt-get update
$ sudo apt-get -y install cuda-toolkit-10-2
