Configuring Clock Speed of Jetson Nano
Hello Experts,
CC: @Honey_Patouceul @DaneLLL @Amycao @kayccc @icornejo.a @AastaLLL @dusty_nv @forumuser @Jeffli
Pls specify how to run the Jetson nano at max frequency and would there any thermal impact of doing so ?
please, refer to jetson_clocks
Thank you.
Additional note:
jetson_clocks has several options. After booting and before boosting, you may save a slow clocks config for being able to restore later :
sudo jetson_clocks --store
So that you’ll be able to restore later with:
sudo jetson_clocks --restore
For boosting, not sure for recent releases, but before launching jetson_clocks as @forumuser mentionned, you may first select a NVP model:
sudo nvpmodel -m 0
sudo jetson_clocks
Max perf NVP model used to be 0 on most Jetsons (but surprisingly on NX it may be -m 2, though).
Thank you for the detailed explanation.
