Connect Hikvision IP camera to Jetson Orin
I have a Hikvision IP camera, but after connecting the camera to the device directly I am not able to find out get if the device is connected properly, as it does not have support for SADP tool. is there any other way I should connect the camera in order for it to work properly with the edge device.
The camera works fine, as I can connect it to my laptop and view the stream in vlc through rtsp.
We would suggest check with the vendor to get support. Probably it needs additional driver and some kernel configs have to be enabled.
