Connecting a DPST 4 Pin Switch to Jetson Nano B01
I am using a 4 Pin On-Off 2 Position DPST Boat Rocker Switches to connect it to Jetson Nano. The switch has a main positive, main negative, load positive, and load negative. Where do I connect that parts to manually on/off the jetson.
Hi, please share the diagram of schematic of your switch.
here is the link of the switch including the schematic
You should use it to the power supply of your Jetson nano board.
What switch do we need to use? We use a micro USB cable to power up the jetson nano. But we want to make the power on/off manually not automatically when micro USB is plugged in.
It depends on your choice. Are you planning use this switch to manually control power input to nano? Then you should add this switch in series in your power supply line (here is the vbus of USB cable per your description).
There is no place on devkit carrier board for this switch to add into VDD_5V_USB net. You need to add it outside into vbus of cable.
Thank you!
