Hi!
I’m trying to connect a display to the Jetson TX1 J23 connector via an adapter board. The analog power supply of the display requires a 3V voltage, but the pin I want to connect from the module(VDD_DIS_3V3_LCD), has a 3.3V output.
The description of the pin says it´s a gated 3.3V analog supply.
Can I use an IC driver or a simple voltage divider to get the voltage I want(like a digital signal), or should I use something else?
Thanks in advance
