Hi everyone,
I’m using Isaac sim to train a wheeled robot.
I would like to know if there are available controllers for wheeled robots in here (e.g. a differential controller).
Thank you!
Hi everyone,
Thank you!
Here is a link for reference: Wheeled Robots [omni.isaac.wheeled_robots] — isaac_sim 4.2.0-rc.17 documentation
Thank you!
When I import the package from omni.isaac.wheeled_robots.controllers import DifferentialController, I get the following error:
ModuleNotFoundError: No module named 'omni.isaac.wheeled_robots'
Why is it?
Closing note — the ModuleNotFoundError and how to fix it:
The extension needs to be explicitly enabled before importing. In Isaac Lab / standalone scripts, extensions are not auto-loaded like they are in the Isaac Sim GUI.
Isaac Sim 4.5+ (module was renamed):
from isaacsim.core.utils.extensions import enable_extension
enable_extension("isaacsim.robot .wheeled_robots")
from isaacsim.robot.wheeled_robots.controllers import DifferentialController
Isaac Sim 4.1–4.2 (original module name):
from omni.isaac.core.utils.extensions import enable_extension
enable_extension("omni.isaac.whe eled_robots")
Available controllers: DifferentialController, HolonomicController, AckermannController, WheelBasePoseController, plus QuinticPolynomial path planner and stanley_control.
Updated docs: https://docs.isaacsim.omniverse.nvidia.com/latest/robot_setup/ext_isaacsim_robot_wheeled_robots.html
