I am trying to make my robot move like a differential wheeled robot, where the wheels on one side rotate forward and the wheels on the other side rotate backward in order to turn. However, instead of turning, it just goes straight. I have experimented with different friction values on the wheel material, as well as different collision approximations. Does anyone have any tips on how to solve this issue?
rthaker
3
Hi @funktiona -Apologies for the delay in response. Please let us know if you are still having any issues or questions after using the latest Isaac Sim release.
Related topics
| 4 wheels differential drive robot issues | 1 | 1460 | March 28, 2023 | |
| Physics/friction settings for 4-wheel differential drive? | 2 | 41 | December 5, 2025 | |
| Incorrect angular velocity when simulating differential drive in IsaacGym | 1 | 559 | February 22, 2024 | |
| Differential Drive Mobile Robot Wheel Friction Issues | 0 | 83 | August 6, 2024 | |
| Custom URDF Vehicle Moving Backwards using ROS Differential Base | 8 | 1265 | April 5, 2024 | |
| Abnormal orientation change when robot is rotating | 2 | 54 | January 7, 2026 | |
| Differential Drive Mobile Robot Wheel Friction Issues | 3 | 240 | October 25, 2024 | |
| Action Graph to Move Custom Robot Using ROS? How should the articulation controller be set up? | 3 | 526 | May 20, 2023 | |
| Using IsaacGym to simulate differential drive of a four-wheel robot | 4 | 1357 | March 13, 2025 | |
| Problems with starting differential controller and moving my car by pressing keys in space | 2 | 68 | September 6, 2025 |
