Hi, all.
Last night I resized my ubuntu20.04 via GParted tool, and today the Omniverse Launcher could not login anymore.
However, the same count is accessible on the other PC.
Here is the related msgs on the terminal:
walker2@walker2:~/appImages$ ./omniverse-launcher-linux.AppImage
10:54:58.953 › Omniverse Launcher 1.8.11 (production)
10:54:58.966 › Argv: /tmp/.mount_omniveaV52lW/omniverse-launcher
10:54:58.966 › Crash dumps directory: /home/walker2/.config/omniverse-launcher/Crashpad
10:54:59.197 › Running “/home/walker2/.local/share/ov/pkg/cache-2023.1.0/System Monitor/omni-system-monitor”
10:54:59.208 › Running “/home/walker2/.local/share/ov/pkg/nucleus-workstation-2023.1.0/System Monitor/omni-system-monitor”
10:54:59.216 › Reset current installer.
10:54:59.284 › Running production web server.
10:54:59.296 › HTTP endpoints listening at http://localhost:33480
10:54:59.305 › Sharing: false
10:54:59.411 › Started the Navigator web server on 127.0.0.1:34080.
10:55:00.371 › Saving omniverse-launcher.desktop file to /tmp/omniverse-launcher-FFgFLW…
10:55:00.372 ›
[Desktop Entry]
Name=omniverse-launcher
Exec=“/home/walker2/appImages/omniverse-launcher-linux.AppImage” %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/omniverse-launcher
10:55:00.567 › Saving omniverse.desktop file to /tmp/omniverse-launcher-Y0p5lV…
10:55:00.567 ›
[Desktop Entry]
Type=Application
Terminal=false
10:55:00.748 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
(Use omniverse-launcher --trace-warnings ... to show where the warning was created)
10:55:00.749 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 1)
10:55:11.817 › Login URL opened.
10:55:11.823 › Waiting for login result…
10:56:16.621 › WEB /login-result?ui_locales=en&code=4LLpBhIb8lFCuZinakHh0kq7d6f0HrkRJo7Xt5mvDCecwVjHxmLetzdKEKu0xWK4gwfrZvJjpTk0TJUjD8jYaw
10:56:18.260 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
10:56:18.260 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 2)
10:56:46.638 › Login cancelled.
10:56:59.569 › Error happened during the update: Error: net::ERR_INTERNET_DISCONNECTED
at SimpleURLLoaderWrapper. (node:electron/js2c/browser_init:2:49549)
at SimpleURLLoaderWrapper.emit (node:events:513:28)
10:57:19.511 › Login URL opened.
10:57:19.517 › Waiting for login result…
10:57:30.454 › WEB /login-result?ui_locales=en&code=CpsQkBs5oEiE0KS4NZxcOtZ89B31KKxtGYQ2mGAK-SCrAr2u3B07yvz6L28fHvK3f3UaSw61-4xycSbxSuyo4Q
10:57:32.048 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
10:57:32.048 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 3)
10:58:07.902 › Login cancelled.
11:00:10.978 › Login URL opened.
11:00:10.984 › Waiting for login result…
11:00:20.562 › WEB /login-result?ui_locales=en&code=zy1q0dl8aVnrUuh1WwaXci42CXOfoUm7HujTWX_82ZwNqgS0kKGrQP8TbuQFNNpKlGKRfEKUQFUaMIGFBi2s2Q
11:00:22.079 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
11:00:22.080 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 4)
11:01:59.940 › Error happened during the update: Error: net::ERR_INTERNET_DISCONNECTED
11:02:59.945 › Error happened during the update: Error: net::ERR_INTERNET_DISCONNECTED
11:03:59.950 › Error happened during the update: Error: net::ERR_INTERNET_DISCONNECTED
11:04:38.783 › Failed to get GDPR, retrying in 2.5 seconds…
11:04:41.289 › Failed to get GDPR, retrying in 2.5 seconds…
11:05:06.722 › WEB /login-result?ui_locales=en&code=CpsQkBs5oEiE0KS4NZxcOtZ89B31KKxtGYQ2mGAK-SCrAr2u3B07yvz6L28fHvK3f3UaSw61-4xycSbxSuyo4Q
11:05:07.513 › WEB /login-result?ui_locales=en&code=CpsQkBs5oEiE0KS4NZxcOtZ89B31KKxtGYQ2mGAK-SCrAr2u3B07yvz6L28fHvK3f3UaSw61-4xycSbxSuyo4Q
11:05:08.312 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
11:05:08.313 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 5)
11:05:08.927 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
11:05:08.927 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 6)
11:05:26.618 › Login cancelled.
11:05:32.687 › Login URL opened.
11:05:32.692 › Waiting for login result…
11:05:44.768 › WEB /login-result?ui_locales=en&code=maCpMJwl19lktOKolqZA-5XrStPTopEpJNi3I2ggIGyPyS-okJp4YmIw9rSCqVqG7K2Z_qiqWzkEF_-JEZSTqg
11:05:46.409 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
11:05:46.410 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 7)
11:08:00.248 › Error happened during the update: Error: net::ERR_INTERNET_DISCONNECTED
11:08:48.845 › Login cancelled.
11:08:50.185 › Login URL opened.
11:08:50.190 › Waiting for login result…
11:09:12.807 › WEB /login-result?ui_locales=en&code=a9b-juAxePAe5qz8x67A0HPP5io-UZt-y3UysQ7STokMmXdcVdQDqGQ56rGYD7pe4Dk1bE5nsh3GxqZQ7ZwtsA
11:09:14.371 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
11:09:14.371 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 8)
11:09:28.701 › Login cancelled.
11:10:16.581 › Login URL opened.
11:10:16.587 › Waiting for login result…
11:11:56.147 › WEB /login-result?ui_locales=en&code=ca2-AmKVYl18wELcmDwPl9azDOss4eC3XbFXg0xh9LsZcFwRCnyDEVxFUx2gCNKKD8M92q-oUsUypd_EUCNvTQ
11:11:57.614 › (node:10735) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, unlink ‘/home/walker2/.config/autostart/nvidia-omniverse-launcher.desktop’
11:11:57.615 › (node:10735) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v20.5.0 Documentation). (rejection id: 9)
And the launcher keeps turning around all the day with no sign of going any futher.
Can you help me with the problem?
