Couldn't spin following the goal speed
Hi, I have a four-wheel car model. And I want to control the car following the goal speed. The command are only move forward and spin without drift.
Now the car can follow the linear goal speed, **but it can’t follow the rotate goal speed in spin action. And the car will drift when it spins specially in low speed.
What I do is to set the front_left_wheel and rear_left_whell to 175 degree/s, front_right_wheel and rear_right_whell to -175 degree/s running in the ground plane. So the ideal goal speed is 1rad/s.
The distance between left wheel and right wheel is 0.49. The wheel radius is 0.08.
IsaacSim 5.0
Thanks for your help!!
scout_mini_v6.zip (4.0 MB)
Hi, can you share your code also?
Take a look at this tutorial on driving an AMR using ROS2 Messages. Check out the info on driving a robot with a differential controller. Mobile Robot Controllers — Isaac Sim Documentation
